Re: [Digital BW] What size to you print and matt to?
2003-07-23 by Jack M Kucy
Barry, It is a very personal decision. I exhibited my silver prints a few times (my next show will be completely digital prints). The rules are the same if it's a silver print, graphic, or digital print. It's got to look elegant and neat. It's got to complement the picture, not distract it or overwhelm it. I usually printed 11x14s with the image length about 12". The mat I used was 16x20 with the window slightly off center (shifted a few fractions to the top) with the distance to the edge of the image 5mm on 3 sides and 7-8mm on the bottom. It already gives you a bit of space to make a small caption. For 8x10s I usually also used 16x20 mat, but 11x14 is OK. If you cut mats yourself - be careful in the corners. If you order it - draw a sketch with clearly stated dimensions, because any mistake or irregularity will make you throw away the mat. If you have any questions - ask. Good luck, Jack _________________________________________________ Jack M Kucy JMK Gallery (www.jmk-gallery.com) 917-991-2096 jmk@... Member of ASMP (www.asmp.org) _________________________________________________ ...a riveder le stelle flyfishingusa2002 wrote:
> Hi All, > I am particually interested in what might be the size of print and > matt you might use? I know this is very subjective, but I want to > mattt some prints for resell, the print size being, say 8x10. Should > I make the matt a little larger for my signature and print name? How > big should I make the matt. I use a Canon digital camera and of > course the format does not match the 8x 10 format.Any suggestions? > > Thanks, > > Barry >
