"remononaz1" <homershannon@...> wrote:
> I found a cache of ICC profiles today and am wondering if I can use these. A number of them seem well suited for use with Red River papers on an Epson 1400. I have a 1400 and usually print on Red River Art White, Polar Gloss or Polar Matte. Can anyone explain the following:
> These ICCs are for the Plus 4 set of B&W inks. Will they work with the UT-14 (six set) of inks?
ICCs are specific for the inkset named. usually mine are in Zip files that are linked to PDFs with respect to a specific inkset. UT14 is not the same as Eboni-4 Plus, if that is what the one was referring to.
> Each of the ICCs is listed with a name that is in code, for example:
> 1400-EB4-RR-auoraW-n2-rgb.icc
> I'm assuming this means:
> 1400 printer
Yes.
> Ebony 4 ink set
Yes.
> Red River Aurora White paper
Yes. I think you'll find the Red River Natural uses the same profiles.
> n2 - Neutral 2?
There can be more than a single ICC or profile that is "neutral." Sometimes I re-do one for some reason. If there are more than one, just see which one works best for you.
> rgb - set color space to RGB?
QTR's Create ICC-RGB, which was used to make the ICCs, puts an "rgb" at the end. The plain Create ICC does not. You still use a grayscale file when printing, however. I think if you use an RGB file it will covert it to gray scale prior to applying the embedded curves.
> What else do I need to know?
It's a good idea to read the PDF I've written on the inkset. An index (not totally complete) of PDFs by printer and inkset name is at http://www.paulroark.com/BW-Info/Inkset-list.html
