Bill,
have you saved the thickness of your PhotoRag as one of the paper pre-sets?
Unless it's the thin one, it will be radically heavier than EAM and could be a
cause for misalignment of sorts.
I've heard of issues with high temp/humidity, and I wonder if you have tested
specifically for that (i.e. tested if a/c makes a difference).
And, you are sure, air in the lines is not a possibility?
Is it always the same ink?
Have you tried the heavier "mainenance" cleanings?
For lots and lots of info specific to the 7000, got to the Epson 9000 list:
http://groups.yahoo.com/group/Epson9000/
Hope it goes away! (like mine did with the Piezotones).
Antonis
--- In DigitalBlackandWhiteThePrint@y..., Bill Giffen <wagge@s...> wrote:
> I have tried to find info on banding problems that I am having but have not
> been successful. I have a 7000 with MIS FS inks and imageprint rip. I just
> starting getting these using current setup. Today did a print on photorag
> and had banding, did to cleaning cycles and used EAM and looked good.
Went
> back to photorag and back came the bands. They are very slight but I can
see
> them. At 8x it looks as if one of the inks is not squirting. These are
> horizontal bands. My studio is 90deg plus with high humidity ( only use ac
> when I am working)so that might be a cause.? Thanks for any help.
> Bill Giffen
