Brown Tone Ink Set Needed
2011-06-28 by davidkachel
I am hoping someone can suggest a starting point as I am back to square one (almost) after a year and a half.
I need quadtone inks (6 or 7 dilutions probably) that will be used in an Epson SP 3800 w/QTR. I need to produce full brown tones, not subtle like sepia but frank unmistakable browns. I know this presents archival problems. They have to be secondary to image color. On the other hand I would prefer the least problematic inks possible under the circumstances.
I am aware there is nothing like this at the moment but need a starting point with currently available inks. I print only on matte rag papers.
I presume a good starting point would be MIS MK for the black and gray dilutions but have no idea what colored pigments to use or how to approach their use; whether to mix the color pigments with the black or put them in separate cartridges for more control. The latter would seem more logical as it would allow me to create different profiles for different papers.
I see there are ink sets that have color pigments for cooling naturally warm black inks to a neutral tone so am wondering if simply using the same kind of set up with opposite colors might be the place to start.
All ideas/suggestions are welcome. And yes, I know about ABW. That is not what I am after.
RE: [Digital BW] Brown Tone Ink Set Needed
2011-06-28 by E.Neilsen
How do you relate brown to the Sepia set of Cones Piezotones - Sepia. I call
that a brown. Sepia is just as hard to call as a "platinum" since MOST
platinum prints these days are REALLY only palladium prints.  Perhaps get
three channels using the dark tone and back one of the three off to 50%. Or
just over print a brown color.
Eric Neilsen
Eric Neilsen Photography
4101 Commerce Street, Suite 9
Dallas, TX 75226
www.ericneilsenphotography.com
skype me with ejprinter
www.ericneilsenphotography.com/forum1
Let's Talk Photography
  _____
davidkachel
Sent: Tuesday, June 28, 2011 4:01 PM
Subject: [Digital BW] Brown Tone Ink Set Needed
what I am after.
Re: [Digital BW] Brown Tone Ink Set Needed
2011-06-29 by davidkachel
Eric,
For lack of more sophisticated terminology, I would call Cone's Sepia "brown--ish". I am after something much less subtle. Think turn of the century cabinet cards and then a little more brown than that... Hershey's chocolate! And then, I want to be able to control it for use on different papers rather than having to rely how the ink set chooses to behave from one paper to another.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E.Neilsen" <e.neilsen2@...> wrote:
> that a brown.
2011-06-29 by E.Neilsen
OK, brownish works for me. that's why I thought perhaps using a darker blend
and less of it might work in a higher position. What are you going to use to
drive the ink set? QTR? Studio Print?  I do understand the part about not
wanting to let the ink determine the color too. I believe that part might
require a stronger tone from the ink set.  What about a solution like a
custom profile using i1 or Data color and staying with color ink? Such a
specific richness in color from a mono ink set is not common and a little
hard to buy off the shelf.
Eric Neilsen
Dallas, TX 75226
  _____
davidkachel
Sent: Tuesday, June 28, 2011 8:51 PM
Subject: Re: [Digital BW] Brown Tone Ink Set Needed
Eric,
paper to another.
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E.Neilsen"
call
> that a brown.
QTR. I can get what I want visually from both HP and Epson OEM ink sets. But it is not consistent and I know it can be done better and with smoother tones with Quadtone inks.
I have used mostly the HP inks and they just decide to careen off the road for no particular reason once in a while. I'll have a nice brown print with a strip through it 2 points more toward green. Besides, better inks for less money is a strong draw.
2011-06-29 by Ernst Dinkla
I would think that a HP Vivera Red (Z3100) would be a good pigment ink
to start with.
Met vriendelijke groeten,   Ernst
Try: http://tech.groups.yahoo.com/group/Wide_Inkjet_Printers/
|      Dinkla Grafische Techniek      |
|         www.pigment-print.com        |
|                 ( unvollendet )                 |
2011-06-29 by David Whistance
I've not tried them but American Inkjet Systems sell a Burnt Sienna ink in
their bulk sets for Roland 12 ink printers which might be a good starting
point.  Give them a call and see if they can help out.
David Whistance
davidkachel
Sent: 29 June 2011 03:25
To: DigitalBlackandWhiteThePrint@...
blend
to
