Epson Stylus Color 900 + MIS Quadtone inks
2003-01-10 by photoglevee <oglevees@attbi.com>
I was just given a 'new' Epson Stylus Color 900 printer (two years
old but never used) at no cost.
I'm thinking of trying my hand at some B&W printing (files from a
new digital camera) and thought a low-cost experiment would be to
buy / install a set of MIS Quadtone inks (MIS has pre-filled
Quadtone cartidges for the 900).
Does anyone here have any experience with this Epson model ?  If so,
I'll take any suggestions on setup, paper recommendations, workflow,
etc.
Thanks in advance.
Scott
Re: [Digital BW] Epson Stylus Color 900 + MIS Quadtone inks
2003-01-10 by Sam A. McCandless
Good printer, Scott; I still miss mine. I never tried a quad tone
inkset in it. It coped well with a variety of papers. The
heaviest/thickest I remember using in it was Crane's 300 gsm uncoated
cover stock, which wasn't very useful due to the dot gain. If someone
gave me one (and I could find some place to put it!), I think I'd try
Lyson's Small Gamut Photonic inkset in it if Lyson supports that. But
I assume that would be a more expensive experiment. I think it would
make a good printer for one of the MIS VM inksets, but I don't think
anyone has developed the necessary (I guess) curves for it.
Incidentally, the 900 is, I believe, one of the few printers for
which Adobe's discontinued PressReady rip works.
Sam
Sam McCandless       samcc@...
>etc.
>Thanks in advance.
>Scott
Re: Epson Stylus Color 900 + MIS Quadtone inks
2003-01-10 by Clayton Jones <cj@cjcom.net>
Hello Scott,
>(two years old but never used) at no cost.
>from a new digital camera) and thought a low-cost experiment
>would be to buy / install a set of MIS Quadtone inks (MIS has
>pre-filled Quadtone cartidges for the 900).
>Does anyone here have any experience with this Epson model?
>If so, I'll take any suggestions on setup, paper
>recommendations, workflow, etc.
Welcome!  You've come to the right place.  I haven't used that model
but the articles at the link below have some good information for
anyone just getting started.
Clayton
2003-01-10 by Scott Oglevee <oglevees@attbi.com>
Clayton,
Thanks for the link !!  I've just skimmed the articles and have
already found the answers to several questions.  I'll spend time
over the weekend giving it a more complete read thru.
Thanks for all your efforts (you are certainly helping this
newbie !).
Scott.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones
<cj@c...>" <cj@c...> wrote:
> Hello Scott,
model
> Regards,
> Clayton
Sam,
Thanks for the reply.
MIS is only suppling the 'original' Quadtones in Epson 900
cartridges.  I'd like to try the VM inks but I'd need to go the
route of refilling virgin carts (I want to prove to myself that the
printer is capable of generating reasonable output before I go this
way).
It appears that the Lyson Small Gamut inks are also not available in
pre-filled Epson 900 carts.
Looks like if things prove out with the printer, I'm likely to get
my first chnace to dip my toes in the 'refill ink' pool.
Thanks again,
Scott.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Sam A.
uncoated
someone
try
But
would
think
> Sam
> Sam McCandless       samcc@v...
so,
workflow,
> >etc.
> >Thanks in advance.
> >Scott
2003-01-10 by Matt Haber
Scott--
filling virgin carts is a bit intimidating if you read about it, but it's actually
pretty easy in practice--and the additional investment compared to
buying filled carts is small (I did it for a 740, and found that re-filling is a
bit harder than filling virgins)
Matt
> Sam,
> way).
> Thanks again,
> Scott.
Matt Haber
dance, portrait and fashion photography
http://www.matthaber.com
Matt,
Thanks for the encouragement.
Scott.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Matt Haber"
<matt@m...> wrote:
> Scott--
but it's actually
re-filling is a
> Matt
> > Sam,
this
> > way).
available in
get
> > Thanks again,
> > Scott.
> Matt Haber
