Re: Epson C82 affordable "Carbon on Cotton"
2003-10-19 by Jerry in Houston
I looked in the Epson site and they list a C-84 and it is in the right price range (@$79 USD) but has a much higher claimed resolution.... or is the C-82 yet to be released.
I have a C-80... what is the difference between my C-82 and the C-82?
Jerry in Houston
RE: [Digital BW] Epson C82 affordable "Carbon on Cotton"
2003-10-20 by Paul Roark
I think the C82 is an older model.  MIS and Amazon have them, but I'm not
sure how many are still out there.  The C84 will be the next one,
presumably, but for now there are no 3rd party carts available. MIS thinks
they use the same inks, but different chips.
The higher resolution of the C84 is probably visible with color inks on
RC/glossy paper, but with B&W on matte, I think a loupe would be required to
see the difference.  I was, frankly, astounded at how good the C82 is at
2880 (with High Speed off -- it does make a difference with this printer)
and when the same gray ink (MIS UT Light cyan) is in all three color carts.
The weaknesses I've found so far with the C82 are, first, the dmax, and
second, a possible paper handling glitch.
While the dmax of the C82 doesn't match that of the 1280, the C82 with
PhotoRag hits 1.57 with Eboni black, which is not too bad for cotton.
Recall that the new cotton papers from Epson and Moab were hitting 1.6 -
1.62 with the 1280 and Epson driver.  I suspect those papers don't do much
better than the C82 when the Piezo driver is used with, for example, an
1160.  The Piezo driver, like the C82, under-prints the black ink with the
"color" inks.  It's a trade-off between smoothness and dmax.  With EEM the
dmax is 1.55, same with the new Permajet (cotton) ISC (there will be a new
name when released in January).  Some cotton papers are not good, however.
PremierArt was down at 1.46.
Of course, some will opt to use Gen 4 Enhance K or some other dye/pigment
hybrid to overcome this issue.  I'm not sure what the ratio is between Piezo
"Museum" K (pure pigment like Eboni) and the hybrid blacks Cone sells, but
many clearly go for the deeper black ink even if it fades and warms more.
The paper handling issue I've found with the C82 is that the head will
sometimes hit the corners of papers that curl.  Usually, I've just seen a
black mark on the bottom 1/8" edge of the paper, but on one piece it caught
the paper and moved it slightly, causing a dual/ghost image at the end of
the page.
The "problem" relates to the fact that the C82 head is set "vertically."
That is, for example, when you look at the parking pad the long axis/side is
perpendicular to the movement of the head.  When looking at a purge pattern
being printed, the color bars are being printed one after the other; they
are like stair-steps.  The yellow ink is the last one to be laid down and is
being printed about 1/2 to 3/4 inch away from the first set of rollers --
the main rollers/platen on most printers, I believe.  So, the yellow is
still being printed when the bottom of the paper is past/outside this first
set of rollers.  However, there is a second set of rollers, very near the
paper exit, that keeps the paper moving.  The system seems to work very well
most of the time.  Unfortunately, if a corner is turned up for some reason,
it might get hit by the head while the yellow ink is still being printed.
This vertical head arrangement may have some distinct benefits, of course.
I thought my old 1160 was a fine quad, but the dither and smoothness on this
cheap C82 is way ahead of it.  I suspect the vertical placement makes
alignment (and cheap assembly) much less of an issue, because I'd guess it
is mostly machined in the head when it's made -- by a very accurate machine.
The carts for the C82 (and C84) are still a bit of an open issue.  It
appears MIS has some new ones for the C82 that might make re-filling
extremely easy, avoiding the foam problems.  (Having only one "color" ink
also makes the process rather easy for both re-fillers and MIS.)  It may be
that with a re-setter, a single set of carts will last a very long time.
The current carts are, apparently, not easy to re-fill.  I'm not certain
when the C84 carts will be ready.
The independent color carts also appear to be all the same.  This could be
very interesting.  The yellow pumps in less ink than the others.  So, if I'm
lucky, a toner might be able to be mixed that, for example, makes a neutral
print when in the magenta spot and medium-warm print in the yellow slot.
Similarly for a sepia toner.  (Having one [already in inventory] gray ink in
all carts -- which just happen to be the same -- is also a nice little
inventory and cost benefit to MIS, which hopefully will be passed on the
users.)
I must say that I am beginning to like the Epson chips.  They keep track of
how full the carts are as they are being pulled in and out for different
effects, including color v. B&W.  As long as the 3rd-party chip engineers
can keep Epson's lead time down to a few months, the chips might be a net
benefit here.
(I have no idea what the differences are between the C-80 and C-84, but I'd
guess the model changes all have different chips.)
>1. Is this going to be offered by MIS as a kit or will I have to buy
>the components separately and prepare them myself?
I don't know, but the aim is to make something that is so simple that a
non-technical novice can do it all.
I'll be talking with a scrapbook store owner tomorrow about, among other
things, the expertise level to expect in that market.  From what I have
seen, I suspect there is a market for a turn-key system, but that may be
left to the local store owners.  I have no idea what MIS has in mind.
I also see a demand for training courses for the non-photographers.  I've
already been invited to speak at a genealogy society and ran out of cards
from older folks who wanted help scanning and printing their fading old B&W
photos.
>2. Will this work with other papers as well (i.e. Epson Heavyweight
>Matte)?
I suppose any paper will work.  The printer doesn't seem to have any trouble
with copier paper, EEM, or the 300-weight/thick paper I was trying.  It just
looks like curl on the bottom corners could be an issue.
Keep in mind that this is a $69 machine.  I don't recommend people throw
their 1280s away, but there are a lot of people who don't want to put out
that kind of cash.  The goal here is to lower the financial and expertise
barrier to outstanding, archival B&W printing by getting a cheap printer,
"no-workflow" inkset, and non-Photoshop image editor competitive with the
best systems -- and the C82 has made me believe more than ever that this can
be done.
Frankly, from what I've seen this last week, and since I use the 7500 with
UT inks for display prints, I might be very happy with the C82 and no 1280.
The "might" isn't a "would" mostly because I have not tested the toning
approaches yet.  That happens next week (since I ran out of carts last
week).  The only real question here is whether the plug-in toner cart
approach will work or whether we need to put the neutral/selenium ink (&
maybe others later) in all 3 spots.
http://www.PaulRoark.com
Re: [Digital BW] Epson C82 affordable "Carbon on Cotton"
2003-10-29 by seanstreiff
Paul:
Thanks for doing, and sharing, your work on doing archival B&W with
reasonable expense and hassle.
What are your current thoughts on using MIS-UT with C82/C84 vs. 1280?
How about newer Epson models like 960 and the mysterious PX-G900?
Reason to delay a purchase decision?
Finally, I'd love to hear your thoughts about what to recommend for
archival *color* printing, if you do any of that.
I'm a rank beginner (Canon G3 bought yesterday; no printer) who, like
many folks, I suspect, has followed with great interest your quest for
'affordable "Carbon on Cotton"'. I'm willing and able to pay for a
1280 but also able to appreciate smaller price (and size) of C82/C84.
Print size difference is not crucial for me (8.5x11 in. fine for
awhile). I'm willing to have two photo printers (color, B&W) if need
be.
THANKS, AGAIN, FOR SHARING YOUR WORK.
Sean Streiff
right
I'm not
thinks
inks on
required to
is at
printer)
carts.
and
with
cotton.
1.6 -
do much
example, an
with the
EEM the
a new
however.
[snip]
on this
makes
guess it
machine.
It
"color" ink
may be
time.
certain
could be
So, if I'm
neutral
slot.
gray ink in
little
on the
> users.)
[snip]
throw
put out
expertise
printer,
with the
this can
> be done.
7500 with
no 1280.
toning
last
cart
ink (&
> Paul
2003-10-29 by Paul Roark
Sean,
The big differences are that the 1280 can print 13" paper, the dmax is a bit
higher (1.62 on cotton v. 1.55, 1.66 on EEM v. 1.55), the 1280 has smoother
highlights than the C82 (unknown with respect to the C84), but the C82 is
about as good at the 2200 with IP5, so it's not bad.
The C82 is going to be simpler -- no curves, etc. -- and cheaper.
I don't know much about them.  The idea was to get a machine that was as
affordable as possible and see what it could do in terms of archival
printing.  The results, frankly, surprised me.  I never expected such high
quality.
Well, the 2200 is a fine machine.  However, the C82 with its color Durabrite
pigmented inks does a very good job, and it's a lot cheaper.  The Durabrite
inks appear to be essentially the same as the UltraChromes, but without the
light black -- the lightfastness and longevity are about as good.  So, my
recommendation for the scrapbookers and genealogists is to get the C82 (or
C84 when the carts arrive) and just switch back and forth between the
Durabrite and carbon pigs as needed.  On matte paper, I think this little
4-ink printer at 2880 does an excellent job.   It's a great way to get into
digital printing affordably.
________________________________________
right
I'm not
thinks
inks on
required to
is at
printer)
carts.
and
with
cotton.
1.6 -
do much
example, an
with the
EEM the
a new
however.
[snip]
on this
makes
guess it
machine.
It
"color" ink
may be
time.
certain
could be
So, if I'm
neutral
slot.
gray ink in
little
on the
> users.)
[snip]
throw
put out
expertise
printer,
with the
this can
> be done.
7500 with
no 1280.
toning
last
cart
ink (&
> Paul
page.
them short.
resources on the homepage.
> Sean,
1280?
is a bit
smoother
C82 is
Paul:
OK, thanks very much for this summary overview.
[snip]
Durabrite
Durabrite
without the
So, my
How about budding digital photo enthusiasts (with modest wet darkroom
experience)?
little
get into
> Paul
Thanks again for your help (I'm assuming that I'm not the only one
benefiting from this).
-Sean
2003-10-29 by Voegels Alfred
paul,
somehow the message below got misdirected to me!
Since I have you here, one question:
Does it make sense to create ICC profiles for the UT
inks on the different papers and create cool, neutral
and warm tones with the ICC profiles?
Alfred
--- Paul Roark <paul.roark@...> wrote:
> Sean,
> C82/C84 vs. 1280?
> and cheaper.
> mysterious PX-G900?
> machine that was as
> terms of archival
> quality.
> to recommend for
> forth between the
> Paul
> "Paul Roark"
> and it is in the
> right
> have them, but
> I'm not
> be the next one,
> thinks
> visible with color
> inks on
> loupe would be
> required to
> how good the C82
> is at
> printer)
> in all three color
> carts.
> first, the dmax,
> and
> the 1280, the C82
> with
> too bad for
> cotton.
> Moab were hitting
> 1.6 -
> those papers don't
> do much
> with, for
> example, an
> with the
> and dmax.  With
> EEM the
> ISC (there will be
> a new
> however.
> [snip]
> on this
> vertical placement
> makes
> issue, because I'd
> guess it
> by a very accurate
> machine.
> an open issue.
> It
> (Having only one
> "color" ink
> may be
> last a very long
> time.
> re-fill.  I'm not
> certain
> the same.  This
> could be
> than the others.
> So, if I'm
> example, makes a
> neutral
> print in the yellow
> slot.
> in inventory]
> gray ink in
> is also a nice
> little
> will be passed
> on the
> > users.)
> [snip]
> recommend people
> throw
> who don't want to
> put out
> financial and
> expertise
> getting a cheap
> printer,
> editor competitive
> with the
> more than ever that
=== message truncated ===
Do you Yahoo!?
Exclusive Video Premiere - Britney Spears
http://launch.yahoo.com/promos/britneyspears/
2003-10-29 by aevoegels
Sorry,
I forgot that yahoo groups emails messages unless clicked off - Has
anyone already mentioned how the yahoo forum format sucks?
anyway, sorry for the confusion.
Alfred
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Voegels Alfred
<aevoegels@y...> wrote:
> paul,
> Alfred
> --- Paul Roark <paul.roark@v...> wrote:
> > Sean,
> > C82/C84 vs. 1280?
> > and cheaper.
> > mysterious PX-G900?
> > machine that was as
> > terms of archival
> > quality.
> > to recommend for
> > forth between the
> > Paul
> > "Paul Roark"
> > and it is in the
> > right
> > have them, but
> > I'm not
> > be the next one,
> > thinks
> > visible with color
> > inks on
> > loupe would be
> > required to
> > how good the C82
> > is at
> > printer)
> > in all three color
> > carts.
> > first, the dmax,
> > and
> > the 1280, the C82
> > with
> > too bad for
> > cotton.
> > Moab were hitting
> > 1.6 -
> > those papers don't
> > do much
> > with, for
> > example, an
> > with the
> > and dmax.  With
> > EEM the
> > ISC (there will be
> > a new
> > however.
> > [snip]
> > on this
> > vertical placement
> > makes
> > issue, because I'd
> > guess it
> > by a very accurate
> > machine.
> > an open issue.
> > It
> > (Having only one
> > "color" ink
> > may be
> > last a very long
> > time.
> > re-fill.  I'm not
> > certain
> > the same.  This
> > could be
> > than the others.
> > So, if I'm
> > example, makes a
> > neutral
> > print in the yellow
> > slot.
> > in inventory]
> > gray ink in
> > is also a nice
> > little
> > will be passed
> > on the
> > > users.)
> > [snip]
> > recommend people
> > throw
> > who don't want to
> > put out
> > financial and
> > expertise
> > getting a cheap
> > printer,
> > editor competitive
> > with the
> > more than ever that
> Do you Yahoo!?
RE: [Digital BW] Re: Epson C82 affordable "Carbon on Cotton"
Sean,
As to your question about the quality of the C82 color printing, it's
probably subjective.  However, it's good enough for me.  I did my (picky
princess) daughter's senior high school yearbook photo with it, and she was
pleased.  Last year I did a wedding in color on my 1160, and the people were
very pleased -- and the C82 is better than the 1160.  So, with matte paper I
consider the quality to be very good.  I think the RC/glossy paper is where
one might see more differences between this 4-ink printer and the hextone
printers.
Sent: Wednesday, October 29, 2003 2:54 PM
Subject: [Digital BW] Re: Epson C82 affordable "Carbon on Cotton"
> Sean,
1280?
is a bit
smoother
C82 is
Paul:
[snip]
Durabrite
Durabrite
without the
So, my
experience)?
little
get into
> Paul
-Sean
page.
them short.
ICC profiles for UT inks (was Epson C82 affordable "Carbon on Cotton")
2003-10-30 by Paul Roark
Alfred,
I'm just not familiar enough with ICC profiles to know.  I suspect they
might be easier to use (if they worked), but I'm not sure they would be as
easy or cheap to create or modify by users.  My whole approach is oriented
to open and free systems.
Re: [Digital BW] ICC profiles for UT inks (was Epson C82 affordable "Carbon on Cotton")
2003-10-30 by Tom Baker
ICC profiles are obviously easier to use.  But, remember that a profile that is not right on is pretty much worthless.  And, to get really good ones you have to pay.  Either in you own time and equipment, or someone else's time and equipment.  If you attempt to have profiles done, be sure you get a "SATISFACTION GUARNTEED" guarntee.
Tom Baker
Alfred,
Yahoo! Groups SponsorADVERTISEMENT
RE: [Digital BW] ICC profiles for UT inks (was Epson C82 affordable "Carbon on Cotton")
2003-10-30 by Paul D. DeRocco
> From: Paul Roark [mailto:paul.roark@...]
The purpose of a profile is to accurately describe the hardware. If you want
to print cool, neutral or warm using color inks, then you really want to use
conventional color balance controls for that, so you can see it on the
screen, and then rely upon the profile to do what it's really intended for,
which is to make the print look like the screen.
2003-10-31 by dp20031997
I want to especially thank Paul and Clayton (but many others also)
for their contributions to this group.
This is the first time anyone in the group has heard any sort of
noise out of me, but I have been reading and learning for quite a
while now.  Thanks!
The Epson C82 with your suggestion of MIS Eboni and UT Light Cyan is
very interesting to me, but the C84 seems to an even more desirable
printer – not just because Epson has dropped the C82.
I asked MIS today about support for the C84 but they were unable to
give a definite answer.
Also the person I talked to didn't know about your `no curves, etc.'
set setup for the C82.
I am wondering if anyone is planning to try this setup.
Sincerely,
David Polasek
dp4391@go2netmail.com
> Sean,
it's
(picky
she was
people were
matte paper I
is where
hextone
> printers.
> Paul
> From: seanstreiff [mailto:seanstreiff@e...]
> > Sean,
> 1280?
dmax
> is a bit
> smoother
> C82 is
> Paul:
> [snip]
for
> Durabrite
> Durabrite
> without the
> So, my
darkroom
> experience)?
> the
> little
> get into
> > Paul
> -Sean
2003-10-31 by Paul Roark
David,
The only problem with the C84 is that the chips for the carts are not yet
available.  MIS thinks they use the same Durabrite inks as the C82 and the
same cartridges -- but different chips.
There is no shortage of C82s out there from $69.  See, for example,
http://www.nextag.com/Epson_Stylus_Color_C82~55322144z0znzzz1zzc82_epson_sty
luszmainz2-htm (cut and paste the wrapped part of the URL)
MIS has received the new C82 carts and they are in the mail to me.  I'll
have a neutral version of the inkset soon.
Sent: Friday, October 31, 2003 2:14 PM
while now.  Thanks!
printer \ufffd not just because Epson has dropped the C82.
Sincerely,
David Polasek
dp4391@...
> Sean,
it's
(picky
she was
people were
matte paper I
is where
hextone
> printers.
> Paul
> > Sean,
> 1280?
dmax
> is a bit
> smoother
> C82 is
> Paul:
> [snip]
for
> Durabrite
> Durabrite
> without the
> So, my
darkroom
> experience)?
> the
> little
> get into
> > Paul
> -Sean
page.
them short.
RE: [Digital BW] Epson C82 "Carbon on Cotton", but be warned of the C84
2003-11-02 by D. Hill
Hi all,
With much sadness yesterday, I had to pronounce my
trusty 875dc deceaded, time of death 3:03pm.
As this was the workhorse printer that my wife and I
share, it needed immediate repacement.  Great, I
thought, I'd just run out and buy one of the C82's.
Unfortunatly they were all out of stock except for the
display so I picked up a C84 (thinking that they were
the same beast but a better model).
Long story a bit longer, the printer was dead on
arrival.  As I looked closer at the printer itself, it
is a really shoddy model, not in the same league as
the C82.  As I did not want to repeat this process, I
brought it back and exchanged it for an Epson 825
which uses the same (dye) cartridges as the 870/875dc
(which I still have a stack of) This was a pleasant
surprise, as the canned profiles were spot on out of
the box.
So the moral is, if you would like to try out the C82
- get one before they are gone, because the C84 is not
a very impressive replacement model.
So, back to the beginning, If anyone wants the 875dc
for printing black only, you can have it for the cost
of shipping (contact off list please), but the cyan
channel is dead.
Don
> it is in the right
> the next one,
Do you Yahoo!?
2003-11-03 by Paul Roark
Don,
Thanks for the information.
>... I thought, I'd just run out and buy one of the C82's.
>Unfortunatly they were all out of stock ...
Was this true of the internet sellers also, or was this just the local
stores?
> except for the
>... it is a really shoddy model,
>not in the same league as the C82. ...
That's very bad news.  I'll pass the information on to MIS.  Maybe I ought
to focus my efforts on some other model.
> it is in the right
> the next one,
Do you Yahoo!?
page.
them short.
Re: [Digital BW] Epson C82 "Carbon on Cotton", but be warned of the C84
2003-11-03 by joseph07081
Hi again
I have found ONE new C82 at a local dealer here and I plan to pick
it up ASAP. Actually I may also buy up the floor model too if
possible :-)
Is there any word from MIS as to when the inks/cartridges may be
available?
Thanks
Joe
> Don,
MIS says there are lots of C82s still out there.  I hope they are right.
Carts are supposed to be in the mail to me.   MIS was not able to get the
ones they hoped for, but what is coming is apparently easy to bottom fill,
but the total ink capacity may not be quite what it is supposed to be.
I'll get a neutral solution ASAP -- this week, hopefully.
If the C84 isn't up to the job we'll find an alternative and do the same
approach.  I'm determined to have this technology available to all.
Sent: Monday, November 03, 2003 4:37 AM
Subject: Re: [Digital BW] Epson C82 "Carbon on Cotton", but be warned of
the C84
Hi again
possible :-)
available?
Thanks
Joe
> Don,
page.
them short.
2003-11-03 by D. Hill
Paul,
None of my local stores had the c82 in stock.  This is
unfortunate, but as this model is a closeout any that
can be found should be able to be purchased at an
extraordinary deal.
A few online dealers still have remaining stock of the
printer, but the supply is short - it seems the best
place of purchase would be office depot.
Don
> Don,
> C82's.
> this just the local
> stores?
Do you Yahoo!?
2003-11-03 by bfwoolner
I purchased 2 C82 printers at Staples yesterday for $69.00 each.  They had a
couple of others in stock at this particular store.
Barbara
Sent: Monday, November 03, 2003 9:30 AM
Subject: RE: [Digital BW] Epson C82 "Carbon on Cotton", but be warned of the
C84
> Paul,
> extraordinary deal.
> Don
> > Don,
> > C82's.
> > this just the local
> > stores?
> Do you Yahoo!?
page.
them short.
2003-11-05 by dp20031997
Paul,
I finally found one at a local Staples which they are holding for me
until tomorrow.  I hope you are still interested in trying to work
with this printer but I'll at least get to try BO with the ink
shipped with it.
I'll be in your debt if work out anything with it (even curves).
Thanks.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "D. Hill"
<hill14701@y...> wrote:
> Paul,
> extraordinary deal.
> Don
> > Don,
> > C82's.
> > this just the local
> > stores?
> Do you Yahoo!?
2003-11-05 by Paul Roark
Don,
>I finally found one at a local Staples ...
>with this printer ...
I just received the new empty carts for the C82 today.  They are not the as
"refill-friendly" as MIS had hoped, but they work.  (MIS apparently has a
CFS for this printer for high volume users.)
I also just printed a PhotoRag neutral print.  The neutral (slight
"selenium" tone) inkset needs at least one more iteration, but it looks
good.  (Dmax on PhotoRag with this version is 1.59.)
So, it's still looking like an excellent affordable and simple B&W printing
solution -- print from grayscale files & no curves to mess with.
_____________________________________________
> Paul,
> extraordinary deal.
> Don
> > Don,
> > C82's.
> > this just the local
> > stores?
> Do you Yahoo!?
page.
them short.
