Epson 2200 RIP fading at trailing edge
2003-04-18 by robert_ardinger
Hello all,
I have been reading the group for awhile and recently joined.  I
have a question I am puzzled over.
I am using the Epson 2200 printer, Matte black ink, PS7, WinXP home,
2.4 ghz, 1 gb ram. I have no problem using the Epson dirver for
color and have learned (from this group) a "workflow" that prints
very nice Black and White orints with only a hint of metamersim.  To
improve matters I bought the Epson Stylus 2200 RIP and after a few
false starts got it to produce very nice black and white images.
The only problem is that no matter what my settings, the trailing
edge (last out of the printer) has about a near 1/4 inch fade to it,
like the printer just slowly stopped using some of the ink.
you can see the problem at:
http://home.kc.rr.com/rardinger/fading.jpg
These are scans of parts of two pictures, one with the RIP the other
without.  (the one without does not look that magenta in person but
does shift to a slight magenta underdifferent light.
I have gone through the settings on the RIP and think it is close to
correct for a good B&W image but I cannot shake the fading off at
the end of the print. If I flip the image it happens to the other
side (the trailing edge that was once the leading edge).
Thanks in advance for the help.
Robert
Re: Epson 2200 RIP fading at trailing edge
2003-04-18 by Bill Strong
I had this exact same problem with the 2200 using IP 5.0 when
printing on
Hahnemuhle Photo Rag 13 X 19 inch paper. Apparently this particular
paper is sized
slightly smaller than what the 2200 thinks a 13 X 19 inch piece of
paper should be.
Try manually specifying a paper size 1/8 or 1/4 inch shorter in
length (or in both
dimensions) than the size your paper is supposed to be. This might
take care of the
problem.
Bill
--- In DigitalBlackandWhiteThePrint@yahoogroups.com,
"robert_ardinger"
<rardinger@k...> wrote:
> Hello all,
home,
To
it,
other
to
> Robert
2003-04-19 by robert_ardinger
I thnk I've got it.
My problem was that the trailing edge of the image was not being
printed well. After processing through the suggestions I received I
thought it might be some buffer/spool somewhere was not being large
enough. I searched and could not find how to change it. I thought
that probably it might be a common epson thing so in frustration
removed all my epson software and installed things back one at a
time with the RIP being second (after the 2200 driver) and it
worked. I put back my second printer (777) and the scanner (3200),
they worked and the RIP still worked. Right now I am a happy camper.
The B&W are the best I have done. I tried a dedicated ink system for
an older 870 epson and those were good, these are better.
Robert
> "robert_ardinger"
> > Hello all,
> home,
prints
> To
few
images.
trailing
> it,
> other
but
> to
at
other
> > Robert
Re: Epson 2200 RIP fading at trailing edge-solution?
2003-04-20 by robert_ardinger
Now have a more specific idea about this problem.  The issue appears
to be a conflict in the 2200 RIP and the epson driver/software for
my second, general printer, an Epson 777.
With a number of system restores and trial and error I find the
following:
If I never install the 777, all works.
If I install it (777, driver from Windows XP) but never print with
it, all works.
If I install it (the 777, and always after the 2200 driver (the
older version even though I downloaded it Friday) and then the 2200
RIP), use it but do not restart the computer the RIP still works
HOWEVER, if I then restart the computer after doint the above, the
RIP has the fading , trailing edge issue again (now easily tested
for by sending the printer a windows test page and seeing the last
lines fading off).
It appears the 777, once installed and used, rewrites somthing that
on restartup takes the place of somthing used by the RIP.
I then bagged the 777 and used a C42UX stolen from my son's room to
be the general printer and all works, all the time (so far).
I do like the output of the RIP but there are some asthetic
adjustments in the prints I would like to try.  This will be easier
with the silly thing working.
BTW does anyone using the RIP know how to have it keep the settings
(paper choice, DPI, etc.) or do I just need to reset these each time
I open the server?
Hope this invistigation helps someone who may have a similar problem
with the RIP (Windows XP Home, prints sent to the RIP server from
PS7 as standard PS files).
Robert
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "robert_ardinger"
> I thnk I've got it.
I
large
camper.
for
> Robert
> > "robert_ardinger"
> > > Hello all,
I
> > home,
for
> prints
metamersim.
> > To
> few
> images.
> trailing
to
> > it,
> > other
person
> but
close
> > to
> at
> other
> > > Robert
