What is "bronzing"
What is "bronzing"
2004-08-01 by Adolph B. Amster
I'm perplexed and would appreciate knowing what "bronzing" is. I suspect it is
what I describe below:
	I'm using Epson Matte Paper Heavyweight with MIS Eboni inks and the
Roark curves. Some small areas in a print acquire an unusual "sheen". Typically these
are in dark gray regions: the tone is correct but detail is lost.
	Regardless of whether this is bronzing, I'd appreciate suggestions for solving
the problem.
	Thank you.
email: dolph@...
RE: [Digital BW] What is "bronzing"
2004-08-01 by Paul D. DeRocco
> From: Adolph B. Amster [mailto:dolph@...]
> is. I suspect it is
> suggestions for solving the problem.
Bronzing is primarily a problem on shiny papers in the black or near black
areas. If you catch the light just right, you get a faint yellowish
reflection. On Epson printers, it seems to be caused specifically by the
black ink, because ImagePrint, which uses a higher proportion of black ink
when making grays, produces prints with more bronzing than the Epson driver,
which mixes more color inks.
Your description would seem to match, although I hadn't seen it on matte
papers before. I consider it a minor irritant since, if you put a print
under glass, the normal reflections off the glass interfere with the viewing
more than the bronzing does. But I've heard that it can be lessened with
certain sprays.
Re: [Digital BW] What is "bronzing"
2004-08-01 by Douglas Meeuwsen
hmmmmm....My bronzing problem is really exagerated. It actually mainly
occurs in the transition from mid to highlights. So much so that and
image of water will actually look from certain angles like it is goated
with gold glitter. turn it a little bit and it looks great. This is way
more exagerated on smooth pearl than smotth gloss, because the surface
is bumpy, but it there on gloss too. It does not seem to be related to
the black ink. If I print black only with the same black ink, there is
no bronzing. Of Course I am using UT2 grey inks, so there is black ink
all around I suppose......I am getting the print guard spray
soon......hopefully that will cure it.
>  > ����� I'm perplexed and would appreciate knowing what "bronzing"
>  > is. I suspect it is
>  > ����� I'm using Epson Matte Paper Heavyweight with MIS Eboni inks
> and the
>  > ����� Regardless of whether this is bronzing, I'd appreciate
> black
> the
> black ink
> driver,
> matte
> print
> viewing
> with
>  certain sprays.
>  Ciao,�������������� Paul D. DeRocco
>  Paul��������������� mailto:pderocco@...
>  If you wish to receive no emails or just a daily digest, or you wish
> this same page.
>  Please follow these basic guidelines:
>  - As threads develop, trim off excess portions of earlier messages to
> keep them short.
>  - Good manners are required at all time. No personal attacks or
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
>  - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
>  - By posting on this forum you agree to abide by the group rules and
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See �Group Topic, Rules and Guidelines� in the
> Files section:
>  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER�
> AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE� �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <lrec_companion_043004.gif>
> <l.gif>
> 	� 	To visit your group on the web, go to:
> 	� 	 To unsubscribe from this group, send an email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> 	� 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
