How does William Turner compare to PhotoRag?
2004-05-09 by John Vitollo
Hi all,
I've read descriptions of William Turner on a few vendor sites and some mention WT is
smooth and some say it rough...it gets confusing! I even downloaded the PDFs from Hmule
and it's not clear.
Can anyone with first hand knowledge describe how WT compares to PhotoRag and likes
and dislikes?
I'm using QTR with an  Epson 890 UT2 inks.
Many Thanks,
John V.
Re: How does William Turner compare to PhotoRag?
2004-05-09 by Tyler Boley
I've seen it described as smooth too, very misleading. It's probably
the coarsest tooth I've seen on a coated inkjet paper. It's not
whitened like PhotoRag so not as bright, but not nearly as warm as
German Etching. Given all that, it's my favorite paper. Dmax like
PhotoRag, without the card-like smooth surface and screaming white, it
has a character that adds in a way I like. Looks beautiful with
Steve's Xray floral images, particularly large, and I like it for
straight large format landscapes. The surface does not take away from
fine detail.
If only that tooth were knocked down a bit, more like Somerset, it
just might be perfect.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo"
<jvlist@c...> wrote:
> Hi all,
some mention WT is
the PDFs from Hmule
> and it's not clear.
PhotoRag and likes
> and dislikes?
> Many Thanks,
> John V.
> Tyler
Tyler,
I'm not a big fan of Somerset Velvet - it the surface hard "coated" or "velvety" like
Somerset Velvet?
John V
or "velvety" like
> Somerset Velvet?
John, not exactly sure I know what you're asking. It is coated, as the
other H papers. Somerset Velvet does have a softer feel, but Turner is
definitely more textured and could be described as "harder" I suppose.
Some people described it as having a sandpaper feel, I wouldn't go
that far. More like a cold press watercolor paper I guess.
I think you might have to actually see the stuff, if you like smooth,
you won't like it.
Tyler
Re: [Digital BW] Re: How does William Turner compare to PhotoRag?
2004-05-09 by James Irelan
Tyler,
I'm curious as to what you think of Torchon.  It was always my favorite
paper, although its very figured surface, beautiful on its own and
which disappears in colored areas, could be noticeable and therefore
distracting in very light expanses such as a pale sky.  The only reason
I stopped using it and have been looking for a replacement ever since
was its propensity to "flake", leaving white spots which are nearly
impossible to spot.  Brushing off the surface before printing does
improve one's odds for avoiding "flaking" (I've never been convinced
that something actually flakes off, because I've looked very carefully,
and never found a loose flake), but still, it's disheartening to print
a big print, especially, and find white spots.  But I've always got the
best reds with this paper.  Also, what is your reaction to Entrada?
Mine is that it looks very good with proper profiling, but it is more
difficult to profile than other papers.  And I've even seen some
flaking with it- not as bad as Hana papers, but occasionally- which
makes me suspect that the very dry conditions under which I print may
be part of the equation.
James
2004-05-10 by Tyler Boley
Flaking is the big problem with all of these papers. Torchon
definitely, all the H papers. There were reports of strange longevity
problems with Torchon, prints turning yellow, etc.. I was always sort
of attracted to it, except for it's extreme brightness. Maybe some
component added for that bright white added to the problems. So other
than a few quick tests I haven't worked with it. But I think that
large smooth rolling texture could be nice with large prints, maybe
overwhelm small prints. Impressive blacks.
The Entrada samples I tried were attractive, but I couldn't, again,
get a competative Dmax on it with the Piezotone inks I use. I think it
could be great with work that doesn't rely on a strong black.
I'm afraid I don't know how humidity may impact the flacking but It's
a real hassle. I recently made some prints for someone, the image had
a lot of black and very dark grays everywhere. He wanted PhotoRag. If
you brush it, you clearly see the brush strokes in large smooth dark
areas. After lots of failed prints, I got some keepers by gently
wiping the paper with a soft cloth so you couldn't see the wiping,
than had to quickly spray the resulting prints with Print Guard.
Spraying a lot of prints is definitely something I don't want to get
into. Interestingly, harder wiping (which may more effectively reduce
flacking) eliminated so much coating the Dmax went way down. Not good
for the particular image. Maybe wiping Torchon would be a better solution.
Hana claims to have changed the coating to fix flaking, but I've also
heard there is so much of the old on shelves everywhere we may not see
that for some time. That's just a rumor.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, James Irelan
<james@r...> wrote:
> Tyler,
> James
RE: [Digital BW] Re: How does William Turner compare to PhotoRag?
2004-05-10 by Jim Doyle
Hi Tyler,
Just a quick note Hahnemuhle Is coming out in the next month withal New
Paper One Of several To be released..
It will be called White Velvet 268gsm And Its Just Like Somerset velvet Just
a little different But Boy its going to compete..
The Other New One's are going to be an OBA Free Photo Rag & A New Canvass
If anybody has questions Please email or call me anytime..
Cheers
Jim Doyle
J.Doyle Enterprises L.L.C.
114 Old Orchard Rd.
Cherry Hill, NJ 08003
856-424-8660
http://www.shadesofpaper.com
  Sent: Sunday, May 09, 2004 6:44 PM
  Subject: [Digital BW] Re: How does William Turner compare to PhotoRag?
  fine detail.
  Tyler
  > Hi all,
  some mention WT is
  the PDFs from Hmule
  > and it's not clear.
  PhotoRag and likes
  > and dislikes?
  > Many Thanks,
  > John V.
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
Oh What The Heck..
Email Me off list And I'll Send you a sample of William Turner 190 For
Free..
Cheers
Jim Doyle
114 Old Orchard Rd.
856-424-8660
  Sent: Sunday, May 09, 2004 7:32 PM
  --- In DigitalBlackandWhiteThePrint@...m, "John Vitollo"
  or "velvety" like
  > Somerset Velvet?
  you won't like it.
  Tyler
page.
them short.
the membership.
  Yahoo! Groups Links
2004-05-10 by James Irelan
With my current 7600 failure problem, which still hasn't been resolved,
I've gone back to my 1160s, one of which has Fotonics in it, which I
had installed but had never used yet for anything serious.  Because I
have a project in the works where I'm waiting for the client to choose
which photos they want, and will then will require keeper prints, I
thought I better make the best of things, so I profiled the Fotonics on
Entrada, and am getting just amazingly good prints.  In fact, I spoke
to Lyson last week, and asked them if they have a set of Fotonics for
the 7600, and it turns out that they're just coming out with one.  My
thinking is that given the problem I've had with the Cave Paints, if I
do replace the head etc on the 7600, what ink do I then use?  Try again
with the CavePaints? Lyson says they've not had the problem I've had,
but I certainly have had it.  Coincidence?  The CavePaints?  I can't
know for sure.  They are also coming out with a paper which they
describe as having a surface similar to traditional fiber-based photo
paper, the purpose of which is to improve the archival prospects to
approx 100 years with the Fotonics.  They say they are just waiting for
the American sizes to be prepared.  Sounds like an awfully attractive
prospect, but of course we all know how some of these things pan out in
reality. What I forgot to ask is if the paper is an RC paper.   But
Fontonics with even greater longevity would be hard to beat.  Even now,
they're probably 25-30 years, which would outlive me.
James
Jim, this is outstanding news! Exactly what I've been looking for for
years, and I know others as well. OBA free PRag sounds like a great
option as well.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jim Doyle"
<jdoyle1713@c...> wrote:
> Hi Tyler,
velvet Just
Canvass
> Cheers
> Jim Doyle
> 114 Old Orchard Rd.
> 856-424-8660
>   -----Original Message-----
>   From: Tyler Boley [mailto:tyler@t...]
>   fine detail.
>   Tyler
>   > Hi all,
>   some mention WT is
>   the PDFs from Hmule
>   > and it's not clear.
>   PhotoRag and likes
>   > and dislikes?
>   > Many Thanks,
>   > John V.
resources as
wish to
this same
> page.
to keep
> them short.
flames.
digital B&W
from
> the membership.
Owner and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
PRINT
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
EXEMPLARY
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
>               ADVERTISEMENT
>   Yahoo! Groups Links
Service.
> resolved,=20
> I've gone back to my 1160s, one of which has Fotonics in it, which I=20
> I=20
> choose=20
> which photos they want, and will then will require keeper prints, I=20
> on=20
> spoke=20
> for=20
> My=20
> I=20
> again=20
> had,=20
> but I certainly have had it.  Coincidence?  The CavePaints?  I can't=20
> know for sure.  They are also coming out with a paper which they=20
> photo=20
> paper, the purpose of which is to improve the archival prospects to=20
> for=20
> attractive=20
> in=20
> reality. What I forgot to ask is if the paper is an RC paper.   But=20
> now,=20
> James
<james@r...> wrote:
snip
>...I profiled the Fotonics on
These paper Dmax issues are more on the minds of us B&W pigment folks.
I like Fotonics, and even used Lysonic Es for some time. I have no
doubt that you are getting good blacks and gamut with dyes on that
paper. I suspect you won't reach that gamut, dmax, or transperency
with Ultrachromes. Color pigments have always looked more opaque on
paper to me, not a bad thing, but a different thing.
I also think Fotonic prints will last a good long time. Jan has been
reputably exhibiting them since long before this list even exhisted.
AND, that new paper you mentioned that we are all waiting to see, will
no doubt favor dye inks.
I'd just hate to be the guy that recommends to you that you should be
the bleeding edge guy yet again with 3rd parties in your 7600. C.D.
may have a valuable opinion on that too, he has a lot of Fotonic
experience.
Tyler
2004-05-10 by John Vitollo
> James
I have Fotonics with an Epson 1200 - output on PhotoRag is awesome. No need for an
Epson 2200...though maybe for UT7
Thanks for all the William Turner info - if it's good enough for Tyler it's worth a try!
John
> with Ultrachromes.
When I switched from Archiva dye inks (which I found out weren't so
archiva, after all) to Generations, I expected to have to make an
adjustment, and accept that the inks would be all dull or something.
To my amazement, I thought the Generations looked great. When I got the
7600 with the Ultrachromes, I expected to see some sort of major
improvements on the Generations.  I didn't.  The inks looked ok, but I
found myself comparing UC prints to my old Generations 1160 prints to
see if they measured up.  They were ok, especially when factoring in
that much bigger prints could be made.  But a vast improvement?  No.
An improvement at all?  Couldn't prove it by me.
Right.
Yes, that's what it's intended for, according to Lyson.
I understand, and wouldn't ask you for one.  But I would think that dye
inks would inherently have not the same clogging problems going through
heads that pigments do.  Am I wrong about that?
James
7600 dyes and pigs was How does William Turner...
<james@r...> wrote:
snip
>...When I got the
Generations were always pretty darn good, I think the major advantage
of the UCs were that they could print on the more photographic Epson
surfaces. I've never heard UCs were substantially better in other
ways. I've not been paying attention to the latest Generations, maybe
they can print on those surfaces too. I think most people just stick
with OEMs without asking these questions, and Epson is making it
harder to play around.
snip
>...I would think that dye
On the face of it I'd agree, also based on watching people's
experiences over the years as a generalization.
Sounds like you may be the one that tells us for sure <G>.
One color still not functioning eh?
Tyler
Re: [Digital BW] 7600 dyes and pigs was How does William Turner...
> Tyler
'Fraid so.  And an additional color has lost suction that was printing.
  I've deformed either the dampers and or the tubes, I guess.  I will
probably replace the dampers along with the head, and possibly the
tubes as well, though I hope not, because that looks like a much bigger
job still.
James
