Richard & Alex,
>Paul, are you working on any UT formulations and/or curves for the
>Epson 2000?
No.
>... Bulk ink availability would be fine...
There may be several mixes that would work OK in that, although old vm
curves for the PC are all I ever wrote for it.
>If MIS does not plan to make a set of compatible inks, I will stock up on
>the FSE. It works for me and my 2000P and have no need to change.
I don't think MIS will totally stop selling any of the inks as long as there
is reasonable demand. It will probably be in the "legacy" category.
I would think that it would be easy for MIS to make the UT-FSE inks in bulk.
It's the carts that I suspect might more likely be dropped at some point.
If the 1280 carts fit the 2000P, it might be interesting to see what the UT2
inks look like in it.
____________________________________
<paul.roark@v...> wrote:
> Alex,
> >Is there a Hex set based on UT inks which is a 1:1
> >replacement for the Non variable MIS inks as the FS-E?
> Not yet. MIS might make a full line of UT-based "FS" inks out, but
I'm not
> sure. MIS has a problem with too many different products. So, you
might
> see them try to limit the ink selection.
> Frankly, I think the FS-E approach (including the new Cone hextone
ink
> order) puts too much light ink in the mix. On matte paper, it is
smooth,
> but it also floods the papers. With glossy papers even the
standard UT ink
> can cause pooling of ink.
> So, it may be that MIS will decide not to replace all the older
inksets (at
> least those that are pre-loaded into cartridges) and, for example,
point
> most 1280 users to UT2. For older hextone printers, it may be that
a new
> UT-FSE will be available only in bulk -- but I'm speculating.
> Paul
> www.PaulRoark.com
> ______________________________________
> > My attempt to explain the UT2 inkset and workflow is at
> > http://www.inksupply.com/index.cfm?source=html/ut2comments.html
> > (MIS has it there, but it's a bit buried.)
> > Paul
> > www.PaulRoark.com
resources as
> If you wish to receive no emails or just a daily digest, or you
wish to
> unsubscribe, please edit your Membership preferences by visiting
this same
> page.
> - As threads develop, trim off excess portions of earlier messages
to keep
> them short.
flames.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> - Keep your posts and threads related to the group topic of digital
B&W
> printing. Users who persistently make off-topic posts may be
removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group
Owner and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
PRINT
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED
OF THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
INABILITY
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
CONDUCT OF ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY
OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
page.
them short.
the membership.
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
Yahoo! Groups Links
