Re: ImagePrint Experiences
2003-09-30 by Mitch Alland
For: John Hollenberg > I believe Andrew was saying (but I don't know if it is true) is that > if you convert to gray gamma 2.2 in Photoshop first the "Black Point > Adjust" slider doesn't function in IP. No need to theorize, just try it. I just did and find that this is correct: using one of the IP grayscale profiles, the Black Point Monitor Compensation Slider works when you use an RGB file but not when you use a grayscale file, and the TintPicker seems to work as well. The trouble is how to get a proper preview in Photoshop when you're using an RGB file that you are going to print with an IP grayscale profile. I am going over to the yahoo ImagePrint group to continue this discussion. --Mitch/Paris
