Is anyone using Sundance Septone?
2004-02-27 by Wayne Firth
I recently purchased Septone from BW Guys to use in an Epson 2200.
After three days effort I still cannot get anything close to
acceptable nozzle tests. I contacted BW Guys and they immediately sent
me a stock email with instructions for a standard windex type
cleaning. This didn't work. Apparently, the ink is thinner than the
Epson ink and the cleaning cycles create foam. There is no way to
prevent the cleaning cycles. The printer insists on cleaning either
when it is plugged in or when it prints a nozzle test.
Has anyone else encountered this problem? Does anyone have any
suggestions. BW Guys doesn't seem to provide much support for their
product. It is just about impossible to get any information about this
system.
Please no lectures about getting Imageprint. I have Imageprint but
since I got a new computer Imageprint refuses to print and that is why
I am trying something else.
Wayne Firth
Re: Is anyone using Sundance Septone?
2004-02-27 by Jim
Hi Wayne,
Everytime you run the cleaning cycle, you need to wait for at least
10 minutes for the foam to settle. Don't do anything after the
cleaning cycle and wait for 15 mins, then do a nozzle print to see if
it is alright.
Another thing that will cause the problem is the capping station(the
sponge where the print head rests when it is not printing). Everytime
you run a cleaning cycle, ink starts to puddle up in the capping
station. It will give you the problem of getting a good nozzle check.
It can be cleaned by using a paper towel to soak up the ink in the
capping station and then put a small piece of paper towel on the
capping station and move the print head to the capping station for a
minute or so. After 3 cleaning cycles and you can't get a good nozzle
check, try this. You will see the difference.
However, if you really like the Septone, I suggest you to get a
Niagara CIS system for the Septone ink. It works really fine on my
2200 without any nozzle problem so far. The pressure inside the
Septone cartridge is different and causes a lot of problem and the
ink runs out fast!!! I used to use the Septone cartridges and it's a
pain. I received some recommendations from other Septone users and
decided to buy the CIS system. It's a little expensive but it works
great.
Good luck
Jim
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Wayne Firth"
sent
this
> system.
why
> Wayne Firth
2004-02-27 by Yeung-Seu Yoon
Hello Wayne Firth
I saw your post regarding septone inks.  I use them with a CIS,
but when I started with the non-CIS cartridges, I had the exact
same problem as you.  It was very, very difficult to get clean
nozzle checks with the disposable cartridges.  I used up 3 very
expensive sets trying  The inks really are very thin and form
bubbles extremely easily.  (If you even nudge a bulk-bottle of ink,
you can see a huge bubble cluster form, and it takes ages to
disappear).  However, the occasional good nozzle check
provided an absolutely stellar print, much better than anything I
had seen before, so I sort of recklessly took a flying leap off the
pier and bought the CIS, about 4 months ago.  The nozzle
checks since then have been uniformly flawless.  Apparently the
CIS bottles keep the ink under higher pressure, and so bubble
formation is suppressed.   My suggestion is that if you want the
septone system, don't  do what I did  and waste any further time
or money with the individual cartridges--just jump ahead with
the CIS.  The prints that come out are so breathtakingly lovely
and consistent that you'll forget about the temporary big dent in
your wallet--
I'd be happy to answer any other questions if you have them.
Cheers, and kindest  regards
Yeung-Seu Yoon
Toronto, Canada
2004-02-27 by mfp90021
Yes, I am using Septone with a 9600 and have had it for about 4
months now.  I love it and
have found the BW Guys to have excellent tech support.  Every time
I've called they've
either answered the phone or have called me back within an hour.  The
only time I've had
clogging problems was when I didn't use it for three weeks.  I called
BW Guys and they told
me how to do a power clean (a maintenance cycle of the 9600 not well
documented in the
manual) and the clogging disappeared.
www.michaelfaye.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Wayne Firth"
<wfirth@s...>
sent
this
> system.
why
> Wayne Firth
Hi Jim,
Thanks very much for your reply. This is just the type of information
that I am looking for.
I did wait after the cleaning and I blotted the cap sponge but then
when I do the test again or when I plug the printer in, the printer
does another cleaning cycle on its own and defeats my previous good
deed. I also did the paper towel thing and parked the heads. I don't
doubt that all of this would work if I could just get the printer to
stop doing these cleanings that I don't ask for.
I managed to get one test print when six heads were briefly working at
about 50% and one head was doing nothing. Even with that problem I
could see that the print would be wonderful if I could get the ink to
work. I don't want to give up on this system because of the smoothness
of the image.
It's good to know that the system works with the continuous feed. The
ink carts do not last long at all. I have emptied one set already just
trying to clear the heads. Thanks for the advice. I will look into the
CIS.
Thanks again for the help.
Wayne
> great.
> Good luck
> Jim
2004-02-27 by Alan Zinn
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Yeung-Seu Yoon"
<yeungseuyoon@y...> wrote:
> Hello Wayne Firth
ink,
> your wallet--
> Yeung-Seu Yoon
> Toronto, Canada
Yeung,
Your helpful message came just in time today - I was going mad with
re-filled carts on my 1280, - ink slopping about as described by
Wayne. Guess I should hook up a CIS. Just wondering - anyone know if
the MIS UT2 inks are "thinner" than stock inks?  Just yesterday I was
bragging about how well my printing was going with these inks :-)
AZ
Build a Lookaround!
The Lookaround Book, 2nd ed.
NOW SHIPPING
http://www.panoramacamera.us
Hello Yeung-Seu Yoon,
Thank you very much for the information. That is just what I needed to
know. I had a feeling that I was chasing my tail with all of those
cleaning routines. I would hate to give up the print quality that I
have seen from this system. I just want to make prints.
It's good to know that an investment in the CIS will not be throwing
good money after bad. Thanks for the advice.
Wayne
> Hello Wayne Firth
> your wallet--
> Yeung-Seu Yoon
> Toronto, Canada
Michael,
Thanks for the information. One reason I am trying to get this to work
on the 2200 is to get some experience with their system and if all
goes well, I would like to convert a 7000 to quadtone.
I will give them the benefit of the doubt about service and try to
contact them again.
Wayne
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mfp90021"
> I've called they've
> only time I've had
> documented in the
> www.michaelfaye.com
> <wfirth@s...>
> sent
> this
> > system.
> why
> > Wayne Firth
