More Coating Questions
2003-08-09 by jmoore172002
I searched the archive and I could not track down answers to these
two print coating related questions:
1) Has anyone done any testing on the issue of whether or not coating
with a product such as Hydrocote Polyshield affects the archival
properties of Piezography carbon prints?
2) When coating Piezo prints with Hydrocote, after a good curing
period, can these prints be drymounted, i.e., Seal tissue and
drymount press?
RE: [Digital BW] More Coating Questions
2003-08-10 by Paul Roark
I've fade-tested coated v. non-coated prints.  I assume the MIS and Piezo
inks are about the same.  In general, the coated blacks faded a bit faster,
although I think that could well be due to the higher dmax raising the
temperature (by absorbing more light).  The black ink in the test was the
MIS VM-K (probably the same as PiezoBW K).  The 50% patches were generally
the same in terms of their fade rates.
There was one other situation that seemed to accelerate the coated print
fading.  I tested one group under very high humidity conditions.  (The test
light, etc. were right over a tray of water.)  The coated print did fade
faster.  The uncoated prints faded at essentially the same rate as the
low-humidity tests.  I speculate that the difference could be that the hot
light artificially dries the un-coated prints, whereas the coating traps the
water around the pigments.
In general, we've always been led to believe that high humidity accelerates
fading, but this has never shown up in my tests except for the coated
prints.  One of the criticisms of accelerated testing is that it
artificially dries the inks, with the result that the fade rate is reduced.
So, I have 2 test results that seem to favor un-coated prints.  I'm very
suspicious that both are more artifacts of the testing than predictors of
faster fading for PUR-coated prints.
>drymount press?
Yes, I've used Seal Colormount at 180 degrees f.  Be sure to use fresh
release paper and wait the full 7-day curing period.  Also, with trimming
the prints, a rotary trimmer might be a good idea.  I've noticed a bit of
edge roughness when trimming with a straight razor knife.
As an aside, one of the PUR experts told me that heat accelerates the
cross-linking and curing.  Heating the PUR soon after application might
actually make for stronger coating -- bringing the strength/extent of
cross-lining of the single-solution, water-borne products close to the
industrial products.  (The adhesion of a water-borne PUR will not, however,
match the solvent-based products.)  This heating information suggests that
the use of a hair-drier might not only speed the drying and curing, but also
result in a stronger coating.
http://www.PaulRoark.com
Re: [Digital BW] More Coating Questions
2003-08-10 by Robert Morrison
I haven't tested the hydrocote coated prints, but when I was testing a
variety of of different acrylic based coatings with piezo inks I found
that under dry south window testing the coating improved the fade by up
to 100%...so this is the opposite of Paul's results with the Hydrocote.
  Honestly I'm still a bit skeptical of the aliphatic polyurethanes
being as good for paper coating as the acrylics...but this is not based
on actual comparative testing...just my knowledge of the respective
chemistries.
Robert
> Piezo
> faster,
> the
> generally
> print
> test
> fade
> hot
> traps the
> accelerates
> reduced.
> very
> of
>> drymount press?
> trimming
> of
> however,
> that
> but also
> Paul
> Please visit the Group Homepage to check the Files, Bookmarks, Polls
> and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> - As the topic of a thread changes remember to change the subject
> header.
> - Good manners are required at all time. No personal attacks or flames
> - Before posting a question, search the message archives and the
> various resources on the homepage.
> Your use of Yahoo! Groups is subject to
Re: [Digital BW] More Coating Questions - And some answers
2003-08-10 by garethlock4472
Found this link yesterday of anyone if anyone is interested
http://www.livick.com/method/inkjet/pg1.htm
Not into coating myself but thought you lot might like a read
Gareth
 --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Robert Morrison
testing a
found
by up
Hydrocote.
based
> chemistries.
> Robert
coating
and
> > Piezo
bit
> > faster,
raising the
was
> > the
> > generally
coated
> > print
(The
> > test
did
> > fade
as the
that the
> > hot
coating
> > traps the
> > accelerates
coated
is
> > reduced.
I'm
> > very
predictors
> > of
> >> drymount press?
fresh
> > trimming
a bit
> > of
might
strength/extent of
to the
not,
> > however,
suggests
> > that
curing,
> > but also
> > Paul
Polls
at:
wish
visiting
> > this same page.
messages to
> > keep them short.
> > header.
flames
2003-08-10 by Steven Schaefer
Is the Clear Shield, Livick uses the Minwax floor product?
And has any one used this on there prints?
Steve
> Gareth
> testing a
> found
> by up
> Hydrocote.
> based
> > chemistries.
> > Robert
> coating
> and
> > > Piezo
> bit
> > > faster,
> raising the
> was
> > > the
> > > generally
> coated
> > > print
> (The
> > > test
> did
> > > fade
> as the
> that the
> > > hot
> coating
> > > traps the
> > > accelerates
> coated
> is
> > > reduced.
> I'm
> > > very
> predictors
> > > of
> > >> drymount press?
> fresh
> > > trimming
> a bit
> > > of
> the
> might
> strength/extent of
> to the
> not,
> > > however,
> suggests
> > > that
> curing,
> > > but also
> > > Paul
> Polls
> at:
> wish
> visiting
> > > this same page.
> messages to
> > > keep them short.
> > > header.
> flames
>                    Yahoo! Groups Sponsor
>                        ADVERTISEMENT
>                         [click here]
> this same page.
> keep them short.
> header.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
RE: [Digital BW] More Coating Questions - And some answers
Gareth,
Note that the test strips that show a positive effect from coating with UV
blocking sprays were in direct sun.
Sun has a lot of UV in it.  Glass filters out the shorter and most damaging
UV.  Acrylic filters out even more.  So, comparison of tests conducted in
direct sun will show much more effect from the UV filtering sprays than will
inside or fluorescent light tests.
For outside display, there seems little question that UV coatings are a very
good idea.  For inside display, I think there will be little difference
between coated and non-coated prints with respect to fading.  In my
fluorescent light testing I see little of no effect from most coatings.
I found that by the time I had the amount of UV coating that Golden (perhaps
the best supplier of acrylic coatings) recommended, the yellowing was
noticeable.  This might not be the case with all of these, but I decided,
given the lack of significant protective effects that I saw, that I'd be
better off just avoiding the UV absorbing additives.
Golden's technical person also noted that the solvent-based UV coatings are
much more effective than the water-borne UV coatings.
testing a
found
by up
Hydrocote.
based
> chemistries.
> Robert
coating
and
> > Piezo
bit
> > faster,
raising the
was
> > the
> > generally
coated
> > print
(The
> > test
did
> > fade
as the
that the
> > hot
coating
> > traps the
> > accelerates
coated
is
> > reduced.
I'm
> > very
predictors
> > of
> >> drymount press?
fresh
> > trimming
a bit
> > of
might
strength/extent of
to the
not,
> > however,
suggests
> > that
curing,
> > but also
> > Paul
Polls
at:
wish
visiting
> > this same page.
messages to
> > keep them short.
> > header.
flames
page.
them short.
No, but it is a polyacrylic with added light stabilizer made
specifically for coating signs.
http://www.clearstarcorp.com/clearshield.asp
It has a UV absorber in it...but I seriously doubt that's what making
it work well...its simply the polyacrylic protecting the pigments from
air.  I've used the clearshield before.  I find the Hydrocote easier to
work with, but with slight diluting it could be a good solution for rod
coating.  I think it could also be sprayed, likewise with diluting.  I
used the semi-gloss product, but my guess is that a mix of the matte
and semi-gloss would probably get us to the gloss level that we are
looking for.  The Clearshield is less toxic than the Hydrocote because
of the co-solvents that they use.
Robert
> Steve
>> Gareth
>> testing a
>> found
>> by up
>> Hydrocote.
>> based
>>> chemistries.
>>> Robert
>> coating
>> and
>>>> Piezo
>> bit
>>>> faster,
>> raising the
>> was
>>>> the
>>>> generally
>> coated
>>>> print
>> (The
>>>> test
>> did
>>>> fade
>> as the
>> that the
>>>> hot
>> coating
>>>> traps the
>>>> accelerates
>> coated
>> is
>>>> reduced.
>> I'm
>>>> very
>> predictors
>>>> of
>>>>> drymount press?
>> fresh
>>>> trimming
>> a bit
>>>> of
>> the
>> might
>> strength/extent of
>> to the
>> not,
>>>> however,
>> suggests
>>>> that
>> curing,
>>>> but also
>>>> Paul
>> Polls
>> at:
>> wish
>> visiting
>>>> this same page.
>> messages to
>>>> keep them short.
>>>> header.
>> flames
>>                        ADVERTISEMENT
>>                         [click here]
>> this same page.
>> keep them short.
>> header.
> Buy Ink Cartridges or Refill Kits for Your HP, Epson, Canon or Lexmark
> Printer at Myinks.com. Free s/h on orders $50 or more to the US &
> Canada. http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/l.m7sD/LIdGAA/qnsNAA/ucIolB/TM
> this same page.
> keep them short.
> header.
Thanks Gareth,  Great link.  Its good to see some comparative testing
of these products with the Ultrachromes.  As Paul mentions in his later
post this may only be part of the story, but it is very consistent with
the testing that I did several years ago on the original piezo inks.
Robert
> Gareth
> testing a
> found
> by up
> Hydrocote.
> based
>> chemistries.
>> Robert
> coating
> and
>>> Piezo
> bit
>>> faster,
> raising the
> was
>>> the
>>> generally
> coated
>>> print
> (The
>>> test
> did
>>> fade
> as the
> that the
>>> hot
> coating
>>> traps the
>>> accelerates
> coated
> is
>>> reduced.
> I'm
>>> very
> predictors
>>> of
>>>> drymount press?
> fresh
>>> trimming
> a bit
>>> of
> the
> might
> strength/extent of
> to the
> not,
>>> however,
> suggests
>>> that
> curing,
>>> but also
>>> Paul
> Polls
> at:
> wish
> visiting
>>> this same page.
> messages to
>>> keep them short.
>>> header.
> flames
> this same page.
> keep them short.
> header.
