Well, I'm making the change, Piezotones to MIS... help!
2002-12-18 by treadwinkle <VOLveeta@bellsouth.net>
I'm running a 1280.  I've been using the Selenium carts, great
results, using the Piezo plug in, but the cost is killing me.  I
ordered a CIS with MIS Full Spectrum Neutral w/generations black.
Any up front pointers?  Will I see similar results with the plug-in
or should I learn this curves stuff? :-)
Thanks for any info!!!
Treadwinkle
Re: Well, I'm making the change, Piezotones to MIS... help!
2002-12-18 by Jeff Randall <jrandall@ch2m.com>
The hextone MIS FS-N inkset (which really is a quadtone inkset where
C=Pc and M=Pm) will not work with the Epson driver.  The Epson driver
expects lighter shades of Pc and Pm.  MIS sells the FS-E inkset that
works with the Epson driver.  You can use the Woolf lumped (non-
partitioned)workflow or can try the 1270 RGB Partitioned workflow I
developed as a starting point (see Files|Ink Sets|MIS|MIS FS).
Good Luck.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "treadwinkle
> Treadwinkle
2002-12-18 by Shilesh Jani <shilesh.jani@smith-nephew.
Treadwinkle (what a great name!),
If you are using the Piezo driver, the MIS FS-N inks should work
seamlessly, or alomst so.  You need to worry about FS-E inks (or
other workflows) only if you plan to use the Epson driver.  Make sure
the inks are in the right positions for the driver of your choice.
Good luck.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jeff Randall
where
driver
that
> Good Luck.
> Jeff Randall
black.
in
> > Treadwinkle
Egggggggzellent!  Thanks a ton, I can't wait to give these inks a
whirl!
Treadwinkle
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani
sure
> Good luck.
> Shilesh
> where
> driver
> that
workflow I
> > Good Luck.
> > Jeff Randall
> > --- In
I
> black.
plug-
> in
> > > Treadwinkle
2002-12-20 by glewis4457@aol.com
In a message dated 12/19/2002 3:54:30 AM Central Standard Time,
DigitalBlackandWhiteThePrint@yahoogroups.com writes:
>  From: "treadwinkle <VOLveeta@...>" <VOLveeta@...>
> Subject: Well, I'm making the change, Piezotones to MIS... help!
> Treadwinkle
I am in a similar situation...I think.  I just ordered my new Epson 1280
($313 after the $100 Epson rebate).  Since it is new, it will never see color
carts.  I am dedicating it to B/W from the very start.  Now the question
is....what do I do next?  MIS inks, Piezotones?  Plugins?  Workflows?
I have just started to get, what I consider, quite nice B/W output from my
C80 using the "Russell Brown Tonal Conversion Technique"  using EEM  and
Epson Velvet Fine Art, but I want a bigger output.
<A HREF="http://www.russellbrown.com/tips/photoshop.html">http://www.russellbrown.com/tips/photoshop.html</A>
I don't know how this stacks up against others, but it works for me and makes
sense to me, unlike some others.  Maybe that is why it works for me.
Jerry in Houston
