What I do is check all the carts either before I start a major printing job
or when any ink appears to be low as reported by the Epson monitor. Once a
pull on cart, the system will do a cleaning cycle. So, I might as well
check all and top off as needed.
On Fri, Feb 22, 2013 at 9:36 AM, jcphoto52 <jacques.caron@...>wrote:
> Thanks Paul
> I checked the gaps and it seems that first I had a clog; then, after
> cleaning and refilling, air was the culprit. I think that I'll follow your
> advice and fill the cartridges and let them sit overnight.
> Some users wrote that I should get a "chip resetter" anyways?!?
> All the taps have been removed. Actually, now, I'm printing like usual,
> testing my new paper. But I'm afraid that I'll have to refill soon since
> the Epson Dialog Box is telling me that "Ink is low". It's kind of messy
> here!
> Thanks again
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Paul Roark wrote:
> > Eb6 dilute inks seldom clog as such. It's usually air in the system. See
> > if the gaps are always in the same place (probably clog) or change from
> > test to test (air/foam). Doing too much "cleaning" will actually make
> > things worse.
> > One of the things that often works is to just let the system sit
> overnight.
> > The foam should rise in the carts, with the ink going down to the outlet.
> > Of course, if the cart is defective and allowing air to get in around the
> > seal at the outlet. Nothing may work.
> > I'm not a fan of auto-reset. The chip information and actual ink level
> > seem to get out of sync. However, the 1400 carts I have from MIS have
> > worked fine. They may, of course, have gone to a new supplier.
> > Needless to say, be sure the tap or plug that blocks the air inlets have
> > been removed.
> > Let me know how it goes.
> > Paul
> > On Fri, Feb 22, 2013 at 9:03 AM, jcphoto52 wrote:
> > > Hi all,
> > > My days of printing BO are shrinking like crazy!
> > > I bought a new 1430 from Epson, two weeks ago and an EB6 kit from MIS.
> I
> > > kept the original inks and installed the MIS inks.
> > > Made some tests to see how I could print BO. I followed a lot of
> advices
> > > from the group and decided to order some Red River paper. In the
> meantime,
> > > I printed on Epson Velvet Fine Art for my tests. I was quite pleased
> with
> > > the results.
> > > Receiving my new paper, I followed one member's procedure, print a head
> > > pattern first; though luck, two "colors" are blocked. Start a cleaning
> > > session, and still, clogged. After three passes, ink level was too low
> so I
> > > refilled all the cartridges always following carefully MIS "How-to".
> > > Now I'm playing a toaster round with the printer; it's saying that
> this is
> > > not an original cartridge , so plug, unplug (went trough all of them!)
> and
> > > now, still a bit clogged, I see that it took a lot of ink and I will
> have
> > > to refill again!
> > > Is it supposed to work like this? I can see now that MIS's chips are
> not
> > > up-to-par with Epson and these "auto-resetting" chips are not working
> very
> > > well.
> > > From someone with a lot of darkened fingers! I would love to go with
> all
> > > the tests needed to be a proficient B&W printer but I'm a bit fed-up
> with
> > > this "ink system".
> > > Sorry if it's a bit long.
> > > Thanks
> > [Non-text portions of this message have been removed]
