> Make sure you removed the air plugs from the cartridges. If you look on top of
> the cartridge there should be 2 plugs, a clear one on the back and a colored one
> towards the top (the top being closer to the inside of the printer). Remove the
> clear plugs as these allow air into the cartridge. The colored plugs are used
> for refilling and should stay in at all times except when refilling.
> After that, run a few cleaning cycles until you start to see ink. You could also
> run a few test prints instead. The problem with new cartridges is they are not
> primed. Therefore you have to priome them to get the ink flowing.
> Stupid question but possible, you do have ink in the cartiridges, right?
> From: hovikgbg <hovikgbg@...>
> Sent: Sat, March 5, 2011 6:50:52 AM
> Subject: [Digital BW] mis ut7 on epson 2200
> Â
> I installed UT7 on my Epson 2200. It is supposed to work with the Epson driver
> using Paul Roark workflow. The 2200 simply will not print - even maintanence,
> nozzle check. I cannot find profiles on his web page. Must I use QTR or
> alternative? If I install QTR driver, how do I get Epson driver back when I wish
> to use full color Epson. I use Win XP SP 3, LR3, PS CS3. By the way, I
> reinstalled the Epson cartridges and I print just fine - except for the
> metamerism and a color cast (usually green sometimes magenta) in my B&W which
> got me to order the UT7 in the first place. What to do?
