RE: [Digital BW] How to replace printer heads??
2003-05-11 by DanielPérez
I hadn't planned on doing it myself.  I was looking
for advice on where I could get it done, price, etc.
or if it was even worth doing it for this printer.
thanks
--- Doug Fisher <dougfisher@...> wrote:
> These heads are not user replaceable as far as I
> know.  You need special
> alignment software.
> Doug
> From: Daniel P\ufffdrez [mailto:tronicart@...]
> Sent: Friday, May 09, 2003 3:34 PM
> To: Digital BW
> Subject: [Digital BW] How to replace printer heads??
> I've had a bad cyan/magenta overspray problem (
> http://www.tronicart.com/ink/spray.html )with my
> 1270
> for a while now and am ready to swap out the heads.
> What is the easiest and/or cheapest way to go about
> this?  (I'm no longer under warranty)
> Is it even cost effective?  Would I be better off
> buying a used 1270/1280 on Ebay or something? I've
> got
> a CIS w/ MIS pigs on the 1270   ..and a 1280 for
> b&w.
> btw.. flushing, swapping carts hasn't helped.
>  thanks in advance,
>         -daniel p\ufffdrez
> __________________________________
> Do you Yahoo!?
> The New Yahoo! Search - Faster. Easier. Bingo.
> http://search.yahoo.com
> Please visit the Group Homepage to check the Files,
> Bookmarks, Polls and
> other resources as they are often being updated. The
> page is at:
> If you wish to receive no emails or just a daily
> digest, or you wish to
> unsubscribe, please edit your Membership preferences
> by visiting this same
> page.
> - Include the address of your website, if you have
> one.
> - As threads develop, trim off excess portions of
> earlier messages to keep
> them short.
> - As the topic of a thread changes remember to
> change the subject header.
> - Good manners are required at all time. No personal
> attacks or
> &amp;amp;quot;flames.&amp;amp;quot;
> - Before posting a question, search the message
> archives and the various
> resources on the homepage.
> Your use of Yahoo! Groups is subject to
Do you Yahoo!?
Re: [Digital BW] How to replace printer heads??
2003-05-12 by Jeff Randall
Daniel:
Before you pay to have the printhead replaced, are you sure your
printhead is spotless clean, especially on the underside?  If there
is any buildup it can cause problems (think of a partially clogged
shower head spraying in several directions).  Check the archieves for
the "wet paper towel cleaning method". If all else fails AND you are
ready to have the printhead replaced, you can try the "cleaning
solution injection through the printhead" procedure.  Again check the
archives -- it can't hurt if it is the last resort.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@yahoogroups.com,
> thanks
> > alignment software.
> > Doug
> > From: Daniel Pérez [mailto:tronicart@y...]
> > To: Digital BW
> > 1270
> > got
> > b&w.
> >  thanks in advance,
> >         -daniel pérez
> > Do you Yahoo!?
> > page is at:
> > page.
> > one.
> > them short.
> > attacks or
> > &amp;amp;quot;flames.&;amp;amp;quot;
> Do you Yahoo!?
2003-05-13 by DanielPérez
Thanks for the help, I've tried both the wet paper
towel and direct injection.  I found some "authorized
Epson service centers" that do cleanings(overnight
soaking, direct injection, re-alignment, etc) and can
replace heads if necessary.  They charge $80 for
cleanings!  ..plus another hundred if you need a new
head.  I'll try it at least knowing I tried everything
I can on my own.
While I'm sure they can clean a head clogged with
dried up Epson inks, can they handle dried up
pigments?
  - Daniel
--- Jeff Randall <jrandall@...> wrote:
> Daniel:
> you sure your
> underside?  If there
> partially clogged
> the archieves for
> fails AND you are
> the "cleaning
>  Again check the
> Jeff Randall
> looking
> etc.
> > thanks
> > > alignment software.
> > > Doug
> > > From: Daniel P\ufffdrez [mailto:tronicart@y...]
> > > To: Digital BW
> heads??
> > > 1270
> heads.
> about
> off
Do you Yahoo!?
2003-05-14 by Harry Saddler
>I can on my own.
I put a new head in my 1200; ordered it from National Parts Depot (about
$80), put it in, then realized that I couldn't align it because I didn't
have the alignment software, which I couldn't find anywhere (except for
some Russian guy who wanted to sell me a copy of dubious provenance). So
I took the printer to an Epson repair facility, they couldn't get it to
work right either, ordered another & installed it, and it still had very
minor banding. So I sold it.
So: it's not hard to replace the head, but difficult to get it to work
right. I wish I'd taken it to the Epson place to begin with.
Harry Saddler | hsaddler@...
