7660 can't handle grain????
2004-02-17 by Mark Hahn
Ok, ...I guess they say that when something sounds too good to be
true...
Have made a bunch of b&w prints with my new hp 7660.  All the smooth
tone digital images print out near perfectly, but from film scans
the "woven" dither pattern somehow blends with the random scatter of
the grain and produces a hidious pattern of perceptible soft
gridlines which almost look like microbanding.  Looking at the prints
under a loupe shows that it is some interaction between the grain
pattern and the dither pattern however.  The problem manifests itself
most in something like a face in a portrait or other smoothly shaded
objects and vanishes in more texture rich images or grain free
images.  By comparison, the posterization issues with my 1160 seem
rather mild now.  I've tried upsampling to printer resolution prior
to printings which changes the output, but doesn't correct it.
Anyone else seeing this?  Anyone have a solution?  Unless I figure
out a work around I will be returning the printer as the output from
T400CN scans are not suitible for hanging in a gallery.
thanks for any advice,
mark
Re: 7660 can't handle grain????
2004-02-17 by Tyler Boley
More info. What driver? Quads or color? Never heard of this with a
x600 printer so it should be able to be resolved. No such problems
here with a 9600, same technology.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Hahn"
> true...
> mark
It is the hp driver supplied with the 7660 using the #59 gray
cartridge.  maybe I can post some examples tonight.  the "lines" are
certainly not in the digital image and most definitely are in the
print.  I would be happy to have just gotten a defective printer, but
as I said, under a loupe everything looks fine which makes it seem
like a driver limitation.
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
> Tyler
> > true...
smooth
of
prints
itself
shaded
seem
prior
figure
from
> > mark
PS  More info: I saw the problem in a 6x9" print on hp Premium Plus
glossy with a starting print resolution of about 400dpi and then
tried upsampleing to 600dpi.  I also tried printint in both "Best"
mode (600dpi) and "Max DPI" (600x4800dpi I believe).
mark
> Tyler
> > true...
smooth
of
prints
itself
shaded
seem
prior
figure
from
> > mark
2004-02-18 by Tyler Boley
Sorry, I misread your post. Automatically saw 7600 instead of 7660 and
assumed Epson. I briefly saw cannon output under a loupe once and
noticed a gridlike pattern.
Sorry I can't really offer any suggestions.
Tyler
> mark
> > Tyler
> > > true...
> smooth
> of
> prints
> itself
> shaded
> seem
> prior
> figure
> from
> > > mark
2004-02-19 by Radimus
Hi, Mark.  What print quality setting are you using?  I just cranked
out a B&W print on HP PPPG with the quality setting at Best and it has
what looks like microbanding going vertically across the print (the
print is landscape oriented).  Examining it with a loupe it is
actually a weave pattern.  Without a loupe it has the look that you
describe below.  However, with the quality set to "Maximum dpi" the
pattern goes away, but there is now an even finer microbanding going
horizontal to the print.  However, this artifact is only noticable to
me if I practically stick my nose in the print.
Rad
> true...
> mark
update: Re: 7660 can't handle grain????
2004-02-19 by Mark Hahn
I tried both, first the max, then the best, then upsampling to
printer resolution... in each case it *changed* the problem, but
didn't get rid of it.
Anyway, after hours of frustration by myself and then two hours of
frustration with tech support I returned the print, BUT I ended up
learning a few things about these printers that may be helpful.
First thing, the printer's calibration routine is not that good.  If
you get banding after the automatic calibration, a second or third
calibration can make it better.  Makes me think that the calibration
is some sort of initial condition limited control loop cycle so it is
hit or miss whether one calibration will actually get you as "good as
it gets."  Second, there is an transparent acetate optical tracking
band that has to be clean so the print heads know where they are.  A
damp q-tip is all it takes to clean this up and it adds to the
printer's accuracy.  Third, hp is apparently shipping a lot of bad
#59 b&w carts.  After returning my 7660 to the store I went and
tested the floor models 7660 and 7960 just to see if there really was
some difference with b&w.  I used my newest cartridge which actually
gave horizontal banding at home and guess what, the store's 7660 and
7960 both banded like old one so it seems that the real problem with
my printer was that I had purchased two bad cartridges (from two
different stores miles apart!).  As to differences, the 7960 looked
much worse which I think dispells the rumors that b&w is better from
the 7960.
HP said they will ship out some fresh carts so I am going to try
again with a new 7660 this weekend.
So the moral of the story is that we still don't have hassle-free b&w
unless we spend big bucks:(
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Radimus"
has
to
> Rad
> > true...
smooth
of
prints
itself
shaded
seem
prior
figure
from
> > mark
I'll try some of those tricks on my 7660 and see what happens.  I'm
interested to hear how things go when you get the new cartridges and
printer this weekend.
Rad
> the 7960.
> mark
> has
> to
> > Rad
> > > true...
> smooth
> of
> prints
> itself
> shaded
> seem
> prior
> figure
> from
> > > mark
2004-02-20 by Radimus
On my 7660 I ran a calibration and three cleanings.  My findings have
not changed very much.  With the quality setting at Best under a loupe
I see a herring-bone pattern of which an example can be seen on the
left here:
http://www.photo.net/comments/attachment/443167/printClose.jpg
With the quality setting to Maximum dpi my output looks very much like
 the sample on the right.  Here's another example of what I see on my
prints at max dpi:
http://www.photo.net/equipment/hp/hp7960/grayscalecompare1.jpg
As you can see in that example, there is a definite pattern compared
to the Canon sample.  What I'm seeing on my prints is that the pattern
will appear as extremely fine microbanding.  And I mean extremely
fine.  I need to view the print from 5 inches away to actually see it.
Something else I found is that the high resolution of this printer
will bite you in the backside if you are printing from film scans and
have oversharpened the image and/or have hairline scratches in the
negative.  The former making the latter worse, obviously.
Rad
> Rad
> > the 7960.
> > mark
> > has
> > to
> > > Rad
> > > > true...
> > smooth
> > of
> > prints
> > itself
> > shaded
> > seem
> > prior
> > figure
> > from
> > > > mark
examples posted: update: Re: 7660 can't handle grain????
2004-02-20 by Mark Hahn
here is a link to a page showing the specific problems I had with my
7660:
http://www.geocities.com/markhahn2000/7660test.html
examining samples that two list members sent to me shows no evidence
of this type of problem.
mark
have
loupe
> left here:
like
my
> prints at max dpi:
pattern
it.
and
> Rad
I'm
and
> > Rad
but
of
up
helpful.
good.  If
third
calibration
it is
as "good as
tracking
are.  A
bad
really was
actually
7660 and
with
two
looked
from
> > > the 7960.
try
free b&w
> > > mark
cranked
and it
> > > has
print (the
that you
dpi" the
microbanding going
noticable
> > > to
> > > > Rad
Hahn"
to be
> > > > > true...
> > > smooth
scans
scatter
> > > of
soft
> > > prints
grain
manifests
> > > itself
smoothly
> > > shaded
free
1160
> > > seem
resolution
> > > prior
it.
> > > figure
output
> > > from
> > > > > mark
2004-02-21 by Clayton Jones
Hello Mark,
>7660:
I have several 7660 samples that someone sent to me, both cart
combinations on several papers, and the cross-hatch dither banding
appears in all of them, to varying degrees.  It requires a loupe to
see it.
Clayton
2004-02-21 by Mark Hahn
These problems did not take a loupe to see.  They were very visible
to everyone I showed them to.  I also got samples from a couple
people and I do not see anything like this in any of their prints.
As I said, the first digital source prints looked great, it was just
the film scan prints, but I certainly can't take those to my gallery
now can I?  Maybe the driver just can't handle grain, I don't know.
Someone offered to print my image on their 7660 to see if they get
the same results... I'll wait and see before buying a new printer.
These are supposed to be higher resolution printers than my 1160 so
there shouldn't be visible banding (right?), at least I wouldn't
expect so, but my best 1160 prints can hang under gallery lighting
and not be spotted as inkjet.  I was expecting the same from this
printer... only without the hassles.
mark
my
> >7660:
> see it.
2004-02-21 by Paul Murphy
Hi Mark,
Sorry to hear you are having these problems with the HP 7660. I went
back to have a look at prints I made from this printer and yes I am
getting the cross hatch dither banding, but its only visible under a
4x loupe. It is virtually impossible to see with the naked eye and
certainly invisible under glass. All my prints came from images shot
on a Canon 10D.
Having read that your problems were with scanned images I went to my
filing cabinet and pulled out some older shots that I had previously
scanned on a Nikon 4000. I included shots with sky areas that have a
fair bit of visible grain. These prints were no different to the
digital source prints, they exhibited the same minute banding visible
only under a loupe.
I have noticed that different papers show it more or less clearly
than others. If the paper has a slight texture to it (Ilford Pearl)
it becomes part of the texture. On the HP paper it looks very uniform
but still could be mistaken for paper texture.
For me the banding falls into acceptable limits. However I was just
thinking that I am on the original grey cartridge I installed when I
got the printer. It's almost empty. Got alot of prints out of it. I
will have to check again when I install a new one. If I do see the
problems you are having I will post details here.
Paul.
just
gallery
know.
> mark
with
> my
> > >7660:
to
> > see it.
RE: [Digital BW] Re: 7660 can't handle grain????
2004-02-21 by Ed Mathews
I'm sorry I didn't get into this discussion earlier.  I've been
swamped with work (sometimes real life gets in the way).
     I have a 7960 and this problem with the dither pattern that looks
like banding has been discussed at length on the printing board at
dpreview:
http://forums.dpreview.com/forums/forum.asp?forum=1003
     The problem with the 7960, which I would assume is the same problem
with the 7660, is that the driver over sharpens the image causing the
pattern.  HP is well aware of it and several people have been in contact
with them.  They have responded that they are working on a driver update
that will correct the issue, but it is not available yet.  With my 7960,
the pattern is "usually" only visible with a loupe, so I'm in no big
hurry for the fix.
     I have printed both digital images and scanned 35mm negatives, and
I see the pattern in both, but it is not any more pronounced in the
scanned images with my particular set-up.  Overall, my experience is
quite similar to that of Paul Murphy:  Usually visible with a loupe
only; uniform; looking like a texture; and more visible on some papers
than others.
     You may also want to check out this site:
http://www.photo-i.co.uk/
     There is a review of the 7960 there where they show the over
sharpening dither pattern as well.
     My guess would be that since this is a driver problem with the 7960
(and probably the 7660), it may be more pronounced on some OS/hardware
combinations than others, and it might be more of an issue with certain
digital files - depending on the origin and processing of the scan.  So
we see once again, as with the Epson printers, there is no definitive
way to predict exact results when there are so many software/hardware
combinations out there.
Ed
http://lightandsilver.com
