[Digital BW] Quad vs. 2200--Imageprint Revisited
2002-12-13 by Paul Roark
Robert,
Thanks for the information.
One thing I've been curious about is whether the UC light black helps make
for smoother transitions, relative to the quads we've been using, as the
black ink is introduced.
Having received the MIS UC clone black inks, and assuming the designers of
those got their densities right, I was interested to find that the light
black density is essentially the same as the cyan (dark gray ink) density of
the PiezoBW and MIS FS/VM systems. So, in terms of ultimate performance,
the UC ink systems are not likely to have any shadow tone advantage to our
usual quadtone inksets.
>Epson 2200 (Ultrachrome with Matte Black):
> Dots are visible from the light gray ink in the highlights and also
>around 80% when the black ink enters.
Even with the 2200 small dot size, it looks like more than one gray ink is
needed. The RIP must really try to hold the color inks down to a bare
minimum. Do they use any color inks in the highlights at all?
>Unfortunately, unlike the photo black ultrachrome ink, which is
>much warmer, the matte black ultrachrome ink is so cool that
>without adding yellow you can't warm up the print.
Actually, I think it is the light black that must be relatively cool. The
Epson Matte Black ink I pulled from a 7600 cart is very warm. The quad I
made from the inks are more like a totally warmed, old MIS quad.
>The yellow has a metamerism problem, so
>IP does not use it. ...
Interestingly, the MIS UC clone ink tones and characteristics appear to be
reversed from the Epson product. The MIS Matte Black is neutral, but the
MIS Light Black is carbon warm. The MIS Matte Black is weak on EAM but
strong on LPM. With the MIS UC clone ink tones, it would allow the UC
printers with appropriate RIPs to cover a larger tone range while still
avoiding the use of the yellow ink.
>Epson 2200 (inks as described above)
>Tintpicker (0/0)--Cool
>Dmax 1.71 (1.75)
Cyan Magenta Yellow Visual
>25% 0.28 0.30 0.28 0.29
>50% 0.57 0.61 0.60 0.60
>75% 1.03 1.08 1.06 1.06
This is actually a medium warm/magenta set of readings. Yellow is higher
than cyan. The 75% magenta reading is really high.
http://www.PaulRoark.com
