Re: BO Printing Epson 2200 (for Clayton)
2004-02-29 by grdglass@aol.com
Hi Clayton, I played around with BO on Ultrasmooth/PremierArt. I had no contrast problems, perhaps because of my workflow. I have been using ImagePrint and work in Photoshop CS as Untagged Gray. Before printing in IP, I assign Gray Gamma 2.2. I did the same in BO and found them to match my IP prints exactly. Since Gray Gamma 2.2 adds more contast to the image, I imagine that this is similar to your adjustment curve approach. I used the Epson ink for my experiments. (Have not ordered Eboni Black yet.) Why do you recommend MIS Eboni? Can your BO approach be used on glossy papers also? There seems to be a difference of opinions on that issue. If so, which black do you recommend? I am planning on the Epson 4000 and would assume BO would even be better on that model. It would be nice not to incur the extra cost for the IP upgrade. So far, I am finding BO terrific. Thanks for your hard work. Helene >Anybody using BO printing on the 2200 with Eboni Black on >Ultrasmooth paper? >How do the results on Ultrasmooth compare with other papers >you have used? I have tried it with the Premier Art Hot Press which (I think) Paul Roark says is the same as Ultrasmooth. It's very nice paper, but I found it to have less contrast than the EEM and PhotoRag papers which have been my standards for a long time. I needed to apply an adjustment curve to the image to make it match the print on the other papers. [Non-text portions of this message have been removed]
