Re: Septone system (LONG)
2003-08-26 by Jon Cone
The one day I check in to read this list and I see my name come up!! So I should probably respond. By the way it is unbelievable how this group has grown and it is fascinating to see how many variations in use there are now in monochromatic printing. I do not think that any other niche has ever received so much attention from such a wide variety of vendors! re: --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > The reason I was curious about how warm the Septone warm inks were is that > if there are coloring toners in it (which there would have to be if it was > warmer than the Ultra Tone ["UT"] grays), then its longevity would probably > be somewhat compromised. From what I can tell, the new, pure carbon inks > are better than the color pigments that are used to do the toning. For > example, I'd say the PiezoTone carbon/sepia is a toned ink. According to > Jon Cone's latest lightfastness table the PT Carbon Sepia fades at about 3 > times the rate of the PT warm Neutral, which probably has the least amount > of colorant in it. Neither PiezoTone Warm Neutral nor Carbon Sepia is a "toned ink". They are both made from a single 100% carbon pigment. Both use the same single pigment. There is not two, nor is their a different pigment in either formula. The same single carbon pigment is shaped differently to arrive at a different color. This type of technology was unique to PiezoTones when they were introduced. I do not know if others have adopted the technology required to shape micro-pigments. http://www.inkjetmall.com/store/info/1000-hours.html The above has the rates of fade for the PiezoTones as well as EPSON UltraChromes and both MIS-FS and Sundance Warm Neutral inks. The fade rate for PiezoTone Warm Neutral averages less than 1% to just over 2%. The fade rate for PiezoTone Carbon Sepia averages less than 2% to just over 2.6%. The difference in fade between Warm Neutral and Carbon Sepia PiezoTone inks is actually negligible because the fade rate for both is well below that of human perception. So the different color arrived by shaping the pigment has no effect on fade. Rather the fade rate can only be measured by an instrument which is not a human eye! 5% is the threshold for average human perception of fade. Incidentally, 30% is considered the endpoint in testing from both Wilhelm and RIT, yet considered as an unacceptable amount of fade for nearly all b&w photographers. In comparison to the PiezoTone inks, the MIS-FS Warm Neutral inks average fade rates from 8.15% to just over 13.8%, and the Sundance Warm Neutral inks average fade rates from 13.8% to just over 23.5%. PiezoTone Selenium and Cool Neutral inks however, are both two-pigment systems. Yet, they still average from less than 2% to 3.8% fade which is still well below human perception of fade. The two pigments combine to make a single perceived hue. I think that these might be what Paul considers "toned" inks. But they are really comparable to our single pigment inks in fade resistance. In general, there is both a wide range in the quality of pigments used in the various inks on the market today as well as a wide variation in the manner in which chemists design inks. It is possible for two companies to use single pigment systems and not have comparable inks in relation to fade. Also, it is possible for a company to "tone" carbon with another pigment and not have as good a fade resistance as another company which "tones" carbon. Quality and standards vary widely in both the pigment industry and in ink manufacturing. This accounts for the wide variations in ink performance. Few publish patents so mostly chemists are on their own. Paul points out that pure carbon is better than color pigments. In general, this is correct, but when one looks at the fade rates of the EPSON Ultrachromes which average from 3.7% to just over 16.9%, it is noticeable that black is not the most stable component of that set. Magenta is. I beleive that by looking at the fade rate numbers, UltraChrome was designed to test well in industry tests which examine "yellow fade". Cyanine is normally the most permanent pigment in a CMYK set. Yet cyanine is the poorest performer in the UltraChromes and I have never seen that before. UltraChrome Photo Black has a fade rate of 6.36% and Matte at 6.02%. Piezography Museum Black has a fade rate of 5.23% and Piezography Portfolio Black has a fade rate of 7.3%. The preceding blacks have a slight fade that is just over the human threshold. The blacks from the MIS-FS warm neutral and Sundance Warm Neutral did not perform as well and were 13.8% and 15.12% respectively. All of the inks described in this reply have received ratings by testing "authorities" that are considered to be over 100 years. None of the inks reached end points of 30%. This is why I prefer side-by-side testing which shows actual density volume decrease, so that a user can pick out an ink which does not have any discernible fade from one which does have considerable fade even though both have been designated as 100 year inks. This type of information is more meaningful than "years ratings" which do not differentiate between such wide performances and do not clearly state at which point below 30% did the ink fade to. I believe that currently, industry tests are leaving the user a bit in the dark because they do not permit the manufacturer to publish certain data, and it is that certain data which is relevant in relation to the rating. This data can and shoud be used by consumers to understand how two inks compare. Ink manufacturing is changing rapidly. Some companies are making inks that "test" well and others are attempting to make inks which simply just do not fade. The latter being much more expensive to manufacture and seemingly unnecessary considering the leading authorities on testing permit a 30% fade before reaching and endpoint. I am not sure who is actually looking out anymore for the consumer. Testers like Paul and others who have set up their own kits and even makeshifts are slowly combining to reveal much about today's inks. Other independents are beginning to invest in Xenon chambers which have control over temperature and humidity and allow a full spectrum of harmful illumination. I would never dissuade anyone from taping prints onto windows. But it is essential and mandatory that side by side testing use the EXACT SAME methods and software as well as paper and printer and printer settings for each sample. That is critical in evaluating side by side performance of competing inks. If we compare the performance of all of the inks mentioned in this reply to those which were available 10 years ago, no digital artist or photographer would have believed it possible. I am not certain if everyone here realized that the original IRIS inks were rated for only 3-6 months. A subsequent ink set was rated 2-3 years. I eventually made two ink sets for IRIS which received 13-15 and 21-23 years from Wilhelm and on both occasions my entire staffs were treated to celebration dinners. Sometimes it is good to put things in perspective to see how well we are doing. Also, it is widely accepted at the George Eastman House that silver will outlast the paper that vintage photos are printed on. So much work is being done there to save works in their archives. Very little from 100 years ago and even 50 years ago can be stabilized to the point where they can be displayed in the manner that testing authorities assure us our inkjets can! Therefore, we are actually closer to our goals than we realize. Or perhaps they are completely wrong. ;-) Lets not beat ourselves up too much. With that said, naturally I am hoping that more photographers want inks which just simply do not fade! :) best regards, Jon Cone Piezography inks and software
