Epson Gray Balancer Experience
2004-01-18 by Mike Bergen
Before buying ImagePrint I decided to try the Gray Balancer using the Kodak
Gray Scale method previously suggested by another member of this newsgroup.
So far I have had limited success and I have a question for this group.
The Gray Balancer is a stand alone program that takes control of the 2200
print drivers.  One first selects the paper type and then prints a built-in
grayscale and some sample images.  If this has no color cast than one is
done.  If there is a color cast than one prints out a set of color swatches
for 4 points on the scale.  Using the Kodak Gray scale you select the 4
swatches that best match the scale and enter a three digit number for each
swatch.  Then you print out a new grayscale with the corrected colors.  You
then iterate this process to fine tune the colors.
The question is, since this process does not allow the use of any of the
correction curves/profiles that one would apply in Photoshop, how does it
correct for a real image printed using the 2200 via Photoshop w/soft proof?
I have yet to be able to eliminate a slight green cast in the lighter
values.  I am using EEM.
Any comments would be appreciated.
Mike
Re: Epson Gray Balancer Experience
2004-01-19 by njfranknj
I've only started playing with the Gray Balancer for other reasons
(compare to my Photoshop Duotone/Quadtone method), but it seems like
you could just refer to the 4 tone "fish scale" test print that the
GB produces and select one of the minus-green (magenta) sets of
values as input to correct your green cast. Do this repeatedly with a
test image until you are satisfied the the green tint is gone.
Frank
of the
does it
w/soft proof?
lighter
> Mike
2004-01-19 by Tony Bonanno
Mike,
I can't explain how the GB software interfaces with the Epson
profiles, but it apparently does as I get drastically different
output if I accidently select the wrong paper profile.  I have the
GB software "on" all the time for both my B&W and color work.  I
have pretty much eliminated the green cast and other significant
color cast from my B&W using EEM paper.  I have to admit, it was a
lot of trial and error.  It's not perfect, but it is a HUGE
improvement over what I was able to obtain just using the Epson
profiles without the GB.  You may want to refer to a previous post I
made on this topic.. message number 40176.  By the way, the accuracy
of my color output was noticeably improved also. Good luck!
Tony Bonanno
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mike Bergen"
the Kodak
newsgroup.
group.
the 2200
built-in
one is
swatches
the 4
for each
colors.  You
of the
does it
w/soft proof?
lighter
> Mike
2004-01-19 by Bill Schwab
"I have yet to be able to eliminate a slight green
cast in the lighter values."
Mike,
You won't ever be able to remove the green cast or
"metamerism" completely. I have blown a lot of time
and media working with Epson's Gray Balancer and it is
my opinion that it is impossible to get a neutral
black and white print out of the 2200 without going to
carbon pigments or printing black only. Even if you
take what you think is your closest print from under
incandescent light to daylight. The evil green will
appear. The best thing I did was to give up trying and
go to quadtones for my B&W.
Good Luck,
Bill
www.billschwab.com
Do you Yahoo!?
Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
http://hotjobs.sweepstakes.yahoo.com/signingbonus
2004-01-19 by Mark Hahn
I would agree that it is hopeless... at least to be neutral across
all lighting... you may balance it good enough for one specific
lighting condition, but any changes will bring out the green (or
magenta) cast.
sorry,
mark
PS  Image Print does fix it though...
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Bill Schwab
> Mike,
> Good Luck,
> Bill
> www.billschwab.com
> Do you Yahoo!?
RE: [Digital BW] Re: Epson Gray Balancer Experience
2004-01-20 by Robbe Gibson
I have been using the Colorburst RIP demo since Friday. It seems to
pretty much eliminate the color cast (going from daylight to
incandescent) as well as producing a much-improved print in general. The
significantly faster print speed is an added bonus. (7600UC) There's a
limited choice in grey profiles, but even using the color profiles,
printing a greyscale image is much better than the Epson driver.
Robbe Gibson
Sent: Monday, January 19, 2004 3:53 PM
Subject: [Digital BW] Re: Epson Gray Balancer Experience
magenta) cast.
sorry,
mark
> Mike,
> Good Luck,
> Bill
> www.billschwab.com
> Do you Yahoo!?
Please visit the Group Homepage to check the Files, and other resources
as they are often being updated.
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
membership without notice.
printing. Users who persistently make off-topic posts may be removed
from the membership.
guidelines, and to abide by the actions and decisions of the group Owner
and Moderators. See “Group Topic, Rules and Guidelines” in the Files
section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
“OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE PRINT YAHOO GROUP.
Yahoo! Groups Links
To visit your group on the web, go to:
Your use of Yahoo! Groups is subject to:
 http://docs.yahoo.com/info/terms/
2004-01-20 by Tom Baker
How does the price of the Colorburst RIP compare to IP for the 7600?
Tom Baker
Robbe Gibson
magenta) cast.
sorry,
mark
> Mike,
> Good Luck,
> Bill
> www.billschwab.com
> Do you Yahoo!?
same page.
keep them short.
and Moderators. See �Group Topic, Rules and Guidelines� in the Files
section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND
�MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
�OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
Yahoo! Groups Links
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See �Group Topic, Rules and Guidelines� in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
For the 7600, Colorburst w/o Postscript is $795, w/Postscript $995. No
yearly maintenance contracts.  Image Print is $1495 plus $500/year
maintenance.
Robbe Gibson
Sent: Monday, January 19, 2004 4:55 PM
Subject: RE: [Digital BW] Re: Epson Gray Balancer Experience
Tom Baker
Robbe Gibson
magenta) cast.
sorry,
mark
> Mike,
> Good Luck,
> Bill
> www.billschwab.com
> Do you Yahoo!?
same page.
keep them short.
section:
Yahoo! Groups Links
same page.
keep them short.
section:
Yahoo! Groups Links
same page.
keep them short.
section:
Yahoo! Groups Links
