Re: Eboni black spray, was QTR2 for Linux
2003-08-26 by Ernst Dinkla
From: "Paul Roark" <paul.roark@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Tuesday, August 26, 2003 6:47 PM Subject: RE: [Digital BW] QTR2 for Linux > Ernst, > > >... > > that strange spraying happens with all the three 9x00 > >printers a friend and I have loaded with Eboni black. ... > > Is it possible there was some residual dye on the parking pads -- even maybe > the dyes that were in the old black pigmented inks? I think Eboni on the > pads can react with old dye and make solids that then stick onto the heads. > I had some problems with a 1280 that had been using dyes, and it was > eliminated as soon as I thoroughly rinsed/cleaned the pads (with Windex -- > an ammonia solution, I think). > > Paul > http://www.PaulRoark.com Paul, We did a lot of work in cleaning the CIS systems at the change between the old ink and the Ultratone. It is correct that the Generations black is 25% dye and on one system the change was from Epson dye to Ultratone. But on two systems we renewed the black head to see whether that made any difference, it didn't (the heads were cleaned with Windex as well). Two 9000's are running Ultratone, the other one MIS 7600. All colours will print excellent but not the Eboni black. I have another untouched pint of the same Eboni black delivery but I wouldn't like to see the same symptoms when we use that one. The best prints I got was when it was really hot in the Netherlands, looks like the ink needs a warmer environment to flow. I guess the pigmentation of the Eboni black is at the edge of what is still printable with the 9000. The alignment and nozzle check patterns show shaky lines for the black with a lot of droplets thrown around them at random. The nozzles don't clogg. Could be an electrostatic charge issue too. I wrote MIS about it before the weekend but they have not replied yet. A recent delivery of MIS 7600 ink runs smoothly in 9600's. Bob had some reservations about the use of Ultratone ink in 9000's when we ordered the inks in March. We were aware of the testing stage so it is certainly not a complaint. But it surprised me that there was never a similar message on this list. Ernst
