Piezo software -- switching to MIS FS inks
2002-05-10 by sdsmith9999
I've been gradually making the switch from analog to digital
printing, and have had fine results with Piezo software and Cone
inks -- except for the endless clogging and the price.
So I'm testing MIS FS inks ("refilled" virgin carts) with my 1160.  I
get good tonal results using the Woolf workflow, but the dots are too
visible in the high end.
Using the piezo software I get blotched, muddy prints (these are
files that printed beautifully with Cone inks). Fiddling with gamma
doesn't help.
Any suggestions appreciated!
Stephen Smith
Re: Piezo software -- switching to MIS FS inks
2002-05-10 by jrandall1149
Stephan:
You could try the 1160 partitioned RGB workflow for the MIS FS inkset.
It's posted here at
Files> Ink Sets reviews and techniques> MIS FS> 1160 Partitioned
Workflow.
or on the MIS ( www.inksupply.com )Quad workflow pages
The partitioned workflow should yield dot free light tones from 0% to
about 30% (where the medium gray ink kicks in).  It also often
eliminates the banding that some folks report with the Woolf lumped
RGB workflow in the dark end.
Thanks.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "sdsmith9999"
I
too
> doesn't help.
> Stephen Smith
Re: [Digital BW] Piezo software -- switching to MIS FS inks
2002-05-11 by Thom McGraw
I get good results with one of Paul Roark's curves
(meant for the VM inks) with FS inks.  Also, Jeff
Randall has a curve for FS inks you might want to try.
I, however, have not had good results with this
workflow - but I certainly could be doing something
wrong.
Thom
> with my 1160.  I
> the dots are too
> Stephen Smith
2002-05-16 by Stephen Jennings
I get great results with the Piezo software and the MIS FS inks on my 1160.
Have you tried a slight curves adjustment in Photoshop?  I generally adjust
my curve from 30 to 20 on one end, and 70 to 80 on the other.  Your mileage
may vary.  When I want it snappier I use the Woolf workflow.  Haven't
noticed the dots.
STEPHEN    JENNINGS
    P h o t o g r a p h e r
       Cambridge, MA
sgjennin@...
> doesn't help.
> Stephen Smith
