Re: [Digital BW] Cleaning Nomorecarts CIS tubes
2002-07-09 by Bernhard.Schuerlein@t-online.de
From: "k2_chittin" <k2chittin@...> > MIS VM with a new set of carts. Having washed out the old ink with > warm water, I'm unable to get the "black" tube completely clean. Has > anyone who has done something similar been able to completely clean > their tubes? This is funny, because after some 3 weeks of no printing my black cart tube was permanently clogged and I had to get replacement from MIS. The clolour ink tubes were fine however... greetings Bernhard
2002-07-09 by azshtr
--- In DigitalBlackandWhiteThePrint@y..., Bernhard.Schuerlein@t... wrote: > ----- Original Message ----- > From: "k2_chittin" <k2chittin@l...> > > > MIS VM with a new set of carts. Having washed out the old ink with > > warm water, I'm unable to get the "black" tube completely clean. Has > > anyone who has done something similar been able to completely clean > > their tubes? > > This is funny, because after some 3 weeks of no printing my black cart tube > was permanently clogged and I had to get replacement from MIS. The clolour > ink tubes were fine however... > > greetings Bernhard Ditto... after not using my system for a while the nozzle check showed no black. After much cleaning and trouble shooting it turned out the Black line was hardened, completly dry inside in places. Dave
2002-07-09 by Paul Roark
Using old CIS's that had been sitting around for a while totally killed the head of my 1160. I'm not sure what the exact cause of the problem was, but I suspect something is drying out in those systems when they are sitting around unused. (One thread here seemed to indicate that the tubes allow some air to seep through. I would think that dried ink around the outlets might also be a source of problems.) While the ink that caused my problem was Generations, I suspect all pigmented ink would cause the same problem. In fact, I suspect that the VM/FS black and all the old Piezo inks would be the worst due to the more volatile co-solvent base that is used in those inks. (But that co-solvent is probably one of the reasons the VM/FS and PiezoBW blacks -- not the new PT K -- were the best all-pigment blacks I've tested.) At any rate, I'd be reluctant to use a CIS that had been lying around unused for too long. Replacing the head of my 1160 was not cheap. Paul http://www.PaulRoark.com _________________________
Sent: Tuesday, July 09, 2002 11:46 AM
Subject: Re: [Digital BW] Cleaning Nomorecarts CIS tubes
ink with
clean. Has
completely clean
> > their tubes?
black cart tube
MIS. The clolour
> greetings Bernhard
places.
Dave
Yahoo! Groups Sponsor
ADVERTISEMENT
them short.
- Good manners are required at all time. No personal attacks or
"flames."
resources on the homepage.
[Non-text portions of this message have been removed]2002-07-10 by Martin Wesley
I had the same experience as Tom. I cleaned out my 14 month old 1200 CIS to reuse the lines and arms for a 1280 and the PiezoTone inks. The CIS had been out of the printer sitting idle for 9 months and the lines were pretty sludged up especially close to the cartridge end. Some work with warm running water, a syringe and compressed air cleaned everything up except for some staining of the plastic tubing which does not seem to be signigificant. If things are really hardened perhaps a soaking in water or soap and water would loosen it up. The tubing did seem a bit more rigid than a new CIS I bought recently and I suspect that the plastic of the lines may be hardening with time and exposure to the ink solvents. I should probably replace this portion of the CIS in 6 months or so. Martin Wesley http://www.borderless-photos.de/guests.html ----- Original Message ----- From: "Thomas Keesling" <tom.keesling@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Tuesday, July 09, 2002 8:13 PM Subject: [Digital BW] Cleaning Nomorecarts CIS tubes > K2, > > I encountered a similar situation when I switched from the ill-fated Cone > archival color inks to the MIS VM inks. The tubing was permanently stained > with the various colors, but didn't present any sort of problem when I > loaded the VM inks. > > I recently needed to replace the carts again and as a precaution installed a > new support arm and tubing. When I removed the old tubing, I immediately > flushed the tubing with water. It still has the color staining from the > original inks and shows no signs of clogging from the VM inks. It's in great
> shape still and ready to use again. > > Tom Keesling > Intelligent Design, Inc.
2002-07-10 by sm7bxd
Hallo, I have posted in this issue before! My own name for it "the master black devil clog"! This is not only a MIS issue - got letters from others having the same problems! I'm that type of person that I might do photographing for let's say three weeks, scanning for four days - printing for 4-5 days, in cycles. And that cycle may vary - depending of many a thing! I have three CFS's - 1290 (1280's)(dye color, pigment color and a QUAD- systems that vary - and the my black tubes is clogged completely now and then. As beeing aware of it - I take the following measures: Rip of the black-tube. When printer not in use losen it from the black cart and plugs it with a 6 mm tube that is melt glued in the end. Rise the black tube to emty it into the bottle - and plug the tube as well with a meltglued inlet-knee that is sold from MIS. When to use the printer - - the plug from the cart is taken away - the ordinary tube is put back *when* I have filled the tube with ink, by carefully pressing the black bottle until the black tube is filled (put some absorbic paper on the black cart to soak some drops of black ink!) A drip of isopropanol now and then on the parkingpad is liked by the printers!<smile> Keeps the nozzels fit! The "dye-ink" - printer does not seems to have the same issue - howeve I must clean this by printing some color-purging prints now and then to keep it fit for imediate use - otherwise this one also clogs in the nozzels! Why this - because - the tubes are as well absorbic to air as well as pearmeable for fluids. I destroyed one printer - if not doing this - the black "fat grease" end up in the black cart - whatever you do. I have investigated the tubes from CIS and MIS and they are about the same cheap stuff. There are other things - just now I have one "black" Tygon SE 200 for test taped on to the tubeset - and it works flowlessly so far. But I got one user mailing me when this issue was up last time - and he told me that he used the same TYGON SE 200 (a tube with inert of teflon) and the innert cracked. Not mine so far! I have had this up with MIS directly and inderectly with the CIS deliverants and both simular cheap tubings! Nothing done so far! I'm not alone -got plenty of E-Mails last time it happend and this issue was up! ( You can start reading here - taken from the middle when this issue was up last time! http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/146 15 ) This should be solved by the companies delivering the systems - as they are aware of it! I have mailed the deliverants - and they did ask me not to "blow this up". *Now* I got enought! However - they have now been given proper time to "fix it" - but they don't seems to care! I did - as you can see do some investigations as the engineer I am - however - time and job ended this! If somone want's to cooperate I might take it up again. But there are costs (tubes and fright) and time involved - buying mounting , fill tubes and plug them, and put them in heat (40 degres celcius) and then measure the weight on in milligrams over the time - and make carefull notes. Also testing and modifying holders are involved as the bending stiffnes are different. Cut out from earlier post: This is what is used - the cheapest there are: Look for Tygon® Vacuum Tubing : Formulation R-3603 http://www.tygon.com/new/europe/english/en_europe_index.html Look into the PDF - and you see it's waterpermeble. (Think for youself what happens when you get other chemicals in it!) What we have stated 1/ Low pressure 2/ Low flow or slow flow 3/ The Specific area of the tubes are very big that is: the tubes must not absorbatic or permeatic. This is 1,2 and 3 - Fluid stays relatively long time in the tube The risk of both absorbation of outer air and parmation and thereby evaporation on the tubes surface are to be stopped. What is good: a/ that the "transporting area" is very good. b/ That friction agains the tubes walls are NOT a big issue(slow flow)! c/ Pressure compared to the pressure that ALL tubes of Tygon is of no interest here - We have a very low pressure - next to none here compared to what the tubes they sell have! d/All other tubes now examened has better/same fattigue strenge. The flexibility of the of the tubes are important - and they stated that the hardnes meassured in Shore does in whole (some correlation here but it could also be the opposit) has not to do with the bending stress or bending elasticy force. All othe tubes now examened has better fattigue strenge. The HOT one just now is the inert tube that You can see here: Look for: Tygon® Inert Tubing Formulation SE-200 http://www.tygon.com/new/europe/english/en_europe_index.html The gay that reported of the "cracked" inerts in this tubes - seems to have vanished??? Are You there - *please* mail me! But - again - It's not our job to get "nice" tubes - it's up to the deliverants of this systems - not??? Fiat Lux! (Let There be Light!) Bo Wrangborg Moderator "Multi Pro" at Yahoo M.Sc. Engineer But in soul born to Photographing and Drawing! --- In DigitalBlackandWhiteThePrint@y..., "Paul Roark" <paul.roark@v...> wrote: > Using old CIS's that had been sitting around for a while totally killed the > head of my 1160. I'm not sure what the exact cause of the problem was, but > I suspect something is drying out in those systems when they are sitting > around unused. (One thread here seemed to indicate that the tubes allow > some air to seep through. I would think that dried ink around the outlets > might also be a source of problems.) > > While the ink that caused my problem was Generations, I suspect all > pigmented ink would cause the same problem. In fact, I suspect that the > VM/FS black and all the old Piezo inks would be the worst due to the more > volatile co-solvent base that is used in those inks. (But that co- solvent > is probably one of the reasons the VM/FS and PiezoBW blacks -- not the new > PT K -- were the best all-pigment blacks I've tested.) > > At any rate, I'd be reluctant to use a CIS that had been lying around unused > for too long. Replacing the head of my 1160 was not cheap. > > Paul > http://www.PaulRoark.com > > > _________________________ > -----Original Message----- > From: azshtr [mailto:dave@t...] > Sent: Tuesday, July 09, 2002 11:46 AM > To: DigitalBlackandWhiteThePrint@y... > Subject: Re: [Digital BW] Cleaning Nomorecarts CIS tubes > > > --- In DigitalBlackandWhiteThePrint@y..., > Bernhard.Schuerlein@t... wrote: > > ----- Original Message ----- > > From: "k2_chittin" <k2chittin@l...> > > > > > MIS VM with a new set of carts. Having washed out the old > ink with > > > warm water, I'm unable to get the "black" tube completely > clean. Has > > > anyone who has done something similar been able to > completely clean > > > their tubes? > > > > This is funny, because after some 3 weeks of no printing my > black cart tube > > was permanently clogged and I had to get replacement from > MIS. The clolour > > ink tubes were fine however... > > > > greetings Bernhard > > Ditto... after not using my system for a while the nozzle check > showed no black. After much cleaning and trouble shooting it > turned out the Black line was hardened, completly dry inside in > places. > > Dave > > > Yahoo! Groups Sponsor > ADVERTISEMENT > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and > other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep > them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or > "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various > resources on the homepage. > > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2002-07-10 by k2_chittin
Martin and Tom It's nice to know that the staining won't affect the colour balance of new inks. I spend a lot of time on the road and my printer may go unused for several weeks at a time. Once, I was away for 5 months. Upon my return, I fired up my printer and got a perfect nozzle check. I was lucky I guess. Bearing in mind tales of blocked lines from Paul and others, I shouldn't tempt fate. Luckily, here in the UK, 1160s have not been discontinued. K2 --- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley" <mwesley250@e...> wrote: > I had the same experience as Tom. I cleaned out my 14 month old 1200 CIS to > reuse the lines and arms for a 1280 and the PiezoTone inks. The CIS had been > out of the printer sitting idle for 9 months and the lines were pretty > sludged up especially close to the cartridge end. Some work with warm > running water, a syringe and compressed air cleaned everything up except for > some staining of the plastic tubing which does not seem to be signigificant. > If things are really hardened perhaps a soaking in water or soap and water > would loosen it up. > > The tubing did seem a bit more rigid than a new CIS I bought recently and I > suspect that the plastic of the lines may be hardening with time and > exposure to the ink solvents. I should probably replace this portion of the
> CIS in 6 months or so. > > Martin Wesley > http://www.borderless-photos.de/guests.html
Hallo again, A question! Those with new printers like 9000 Epson series - if you look very close to the tubes - it's very tiny, and hard to find. Can You see any "type number" or brand on them! If on those printers they must be good - however bending flexibility might be different - and the main last support may be modified. Simple done with a thin plate of aluminium that is cut out and bended, and fixed to hold the tubeset free! Made three CFS's myself - the weak link is the tubes! Cheap things! both on MIS and CIS version of CFS-systems! (I know what it is! Water permeable and used for short term in hospitals and universities!) For those interested have a look here! Alcohol at least seems to be one ingredient: http://www.tygon.com/new/europe/english/europe_chem/chemahead.html Fiat Lux! Bo Moderator "Minolta Multi Pro" at Yahoo --- In DigitalBlackandWhiteThePrint@y..., "sm7bxd" <sm7bxd@y...> wrote: > > > > > Hallo, > > I have posted in this issue before! > > My own name for it "the master black devil clog"! > > This is not only a MIS issue - got letters from others having the > same problems! > > > I'm that type of person that I might do photographing for let's say > three weeks, scanning for four days - printing for 4-5 days, in > cycles. And that cycle may vary - depending of many a thing! > > I have three CFS's - 1290 (1280's)(dye color, pigment color and a > QUAD- systems that vary - and the my black tubes is clogged > completely now and then. As beeing aware of it - I take the following > measures: > > Rip of the black-tube. > > When printer not in use losen it from the black cart and plugs it > with a 6 mm tube that is melt glued in the end. > Rise the black tube to emty it into the bottle - and plug the tube as > well with a meltglued inlet-knee that is sold from MIS. > > When to use the printer - - the plug from the cart is taken away - > the ordinary tube is put back *when* I have filled the tube with ink, > by carefully pressing the black bottle until the black tube is filled > (put some absorbic paper on the black cart to soak some drops of > black ink!) > A drip of isopropanol now and then on the parkingpad is liked by the > printers!<smile> Keeps the nozzels fit! > > > The "dye-ink" - printer does not seems to have the same issue - howeve > I must clean this by printing some color-purging prints now and then > to keep it fit for imediate use - otherwise this one also clogs in > the nozzels! > > Why this - because - the tubes are as well absorbic to air as well as > pearmeable for fluids. I destroyed one printer - if not doing this - > the black "fat grease" end up in the black cart - whatever you do. > > I have investigated the tubes from CIS and MIS and they are about the > same cheap stuff. There are other things - just now I have > one "black" Tygon SE 200 for test taped on to the tubeset - and it > works flowlessly so far. But I got one user mailing me when this > issue was up last time - and he told me that he used the same TYGON > SE 200 (a tube with inert of teflon) and the innert cracked. > Not mine so far! > > I have had this up with MIS directly and inderectly with the CIS > deliverants and both simular cheap tubings! > > Nothing done so far! > > I'm not alone -got plenty of E-Mails last time it happend and this > issue was up! > > ( You can start reading here - taken from the middle when this issue > was up last time! > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/146 > 15 ) > > This should be solved by the companies delivering the systems - as > they are aware of it! > > I have mailed the deliverants - and they did ask me not to "blow > this up". > > *Now* I got enought! > > However - they have now been given proper time to "fix it" - but > they don't seems to care! > > I did - as you can see do some investigations as the engineer I am - > however - time and job ended this! > > If somone want's to cooperate I might take it up again. But there are > costs (tubes and fright) and time involved - buying mounting , fill > tubes and plug them, > and put them in heat (40 degres celcius) and then measure the weight > on in milligrams over the time - and make carefull notes. Also > testing and modifying holders are involved as the bending stiffnes > are different. > > Cut out from earlier post: > > This is what is used - the cheapest there are: > Look for Tygon® Vacuum Tubing : Formulation R-3603 > > http://www.tygon.com/new/europe/english/en_europe_index.html > Look into the PDF - and you see it's waterpermeble. (Think for > youself what happens when you get other chemicals in it!) > > What we have stated > 1/ Low pressure > 2/ Low flow or slow flow > 3/ The Specific area of the tubes are very big that is: > the tubes must not absorbatic or permeatic. > This is 1,2 and 3 - Fluid stays relatively long time in the tube > The risk of both absorbation of outer air and parmation and thereby > evaporation on the tubes surface are to be stopped. > What is good: > a/ that the "transporting area" is very good. > b/ That friction agains the tubes walls are NOT a big issue(slow > flow)! > c/ Pressure compared to the pressure that ALL tubes of Tygon is of no > interest here - We have a very low pressure - next to none here > compared to what the tubes they sell have! > d/All other tubes now examened has better/same fattigue strenge. > > The flexibility of the of the tubes are important - and they stated > that the hardnes meassured in Shore does in whole (some correlation > here but it could also be the opposit) has not to do with the bending > stress or bending elasticy force. > > All othe tubes now examened has better fattigue strenge. > > The HOT one just now is the inert tube that You can see here: > > Look for: Tygon® Inert Tubing Formulation SE-200 > http://www.tygon.com/new/europe/english/en_europe_index.html > > The gay that reported of the "cracked" inerts in this tubes - seems > to have vanished??? Are You there - *please* mail me! > > But - again - It's not our job to get "nice" tubes - it's up to the > deliverants of this systems - not??? > > > > > Fiat Lux! (Let There be Light!) > > Bo Wrangborg > Moderator "Multi Pro" at Yahoo > M.Sc. Engineer > But in soul born to Photographing and Drawing! > > > > > --- In DigitalBlackandWhiteThePrint@y..., "Paul Roark" > <paul.roark@v...> wrote: > > Using old CIS's that had been sitting around for a while totally > killed the > > head of my 1160. I'm not sure what the exact cause of the problem > was, but > > I suspect something is drying out in those systems when they are > sitting > > around unused. (One thread here seemed to indicate that the tubes > allow > > some air to seep through. I would think that dried ink around the > outlets > > might also be a source of problems.) > > > > While the ink that caused my problem was Generations, I suspect all > > pigmented ink would cause the same problem. In fact, I suspect > that the > > VM/FS black and all the old Piezo inks would be the worst due to > the more > > volatile co-solvent base that is used in those inks. (But that co- > solvent > > is probably one of the reasons the VM/FS and PiezoBW blacks -- not > the new > > PT K -- were the best all-pigment blacks I've tested.) > > > > At any rate, I'd be reluctant to use a CIS that had been lying > around unused > > for too long. Replacing the head of my 1160 was not cheap. > > > > Paul > > http://www.PaulRoark.com > > > > > > _________________________ > > -----Original Message----- > > From: azshtr [mailto:dave@t...] > > Sent: Tuesday, July 09, 2002 11:46 AM > > To: DigitalBlackandWhiteThePrint@y... > > Subject: Re: [Digital BW] Cleaning Nomorecarts CIS tubes > > > > > > --- In DigitalBlackandWhiteThePrint@y..., > > Bernhard.Schuerlein@t... wrote: > > > ----- Original Message ----- > > > From: "k2_chittin" <k2chittin@l...> > > > > > > > MIS VM with a new set of carts. Having washed out the old > > ink with > > > > warm water, I'm unable to get the "black" tube completely > > clean. Has > > > > anyone who has done something similar been able to > > completely clean > > > > their tubes? > > > > > > This is funny, because after some 3 weeks of no printing my > > black cart tube > > > was permanently clogged and I had to get replacement from > > MIS. The clolour > > > ink tubes were fine however... > > > > > > greetings Bernhard > > > > Ditto... after not using my system for a while the nozzle check > > showed no black. After much cleaning and trouble shooting it > > turned out the Black line was hardened, completly dry inside in > > places. > > > > Dave > > > > > > Yahoo! Groups Sponsor > > ADVERTISEMENT > > > > > > > > Please visit the Group Homepage to check the Files, Bookmarks, > Polls and > > other resources as they are often being updated. The page is at: > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > Please follow these basic guidelines: > > - Include your full name with your message. > > - Include the address of your website, if you have one. > > - As threads develop, trim off excess portions of earlier > messages to keep > > them short. > > - As the topic of a thread changes remember to change the subject > header. > > - Good manners are required at all time. No personal attacks or > > "flames." > > - Complete your Yahoo profile. > > - Before posting a question, search the message archives and the
> various > > resources on the homepage. > > > > > > > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > > [Non-text portions of this message have been removed]
2002-07-10 by Richard Sintchak
Does anyone know why www.inkjetart.com now brings you to Booneville Title Co.? And using their top level of www.tssphoto.com brings you to The Stock Solution page but if you try to go to anything involving inkjets you get Boonville Title again! I emailed them to ask but does anyone know what's up? Best regards, Richard mailto:richard@...
2002-07-10 by Jerry Olson
Pure ammonia should do it. Flush with water afterwards. Jerry k2_chittin wrote:
> > I'm switching a used CIS over from Enhanced Generations 4 colour to > MIS VM with a new set of carts. Having washed out the old ink with > warm water, I'm unable to get the "black" tube completely clean. Has > anyone who has done something similar been able to completely clean > their tubes? > > K2 > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or "flames." > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage. > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Hallo, when I had it "the devils clog of tubes" - I pressed the tube between my forefinger and thumb and pulled the tubes several times, all along, untill all "old motor grease" was gone. Then I just forced water through the tube, until it was clean! Rubber gloves - recomended -indeed! Dip the thumb and forefinger in some of your wifes "body-grease" or somthing she uses to make the scin extrasoft for you! (*Please* before you do the trick <smile>...) It's not that fun to stay in the same room as the ammonia! And it's not that fun having a wife looking like a zebra - with MIS double-black-4K all over - but ok, if you switch of the light! Fiat Lux! Bo Wrangborg --- In DigitalBlackandWhiteThePrint@y..., Jerry Olson <jerryolson@r...> wrote: > Pure ammonia should do it. Flush with water afterwards. > > Jerry > > k2_chittin wrote: > > > > I'm switching a used CIS over from Enhanced Generations 4 colour to > > MIS VM with a new set of carts. Having washed out the old ink with > > warm water, I'm unable to get the "black" tube completely clean. Has > > anyone who has done something similar been able to completely clean > > their tubes? > > > > K2 > > > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > Please follow these basic guidelines: > > - Include your full name with your message. > > - Include the address of your website, if you have one. > > - As threads develop, trim off excess portions of earlier messages to keep them short. > > - As the topic of a thread changes remember to change the subject header. > > - Good manners are required at all time. No personal attacks or "flames." > > - Complete your Yahoo profile. > > - Before posting a question, search the message archives and the various resources on the homepage. > > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
