Cool, thank you.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
<scho@m...> wrote:
> Daniel & Tyler,
> Here are some spectral plots (eye-one measurements) for a 50% gray
> patch printed with an Epson 2200 (UC inks) using the Epson driver and
> neutral, carbon, and sepia QTR profiles. The spectral distribution of
> the QTR pure carbon 50% gray (K + LK) is smooth and the added LM + LC
> in the neutral QTR 50% gray and LM + Y in the QTR sepia 50% gray
> introduces some variations in the spectra, but not enough to cause
> visible metamerism. In contrast, the Epson driver gray is highly
> metameric and the spectrum exhibits sharp fluctuations in spectral
> intensity. The x axis in the plot should read wavelength in nm and not
> epson driver.
> http://homepage.mac.com/scho/spectra.jpg
> On Friday, September 17, 2004, at 09:53 PM, Daniel Staver wrote:
> > Carl,
> > If you print a picture with a deep blue sky using UC inks you'll
easily
> > see a shift from purplish blue to cyan if you move from fluorescent to
> > daylight. This is consistent with the shift you would see with a
> > "neutral" print printed with the Epson driver. This could indicate
that
> > either the cyan or the magenta inks (or both) are the cause of
> > metamerism, not yellow.
> > Daniel Staver
> > http://daniel.staver.no
> >> I agree that the "yellow ink causes metamerism" hypothesis is
> >> unverified and probably false, but it would be difficult to test.
> >> Metamerism is most apparent in neutral prints so if one created a
> >> series of neutral profiles with increasing amounts of yellow added it
> >> would be necessary to also add increasing amounts of cyan and magenta
> >> to maintain neutrality. At some point the neutral grays would become
> >> metameric, but does the metamerism occur because of the additional
> >> yellow ink or the CM? I suspect it is the latter but I'm not
sure how
> >> to set up a test to confirm this. Sepia prints I've made with
> >> profiles
> >> that use only K,LK, LM, and Y do not appear to be metameric but they
> >> are of course also far from neutral.
> > Please visit the Group Homepage to check the Files, and other
> > resources as they are often being updated.
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you wish
> > to unsubscribe, please edit your Membership preferences by visiting
> > this same page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier messages to
> > keep them short.
> > - Good manners are required at all time. No personal attacks or
> > flames. Hostile, aggressive or argumentative users may be removed
from
> > the membership without notice.
> > - Keep your posts and threads related to the group topic of digital
> > B&W printing. Users who persistently make off-topic posts may be
> > removed from the membership.
> > - By posting on this forum you agree to abide by the group rules and
> > guidelines, and to abide by the actions and decisions of the group
> > Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> > Files section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
"OWNER"
> > AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> > LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> > LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE
PRINT
> > YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> > RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> > YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> > PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > Yahoo! Groups Links
