Film has "dramatically" more resolution
2004-08-21 by claudej1@aol.com
In a message dated 8/20/2004 9:14:41 PM Pacific Standard Time, DigitalBlackandWhiteThePrint@yahoogroups.com writes: > So in spite of the wonders of digital, which I use for some > things, and the big prints that various users are happy with, film has > dramatically more > resolution. > > Of course others will argue and I know that, so let's not fill up the group > with endless digi > vs film. They both have their uses. > > And for "big prints", it depends on how far you view them from. How does it > look from > "where they'll see it", as opposed to with a loupe? > > Scott I love to pick on blanket statements. Based on the same lens, same image circle, same imager size, even a Bayer sensor beats film anytime. Kodak has a 36 megapixel sensor that is slightly smaller than 645 format. It can beat scanned color 4x5 film. Film has more resolution than digitl ONLY if you use a larger format than digital, but we knew that from the film days. The resolution kings out there are the Clyde Butchers of the world who use 8x20" cameras with B&W film. But it takes 160 square inches of "imager" to do it (without batteries if you wish). Assuming you have a quality device and capture technique, you only need about 1,000 pixels of DIGITAL capture to equal an inch of film, since you interpolate ORIGINAL data. Film is always second generation data, inherently. Black and white film is sharper than color film on any given format at any given ISO rating. That being said, capturing with color film allows you to post process filter the scene. Although not the same as putting say, an orange filter over T-max, you can create a greater variety of products from a color capture. I have shot every format from Minox Spy Camera to 20x24. I am currently on my 25th digital camera in 8 years, own 17 printers, including Big Epsons and have made big prints. I still have 10 digicams because they all suck at one application or another. I used to have 50 lenses and Nikon Hasselblad and Sinar when I shot film. No single camera can do it all. I can say with a high degree of certainty after all that that on a "square millimeter of capture" basis, digital IS sharper than film. The biggest problem I see with digial imaging is: overexposure in capture and Oversharpening the output. Don't let bad practitioners with ugly output cause you to badly judge good technology. Claude [Non-text portions of this message have been removed]
