1200 clogfs
1200 clogfs
2003-08-06 by Stephen Kobrin
I left my 1200 with MIS VM inks for 2 1/2 weeks and came back to
clogs that will not go away, even after 9-10 cleaning cycles and a
number of full prints.  (I use prefilled carts.)  While I know this
topic has been covered at length on the list, I would appreciate a
suggestion of a reasonable first step before I delve into the
archives and go at this full tilt.
The strange thing is that there is a great deal of variation in the
nozzle check patterns with some not all bad and other where several
of the inks are hardly there.
Thanks for any help.
Steve
Re: 1200 clogfs
2003-08-06 by Keith R.
Hi Stephen!
I also had a clog on my 1200, after I installed the ultra tones. I
use a CIS, by the way. Ans the fault it clogged was all mine. But I
went back thru the archives, and other forums, and found a very good
prcedure, buryed within the info at inkjetmall. The cleaning
procedure can be found at:
http://www.inkjetmall.com/store/cone_ts/index.html
Look at # 9: The clog from hell. I followed the instructions, as
countless others have, and in a couple of hours, I was getting
perfect nozzle checks.
Good luck!
KeithR
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin"
> Steve
Re: 1200 clogfs
Thanks Keith
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Keith R."
<kjrslr@e...> wrote:
> Hi Stephen!
good
> Good luck!
> KeithR
Kobrin"
a
this
a
several
> > Steve
