profile question
profile question
2003-11-09 by BMercerTX@aol.com
I know this is a stupid technical question but ....I am Windows 2000Pro OS.
I have a paper profile that I want to use thru the Epson driver.  Where do I
put the profile?
Billie
RE: [Digital BW] profile question
2003-11-09 by Paul D. DeRocco
> From: BMercerTX@... [mailto:BMercerTX@...]
> 2000Pro OS.
> Where do I put the profile?
Right-click it, and select Install. That will copy it into the correct
folder, and list it in the registry so that apps can find it.
Re: [Digital BW] profile question
2003-11-10 by Martin Glader
Billie,
The ICC profiles in W2K are by defult in
C:\WINNT\system32\spool\drivers\color
Martin Glader
Sent: Sunday, November 09, 2003 2:51 PM
Subject: [Digital BW] profile question
OS.
I
> put the profile?
> Billie
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
> - Good manners are required at all time. No personal attacks or flames
resources on the homepage.
2003-11-10 by B. Alex Pettit Jr.
Hi Martin,
Is there an editor for the ICQ paper profiles ???
From my limited tests with the ones used by the
Piezography software, the EAM is very smooth -
other paper profiles have some major gradient
step changes. I'd like to tweak the EAM profile
to expand the very last few % of the K end of the
scale...
Alex
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Glader"
<martin.glader@k...> wrote:
> Billie,
> Martin Glader
2003-11-10 by BMercerTX@aol.com
In a message dated 11/10/2003 2:29:34 AM Central Standard Time,
martin.glader@... writes:
> Martin Glader
Martin,
Thanks but when I just copy them into that folder they are in the folder but
do not show up in my pull down menu, so how do you access them for soft
proofing? I've had to right click them and install so that they end up where I can
choose one. Is that the right way?
Along those same lines.  When you go to print an RGB file on the Epson 2200
Set the source to the profile
The print space to:  Printer management?  or ????
Then the screen where you set the paper type do you set the mode for ICM
under the Mode section, then to advanced and set color management to ICM.
Do you still choose one of the Epson mediatypes?
I'm really fuzzy on how to do this.
I apologize that this is probably not the appropriate group to ask this
question but there are so many knowledgeable people in this group.  So if any one
can clear this up for me I would appreciate it.
Billie
2003-11-10 by Paul D. DeRocco
Two choices:
1) Select Printer Color Management in PS, then select ICM and the profile in
the driver.
2) Select the profile in PS, then select ICM and No Color Adjustment in the
driver.
In both cases, the source space must be Document.
2003-11-11 by Martin Glader
Alex,
I have never had the need to edit the ICQ profiles so I wouldn't know. I'm
using the Cone driver with the paper profiles supplied with the software and
then fine-tune the monitor preview for each particular paper with custom dot
gain curves. I'm mostly using Hahnem\ufffdhle Photo Rag though. The method is
also described in the Piezography manual.
Martin Glader
Sent: Monday, November 10, 2003 11:57 AM
Subject: Re: [Digital BW] profile question
> Hi Martin,
> scale...
> Thanks,
> Alex
> > Billie,
> > Martin Glader
page.
them short.
profile question
2007-10-26 by Frank Jay
hello,
  When I download the profiles for the epson papers, or any papers for that matter, how do I get them from the file I load them to either the QTR or the epson printer page.
  I educated my self on profiles thru several articles being I didn' t get a response on my post as to learning profiles,  but nowhere was it mentioned as to how they get from one place to the other so they can be used.
  thanks
  Frank
"The luckiest dogs are those with clipped tails....they're the ones who won't be chasing their own arses."
Do You Yahoo!?
http://mail.yahoo.com
2007-10-26 by Eric Neilsen
Frank, I did not see you mention your OS; MAC, PC? Color Sync or
C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\COLOR And Vista is different?   You can
right click and "install" profiles and depending on some applications you
need to do that. I set up a shortcut on my desktop so I don't need to
navigate to the color profile folder on the Windows XP systems.
You can save them directly to that folder or save to a different download
folder for profiles and then copy or install them.  I like to keep them in a
separate download folder with subfolders for supplier; Red River, Cranes,
Epson, Innova, etc. You can also keep the ones you make separate. It might
help down the line when you need to reload them or update them.
Eric
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Frank Jay
Sent: Friday, October 26, 2007 7:47 AM
hello,
epson printer page.
thanks
Frank
Do You Yahoo!?
http://mail. <http://mail.yahoo.com> yahoo.com
2007-10-26 by frankjay02
thanks
I have windows XP Media. I also have them in a separate folder
called "profiles". What I do, from what you said, is find the
profile>click install and they will install. Do I direct them to
install someplace or do they just install on their own to the epson
drivers.
thanks for the help
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen"
You can
applications you
to
download
them in a
Cranes,
It might
> Eric
> Suite 9
> Dallas, TX 75226
> Skype ejprinter
>   _____
Frank Jay
> hello,
for that
QTR or the
> epson printer page.
t get a
mentioned as
> thanks
> Frank
who
> Do You Yahoo!?
Frank, Right click on them, you may need to click one at a time, and select
install. That should put them in your XP color folder where they will be
seen by ICC compliant programs. Lightroom for one, was one of those programs
that required an "install" rather than just dropping it in the Color folder.
The settings that you want for the driver will have all those great Epson
names SP3800, or SPW 4800, stuff like that and those will tell the driver
how much ink to use and those are set in the properties tab in the driver.
Depending on the OS and printer you may want to make one a default or allow
the driver to select  auto.
Eric
Suite 9
Dallas, TX 75226
Skype ejprinter
  _____
frankjay02
Sent: Friday, October 26, 2007 10:00 AM
thanks
drivers.
thanks for the help
Frank
You can
applications you
to
download
them in a
Cranes,
It might
> Eric
> Suite 9
> Dallas, TX 75226
> http://e.neilsen. <http://e.neilsen.home.att.net> home.att.net
> http://ericneilsenp <http://ericneilsenphotography.com> hotography.com
> Skype ejprinter
> _____
Frank Jay
> hello,
for that
QTR or the
> epson printer page.
t get a
mentioned as
> thanks
> Frank
who
> Do You Yahoo!?
> http://mail. <http://mail. <http://mail.yahoo.com> yahoo.com> yahoo.com
Re: profile question
2007-10-27 by frankjay02
well Eric and all,
This is what I did
I downloaded the profiles from the Epson site.
They went right to my desktop and I had no control to put it in that
Windows/32/Color etc, folder
I right clicked them
.nothing that said install.
I clicked them
they unzipped and again I could not put them in that
Windows/32/Color etc folder. The fine art profile  went into
C:\epson\epson12364_r1800_icc_profiles_fine_art, and the other
profiles went into similarly named folders.
NOW to CS2
I go to Print with Preview and chose
Let PS determine
colors
Went to PRINT
Went to PROPERTIES
Went to ADVANCED
Another screen
choose PRESENTATION MATTE as my paper
Is THIS a profile???? I have been doing this for 5 years.
BUT,
If I go to ICM I do see in the last box
Printer Profiles and the
paper listed as
SPR1800 Photo Qlty IJP
If I click off ICM I have choices for Epson Vivid, Epson Standard,
or Adobe RGB.
What do I do here. Do I do anything here? Why didn't the profiles go
to the desktop and not that special Windows32/Drivers etc etc.
I am very very confused here folks. I get directions from people,
follow them and what I am directed to do doesn't work as it does for
others. There is NO book for this, NO manual, nothing. How are
people supposed to know what to do
I really don't want to buy another book just to learn profiles. I
have been printing from lower end printers for years, have sold many
many 8x10's and 11x14's and have been doing photography for almost
40 years and owned my own studio and custom black and white lab,
and. I have NEVER found anything that is supposed to be SO important
to have so little resources as to how utilize them (profiles).
Thakns for the help, any more help to get me out of this quagmire
will be appreciated.
Frank
and if I can ever get the QTR to show up and work, I will be doubly
happy.
and select
will be
those programs
Color folder.
great Epson
driver
driver.
or allow
> Eric
> Suite 9
> Dallas, TX 75226
> Skype ejprinter
>   _____
> frankjay02
> thanks
epson
> drivers.
> thanks for the help
> Frank
> You can
> applications you
need
> to
> download
keep
> them in a
River,
> Cranes,
separate.
> It might
> > Eric
> > Suite 9
> > Dallas, TX 75226
hotography.com
> > Skype ejprinter
> > _____
> Frank Jay
> > hello,
> for that
> QTR or the
> > epson printer page.
didn'
> t get a
> mentioned as
> > thanks
> > Frank
ones
> who
> > Do You Yahoo!?
yahoo.com
