7 Inks, 6 Inks, 4 Inks...?
2003-08-25 by John Tarnoff
OK, time to stop lurking on this forum, and in my digital photo
practice, and start printing B/W.
I got the 2200 'cause I believed the Epson hype on B/W.  Silly me.  I
love the color prints it delivers, but when it comes to B/W, somehow
just can't believe that even the IP RIP is actually going to give me
B/W from color inks.  It's still just color dots, no matter how well
balanced - maybe I'm a purist, but it's not Black And White.  I think
I just have to bite the bullet and realize that one printer can't and
maybe shouldn't 'do it all.'
As far as B/W Inks, from what I'm reading about 7 Ink B/W
formulations for the 2200, it seems like overkill (and a lot of
money).  Do I want such a degree of control over Warmth to Cool
tones?  Me personally: no.  I was never much for toning in the
darkroom beyond a little selenium here and there, so particularly at
the beginning of this learning curve/experience curve, one excellent
neutral archival carbon pigment B/W print would be great.
So what do I really need?  Should I convert my trusty 4-color Epson
980 (I believe MIS still makes carts for it) to B/W?  Is the
resolution of the 4-color Epsons sufficient?  Is Quadtone really all
I need?  Or should I pick up a 1280 and go 6 inks?  Or is there that
much more acuity to the 2200 for B/W work and I should trade-off on
inks and clean seven nozzles with cleaner cartridges between B/W and
Ultrachromes?
What's the consensus?
JT
Re: 7 Inks, 6 Inks, 4 Inks...?
2003-08-25 by hlockwood
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Tarnoff" <
> Ultrachromes?
> JT
If the size limitation of the 980 is not a problem for you then loading
with MIS inks will give excellent results.  My 980 serves as a backup/
proof machine for my 980 (the 980 is much faster than the 1160.)  I use
the MIS-FS ink set with the Woolf workflow for the 980 and the Randall
workflow for the 1160.  Additional workflow options are available for
the MIS-VM (Paul Roark) ink set.
Harry Lockwood
2003-08-25 by Mitch Alland
For: John Tarnoff
>  I love the color prints it delivers, but when it comes to B/W,
> somehow just can't believe that even the IP RIP is actually going to
> give me B/W from color inks.  It's still just color dots, no matter
> how well balanced - maybe I'm a purist, but it's not Black And White.
I see, you haven't seen prints made on the 2200 with ImagePrint but you
"just can't believe it's "actually going to give "B&W from color inks."
Well, if you're not going to believe it, then it's not worth trying to
tell you anything.
--Mitch/Potomac, MD
2003-08-25 by Steve Kale
My advice is to move in increments.  Quadtone RIP produces excellent results on the
2200 that are leagues above those using the Epson driver.  With Quadtone you have a
number of key advantages:  it involves no cost (RIP or printer costs) and uses the
same ink sets as you use for color.  Try it and see if the improvement is something
you are happy with.  If not then you might want to look at the work that Carl Schofield
has been doing re adding a (one) light grey MIS Ultratone ink so that only one ink
cartridge needs to be swapped when moving to color and back.  If that doesn't tickle
your fancy then try the full UT set.  Why spend the money up front when there are
significant improvements to be had for free or at little cost....?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Tarnoff" <john@n...>
> Ultrachromes?
> JT
2003-08-26 by John Tarnoff
Mitch:  You're being defensive and I haven't even flamed you yet
<g>.  "Can't believe" is a figure of speech.  I've seen all the
comments on IP and respect the judgment of all concerned (you
included).  As I said: maybe I'm a purist, and maybe that's not
necessarily a good thing.  It would be nice if I could eval. the IP
software, but haven't found a way to do so (as they don't seem to
offer a trial).  If there's a real one-stop-shop solution, that's
obviously great.
Do you find that you're getting the same richness in your blacks that
you would expect from a carbon, or, for that matter, from a silver
gelatin print?
See, you can tell me something!
JT
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mitch Alland
<malland@x> wrote:
> For: John Tarnoff
to
matter
White.
you
inks."
to
> tell you anything.
> --Mitch/Potomac, MD
obviously great.
gelatin print?
JT
<malland@x> wrote:
> For: John Tarnoff
to
matter
White.
you
inks."
to
> tell you anything.
> --Mitch/Potomac, MD
2003-08-26 by Mitch Alland
For: John Tarnoff
>   I've seen all the
> obviously great.
I understand that if you buy IP you can return it within 30 days. To
answer your original question or, to be more precise, your original
contention that you don't think that any printer printing B&W with
color inks can produce a neutral print: IP is spot-on neutral, and the
TintPicker allows subtle "toning", say, from warm to selenium tone. On
the other hand, if you use the Epson driver, even with very good
profiles, it's virtually impossible to get a really neutral print,
without a color cast in some tones. But some people who want to print
strongly toned prints, such a sepia tone, have been happy using the
Epson driver with the Bill Atkinson profiles, for example.
> gelatin print?
I don't believe any inkjet printer produces the rich blacks that are
possible with a silver gelatin print, particularly on matte paper. If
by "carbon" print you mean quad inks like Piezography, then, yes, the
UC inks with IP can match the blacks. There is a lot of information in
the archives on Dmax measurement with different papers and inks, but it
may be difficult to get at.
--Mitch/Potomac, MD
2003-08-27 by johngeyles
Quadtone you have a
costs) and uses the
Although QuadtoneRIP has no dollar costs, it APPEARS to me, based
on the myriad postings here about how to install it, that it involves
a significant cost in terms of effort and frustration to get it
going.  For example, you must download and install two additional
software packages in addition to QTR itself.
I'm not trying to dis the author or the software.  It's a wonderful
service he's provided by making this free software available and
he also seems to provide free support in trying to get it installed.
I'm just suggesting that you may be happier by some other solution,
such as the free driver called OPM (www.bowhaus.com/inkjetcontrol).
I got this up and running with VERY little effort and it gives
great results.
But based on the huge enthusiasm for Quadtone RIP that I see in this
forum, I'm wondering if I should bite the bullet and try to install
it as well.  But I'm glad I started with OPM.
John
2003-08-27 by flyfishingusa2002
John,
Forgive me but your post sounds a little like sour grapes.
If you have a Mac then installation should be simple for someone that has used a mac
before. In my case i had not.
True, there seem to be lots of issues with installing to Linux, but if you are
experianced here you should not have a problem.
Believe you me, the results from my 2200 using Quadtone Rip are stunning, only
limited by the quality of the input.....If you want a test print send me a self
addressed envelope and I'll mail you one!
Barry--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "johngeyles" <jge@c...>
> Quadtone you have a
> costs) and uses the
> great results.
> John
Maybe that's fair.  And I guess it's right that most of the
problems people seem to be having here are related to Linux
(rather than OSX) installations.
I have no doubt that QTR gives wonderful results (and thanks
for the offer to send me a test print), but I wonder
if they are better than OPM/IJC.  Of course, QTR allows printing
color too (but I'm pretty satisfied with color from the Epson
driver).  I think the main reason I'd want to use QTR is that
I want to migrate from OS9 to OSX, and OPM/IJC is only for OS9
(Antonis, is OPM/IJC gonna become available for OSX ?).  And there
seem to be a lot more QTR users, so maybe more profiles downloadable.
Anyhow, in the spirit that the newbie original-poster is probably
better off with an incremental approach, I still think he might be
better off starting with OPM.
John
Re: [Digital BW] Re: 7 Inks, 6 Inks, 4 Inks...?
2003-08-28 by David M. dorn
johngeyles wrote:
> ....But based on the huge enthusiasm for Quadtone RIP that I see in
> this
> John
John,
I think most of the post discussion on the difficulties on installing
QuadTone RIP are related to the installing the software on a PC using
Linux.  If you are using a Mac with OS X then I think you would find
the installation very easy provided you follow the instructions from
Roy's site and in the downloads very carefully, particularly the
printer naming conventions.
I downloaded and installed the software very quickly on a Sunday
afternoon.  The only problem I encountered was getting the profiles to
load properly into the "CurvesDropDownBox" folder. In my case i think
this was due to the OS X security keychains that I had set up.  i don't
think you would have any problem getting QT RIP up and running on a OS
X Mac.
I think in Linux you probably need to have good Unix and/or Linux
skills at the command line level.
If you are doing a Mac installation and have problems feel free to
contact me off list.
I think Roy and Carl have done a great service.
QT Rip and I have, in the last lines of Casablanca, ",,,the beginning
of a beautiful friendship..."
David
2003-08-28 by Roy Harrington
John,
I just want to clear up a couple issues.
The Linux installations are a whole different ball park.  I don't have
any Linux boxes, so these guys are porting software that has never
been compiled, tested, or even tried on those operating systems.
The print engine for both systems is the same -- gimp-print.  So if
whoever designed the curves for each system, did as good a job
the results should be the very similar.
> driver).
There is no color printing for either QTR or IJC.  They both use
grayscale input and control each of the inks independently.
For a user downloading existing curves, the OS9 vs OSX is primarily
the only big difference.  There is a usage difference in that IJC uses
a separate program OPM to do the printing, QTR uses the standard
print dialogues of the OS.
Designing curves is fairly different for the two products.
> John
Roy
2003-08-28 by johngeyles
Thanks.  I never meant to slam QTR.
Got it.
Could you say more about this ?
Thanks, John
