Eboni Black questions
2004-02-26 by luisvcool
Hello.  I have an Epson 2200 and a Mac with OSX10.3.2
I have seen a few posts where people say that Eboni Black has a higher Dmax on EEM than
Epson's MK.  This is true ONLY for EEM?
Can one substitue just Epson's MK cartridge for Eboni Black and make B&W and color
prints without substituting the rest of Epson's color cartridges?  If one can leave the Eboni
Black for making color prints with the rest of the Epson color cartridges, then new paper
profiles are needed?
Thanks.
Re: Eboni Black questions
2004-02-26 by chipcarterdc
I just asked the same question below (among other things) -- hadn't seen your
post.  Hopefully we'll get some input...
2004-02-27 by Clayton Jones
>I have an Epson 2200...
>a higher Dmax on EEM than Epson's MK.
I use Eboni in a 2200.  I don't know about instrument-measured Dmax
compared to MK, but Eboni is cooler in color.  They both have
excellent Dmax - to my eye they look equally intense, but the MK is
warmer.  Perhaps someone with a densitometer will pop in here...
I have found it also true with PhotoRag.
>make B&W and color prints without substituting the rest of
Yes, I have done it, just to see what happened, and it made a very
nice color print.  However, I do almost no color, so I'm not one to
judge how well the Eboni works in color prints compared to MK.
>If one can leave the Eboni Black for making color prints with
I don't know about that one, but I would guess "yes" because of MK's
warmer color.
I do Black Only printing with the Eboni and just leave the other carts
alone.  The 2200 does a fine job with that and the Eboni is gorgeous
stuff.
Clayton
2004-02-27 by chipcarterdc
So, any other follow-up on this?  Is anyone doing full color printing w. the
Eboni black installed, and, if so, do you just use the Epson profiles or are
custom profiles needed?
And, a question from my other post: how does the Eboni black look on glossy/
luster papers and how well (if at all) does it adhere to such papers?  (Either
printing w. just the Eboni black on glossy/luster or full color w. the Eboni black
installed)
> warmer color.
> stuff.
> Regards,
> Clayton
Re: [Digital BW] Re: Eboni Black questions
2004-02-27 by Richard Sintchak
Friday, February 27, 2004, 7:17:15 AM, you wrote:
c> So, any other follow-up on this?  Is anyone doing full color printing w. the
c> Eboni black installed, and, if so, do you just use the Epson profiles or are
c> custom profiles needed?
Yes, I print color on my 2200 with eboni black installed and it looks
pretty good.  On matte papers that is.  No special profiles used.
c> And, a question from my other post: how does the Eboni black look on glossy/
c> luster papers and how well (if at all) does it adhere to such papers?  (Either
c> printing w. just the Eboni black on glossy/luster or full color w. the Eboni black
c> installed)
On glossy is it bad.  The ink simply was not made to be printed on
glossy and it is sure evident of that when you try.
Best regards,
 Richard                            mailto:richard@...
2004-02-27 by Steve Kale
Have you tried spraying the print?
Steve
glossy/
(Either
Eboni black
c> installed)
Best regards,
You should remake your profiles.  I have a CFS from MIS with Eboni black and
intend to use Eboni for colour also.  I will redo my profiles.  But I am not
going to install it until I have used up my Epson OEM inks.
Steve
<So, any other follow-up on this?  Is anyone doing full color printing w.
custom profiles needed?>
Re[2]: [Digital BW] Re: Eboni Black questions
Friday, February 27, 2004, 7:27:57 AM, you wrote:
SK> Have you tried spraying the print?
SK> Steve
c>> And, a question from my other post: how does the Eboni black look on
SK> glossy/
c>> luster papers and how well (if at all) does it adhere to such papers?
SK> (Either
c>> printing w. just the Eboni black on glossy/luster or full color w. the
SK> Eboni black
c>> installed)
SK> On glossy is it bad.  The ink simply was not made to be printed on
SK> glossy and it is sure evident of that when you try.
I do not think it's a matter of spraying as the eboni ink on glossy I
find just dull and lifeless. I guess spraying might help for that. As
a comparison I found MIS FS-N inks to look pretty good on glossy when
I used that in my 1160. It just smudged easily. Spraying that solved
that problem. With eboni on glossy it just looked so bad from the
get-go that I dropped the idea after my first try. Not sure why as I
did not think the eboni was that different than the FS-N formula in
terms of how the ink sits.
Best regards,
Re: Re[2]: [Digital BW] Re: Eboni Black questions
I am surprised by your comments given the success people have had with BO
printing on semi-gloss with Eboni (the spray was simply to fix the ink and
stop it from rubbing off).  I would have thought that if BO printing with
Eboni on semi-gloss was good then colour printing on semi-gloss using Eboni
black would be good also.
Steve
<I do not think it's a matter of spraying as the eboni ink on glossy I
terms of how the ink sits.>
Newspaper photos
2004-02-27 by Janet Redhawk
Anyone take pix for a newspaper or bi-weekly
publiction?
What did you charge them?
J
http://www.redhawkphoto.com
Do you Yahoo!?
Get better spam protection with Yahoo! Mail.
http://antispam.yahoo.com/tools
2004-02-27 by D. Hill
At times when I need a color print I run the MIS
Glossy Pigment inks with Eboni in my 1280 on matte
papers.  I use the profiles downloadable from MIS and
have acheived excellent results.
Don
Do you Yahoo!?
RE: [Digital BW] Newspaper photos
2004-02-28 by Seth Rossman
It's $275 for a short job; $450 1/2 day; $700 day.
Seth
=-----Original Message-----
=From: Janet Redhawk [mailto:cyberdyke_1@...]
=Sent: Friday, February 27, 2004 1:22 PM
=To: DigitalBlackandWhiteThePrint@yahoogroups.com
=Subject: [Digital BW] Newspaper photos
=Anyone take pix for a newspaper or bi-weekly
=publiction?
=What did you charge them?
=J
=http://www.redhawkphoto.com
=__________________________________
=Do you Yahoo!?
=Get better spam protection with Yahoo! Mail.
=http://antispam.yahoo.com/tools
=Please visit the Group Homepage to check the Files, and other
=resources as they are often being updated.
=http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
=If you wish to receive no emails or just a daily digest, or
=you wish to unsubscribe, please edit your Membership
=preferences by visiting this same page.
=Please follow these basic guidelines:
=- As threads develop, trim off excess portions of earlier
=messages to keep them short.
=- Good manners are required at all time. No personal attacks
=or flames. Hostile, aggressive or argumentative users may be
=removed from the membership without notice.
=- Keep your posts and threads related to the group topic of
=digital B&W printing. Users who persistently make off-topic
=posts may be removed from the membership.
=- By posting on this forum you agree to abide by the group
=rules and guidelines, and to abide by the actions and
=decisions of the group Owner and Moderators. See "Group Topic,
=Rules and Guidelines" in the Files section:
=http://groups.yahoo.com/group/DigitalBlackandWh=iteThePrint/file
=s/
=BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
=THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT
=THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO
=GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT,
=INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES,
=INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
=GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
="OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP
=HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
=RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE
=DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
=OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS
=OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
=YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL
=BW, THE PRINT YAHOO GROUP.
=Yahoo! Groups Links
