The MIS dye is not the Claria/Noritsu dye that I recommend. Old style dyes
fade very quckly.
Even the Claria/Noritsu dyes fade faster than a good carbon-based inkset.
A post-printing spray that seals the Claria/Noritsu dyes is necessary to
bring even the advanced dyes up into the range of Epson UC color prints in
terms of fading.
See the fade test results at http://www.aardenburg-imaging.com/ If you
click on the top of the Conservation Display Rating, that puts the results
in order by that column. Then you can see at a quick glance how the
various Claria tests do compared to other ink-paper combination. The Print
Shield Spray makes a huge difference. But, again, this is Claria -- which
I suspect is way different than MIS dyes. Some of the relevant testing is
summarized in this screen grab, including Wilhelm's --
http://www.paulroark.com/BW-Info/Claria-Fade-Tests.jpg
I don't recommend any dyes for long term, fine art type display. However,
the Claria on Canson, sprayed with Print Shield, did surprisingly well in
the Aardenburg-Imaging test. I have used un-sprayed Claria for cards,
printed on the Red River metallic paper, that have been displayed for a
year without any fade or color change that is apparent in casual viewing.
(I have not done a comparison to a dark storage card.)
On Thu, Sep 6, 2012 at 5:04 AM, remononaz1 <homershannon@...> wrote:
> Last spring I posted several notes about using the 2K2LK ink formula on
> Red River Polar Metallic paper. I used MIS D2-4-K black dye ink with the
> PR-Clearbase-PT solution. After some work I got it to print very nicely.
> Some time ago I noticed that the prints are starting to fade. Not only are
> they fading, they are turning RED. The darker the area the more red it is
> becoming. In one print I also have some blue in the whites.
> Mounted along with these prints are some others using UT-14 ink and '5/6'
> UT-14. (gloss prints with MIS D2-4-K in the black position in place of the
> Ebony carbon black) These prints are still perfect despite being up to a
> year older than the 2K2LK prints and hanging in the same light.
> I don't know if this is an issue with the ink or with the paper. I have
> some color prints on this paper that I think are also fading. I did not
> print on other papers for comparison. Looks like with RR Metallic this
> isn't a reliable combination.
