Epson R3000 Using only matte black ink cartridge
2011-12-26 by sdsennert
I am replacing an Epson SP 2200 with an R3000. I have been using QRT and
printing on Premier Fine Art paper with the 2200. The ink set is Epson
OEM with matte black.  I never used photo black ink in the 2200. Here is
the question: If the photo black cartridge is installed in the R3000 as
part of the complete set and never used, what are the long-term
ramifictions? Is it possible to use the R3000 without the photo black
cartridge installed at all?
Re: Epson R3000 Using only matte black ink cartridge
2011-12-26 by Paul
>... Is it possible to use the R3000 without the photo black
Probably not.
If there is a third party chip that is compatible with the Epson set, I'd probably put a clear base or cleaning fluid in the PK spot.  With respect to the 1400, I was pleasantly surprised to find the MIS chips are compatible with the OEM chips.  It might be worth asking them or others if they have a chip that is compatible with the R3000 chips -- that is, one that can be used in just a single spot and be treated as an OEM Epson chip by the printer software.
Epson probably has the machine clean itself enough to keep the PK from clogging, but, nonetheless, it would probably also be wise to print a page of black every few weeks to keep the systems in good shape.
