Re: [Digital BW] Flatbed scanners with film adaptors - good, bad, or ugly?
2002-07-08 by Kip Babington
I have the 2450 and have not been pleased with the results the few times
I've tried to scan 35mm black and white negatives.  The occasional black
and white prints I've scanned have turned into very nice digital files,
but the film scans have been soft and mushy compared to the scans from
prints.  This is based on only a few scans of each type, and from one
with very little scanning experience in general, so take it FWIW.
Kip
steve1t wrote, in part:
> Group,
> <snip>
> Does anyone have experience with these or similar scanners?  How do
> they compare with dedicated film or drum scanners?  Are they close
> quality wise, or is this too good to be true?
2002-07-08 by Truman Prevatt
I've been considering the same thing. If you want to maintain 300 DPI in
your print, then the 2400 DPI only will support a max 8 inches on the
short side of a 35 mm negative when you print. If you want to crop, then
less. With a medium format or 4x5 you have a lot more latitude. So I am
not sure these scanners will do a good job with 35 mm. On the other hand
35 mm film scanners are not that expensive compared to the those that do
medium format.
I've read some reviews of the 2450 which indicate for medium format this
scanner does a pretty good job.
Truman
steve1t wrote:
> Group,
> A dedicated film scanner would be great to have, but is beyond my
> needs and means.
> While shopping for a new flatbed scanner, I came across two that
> feature built in film adaptors capable of scanning any film or
> transparency - up to 4x5" for the Canon D2400UF CanoScan and up
> to 6x9" for the Epson Perfection 2450 Photo Scanner.  Both feature
> 2400x4800 dpi 48 bit scans, street price around $400.
> As for my personal requirements, I'm an amateur photographer with
> 35mm, 6x6, and 4x5 negatives and transparencies.  No pro or fine art
> print sales here, but, I do appreciate fine prints, both color and
> b&w and seldom print larger than 11x14.  All my new photos are with
> a 4 mega pixel Canon G2, RAW file format post processed - I'm
> pleased with the results.
> Thanks for any input.
> stephentucker@...
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/M=229717.2188776.3634751.1473480/D=egroupweb/S=1705019182:HM/A=1148134/R=0/*http://promo.yahoo.com/yphotos/giftsale/index.html>
> Please visit the Group Homepage to check the Files, Bookmarks, Polls
> and other resources as they are often being updated. The page is at:
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> "flames."
> - Before posting a question, search the message archives and the
> various resources on the homepage.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
2002-07-08 by Godfrey DiGiorgi
I've been working with the Epson 2450 since last December. It has enough
resolution to do a good job with 35mm or even smaller work. A dedicated
film scanner is better, certainly, but I have printed even Minox format
work scanned with it at modest sizes with good results. This image,
scanned with the Epson, is made with a Tessina camera (negative size
14x21mm):
<http://www.bayarea.net/~ramarren/photostuff/tess0201/pages/Plumbing.htm>
and prints to a very acceptable 7x10" image at 200dpi. Of course, medium
format makes a far superior print ... a 645 negative scanned at 2400 ppi
will give you a 13x19" print at 300dpi.
A couple of resolution examples of the 2450 can be obtained at the
following two links.
medium format, b&w and color neg:
<http://groups.yahoo.com/group/SeePhoto/files/Godfrey/scaneg/epson2450resolution.
htm>
35mm transparency, minolta scan dual II and epson 2450:
<http://groups.yahoo.com/group/SeePhoto/files/Godfrey/scaneg/reztest.htm>
It's an excellent scanner for the money. I could not say how it compares
with the Canon in detail but I'm satisfied enough to have no real need
to find out for myself.
Godfrey
ramarren@...
http://www.bayarea.net/~ramarren/photostuff/PAW2/
> medium format.
> Truman
> steve1t wrote:
>> Group,
>> needs and means.
>> stephentucker@...
2002-07-08 by Harry B
My own experience with a flat bed scanner is positive.
I am using an Acer Prism 620UT. The software allows me to scan at up to 19200 dpi and custom settings. I am able to scale the negatives to 3200% or custom. The scans come out sharp and with proper settings look very good printed at about 11x14 on my Epson 1270 w/ MIS inks through PS and PWPro.
Two things to note. First, I use the procedure primarily to create negatives for the gum bichromate process. Second, most 35mm negatives begin to show grain and softness at a high percentage of enlargement in a traditional enlarger process. If it's acutance you want to see in a print at great enlargement then you'd be better off with a larger negative to start.
Harry Bonham
Lightspeed Images
Eugene, Oregon
2002-07-08 by William Cobb
Er ... isn't the Epson 2450 42 bit device rather than 48?
  Sent: Monday, July 08, 2002 8:30 AM
  Subject: [Digital BW] Flatbed scanners with film adaptors - good, bad, or ugly?
  Group,
  needs and means.
  stephentucker@...
              ADVERTISEMENT
  - Good manners are required at all time. No personal attacks or "flames."
2002-07-08 by CDTobie@aol.com
In a message dated 7/8/02 9:31:14 AM, stephentucker@... writes:
11x14 from a 2400 dpi adaptor is pushing it from 35mm, but would be very
reasonable from larger film. The Dmax and detail won't be the same as an
expensive scanner, but may suit many of your needs.
C. David Tobie
Design Cooperative
CDTobie@...
From the Epson spec sheet...
Specifications Epson Perfection 2450 Photo
Scanner Type:Flatbed color image scanner
Photoelectric Device:Color MatrixCCDЄ line sensor
Maximum Scan Area: 8.5" x 11.7" (216mm x 297mm)
Hardware Resolution: 2400 x 4800 dpi maximum with Micro Step DriveЄ
technology
Color Depth: 48-bit internal/48-bit external
Grayscale Depth: 16-bit internal/16-bit external
Optical Density: 3.3 Dmax
Interface: USB 2.0 and FireWire (IEEE 1394)
Scanning Speed (2400 dpi, draft mode):
   256 gray l evel 3.8 msec/line (approx.)
   Full color  11.0 msec/line (approx.)
Reliability: 30000 cycles MCBF
Godfrey
2002-07-08 by Jerry Olson
Rarely will any flatbed give great results with 35mm film.  The canon
probably has the better lenses of most affordable flatbed scanners.  If
you don't go beyond 8x12 you can ge by with the canon flatbed. It will
be great for the larger sizes. I would prefer canon over epson for ANY
scanner, and Epson over Canon for ANY printer.
jerry
steve1t wrote:
> Group,
> needs and means.
> a 4 mega pixel Canon G2, RAW file format post processed \ufffd I'm
> stephentucker@...
I strongly recommend you actually scan a typical slide/negative with the
brand of scanner you are going to buy before you buy it. I personally
have never seen a really crisp, sharp scan from any epson scanner,
especially with smaller negatives. But they do fine with the larger
negs, especially the 4x5. I don't think epson optics are in the same
league as canons.
Try before you buy, anyhoo.
Jer
>   ----- Original Message -----
>   From: steve1t
>   Group,
>   needs and means.
>   stephentucker@...
>               ADVERTISEMENT
Did you look at the Minolta SDII and Epson 2450 slide scan package I
posted a URL to earlier? While there's definitely a good gain with the
Minolta, the Epson does quite well.
Godfrey
> league as canons.
2002-07-09 by Godfrey DiGiorgi
It takes some learning to get top quality scans out of the 2450,
particularly with small formats. I feel like I'm getting pretty good at
it. For 35mm and smaller, I shim the negative carriers as I find I get
better sharpness with the negs raised just a little higher off the glass
than the stock carrier provides. For medium format, the stock carrier is
fine, and it seemed pretty good for transparencies on my test.
I also scan with VueScan exclusively now, I don't use any of the Epson
software at all. That takes a bit of learning in itself, particularly
for B&W work. Once you get it, though, the results are superb.
Godfrey
