Building profiles
Building profiles
2003-07-18 by Andre Vallejo
As always,I'm trying to consistently match my mono prints (MIS-UT-FSN,Epson 1160,matte and smooth pearl paper).
So I wrote to a known professional profiler maker to see if I could have one made for this combinations. I quote the answer:
" Quad-tone ink sets require proprietary software code to be used instead of the standard color ink set.  Standard color ICC profiles are not useable with these ink sets because of the proprietary software code.  The only place you can get profiles for quad-tone ink sets is from the supplier of the specific ink set.  "
I'm not sure I understand what the problem is...If one has the spectrophotometer,the printed patch and the profiling software,what's the problem?
Best
Andre Vallejo
www.andrevallejo.net
Re: Building profiles
2003-07-19 by Andre Vallejo
Seems more clear now Tyler,thanks...!
Message: 24
   Date: Mon, 19 Jul 2004 02:14:21 -0000
Subject: Re: Building profiles
A CMM uses ICC profiles to remap input color to the nearest printable
color the device/paper/ink can manage.
Quadtone profiles require density remapping for propper gradation, but
also assigning different tonal areas of the input to their apropriate
quad ink. This assumes a standard color driver without this
partitioning capability built in. The ICC approach and profiling
software has no way of knowing you want to send all your highlights to
a light gray ink that happens to reside in the yellow ink tank, then
smoothly transition to a darker ink that happpens to reside in the
magenta tank, etc...
This isn't to say you coudn't profile it, and even print through your
profile with possibly some success, but there will be no ink
partitioning to take advantage of using a quad inkset.
Color management, with the use of a profile, simply remaps color from
one defined space to another as closely as possible given the
characteristics of the two spaces.
Hope that makes sense.
Tyler
Re: [Digital BW] Building profiles
2004-07-19 by Carl Schofield
Andre,
I'm not sure what you meant by "trying to consistently match", but If
you just want icc profiles for soft-proofing your printed output then
that can be done.  Roy Harrington has a description of the method and
the files needed for making the profiles on his QTR website:
http://www.harrington.com/QuadToneRIP.html
Carl
> the problem?
> Best
> Andre Vallejo
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER”
> AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2004-07-19 by Tyler Boley
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andre Vallejo"
the problem?
> Best
> Andre Vallejo
RE: [Digital BW] Building profiles
2004-07-19 by Paul D. DeRocco
> From: Andre Vallejo [mailto:mastologia@...]
The problem is that a quadtone (or hextone) inkset typically uses the
manufacturer's RGB driver, letting it believe that it is actually printing
in color. When printing color, there is only one combination of R, G and B
values that will translate into any particular color, but when printing with
quadtones, there may be many different combinations that yield the same
density of gray. Profiling software, which expects to operate on colors,
will be hopelessly confused by the many test patches which look like the
same color of gray.
Ciao,                   Paul D. DeRocco
Paul                    mailto:pderocco@...
