matboard - buffered vs unbuffered with UT2
2004-11-12 by Allan Chen
All, I'm trying to figure out whether printing with the UT2 inks needs buffered or unbuffered mat board. All the references to unbuffered mat board is regarding color prints. Some articles reference dye-based inkjet prints. I have no clue on pigment based ones. any suggestions? allan -- Technical Projects Specialist Academic Computing Stanford University v - (650) 996-0546 f - (650) 725-4685
2004-11-12 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Allan Chen <kaiyen@s...> wrote: > All, > I'm trying to figure out whether printing with the UT2 inks needs > buffered or unbuffered mat board. All the references to unbuffered mat > board is regarding color prints. Some articles reference dye-based > inkjet prints. I have no clue on pigment based ones. The use of mat board buffering is principally a means to reduce the acid-catalyzed degradation of the print paper (not the ink). Hence, I expect any benefit of using buffered mat board could apply equally to (papers used with) UT2 inks and color inks. The use of buffered mat board could conceivably also have some impact on the ink stability, but I'm not familiar with any data pertaining to that. Phil
2004-11-13 by Paul Roark
I favor buffered mat board and printing paper for prints you want to last. The best fade test results I have are on buffered paper, although the surface may be acidic. EEM is acidic and also does very well on fade tests. However, Wilhelm initially noted that the original EAM would yellow in 30 years. Now he rates EEM at about 100 years, in rather perfect storage conditions. In an open display, a significant part of the paper's acids will escape into the air. In an enclosed space like a frame, however, that acid has only the mat boards or the paper as a place to end up. In a conservation article I've seen reports of acidic damage to old books that are encapsulated being up to 10 times as bad as when they were open to the air. With a framed, acidic print, a buffered mat board just might absorb those migrating acids, prolonging the life of the paper. Paul www.PaulRoark.com
-----Original Message----- From: Allan Chen [mailto:kaiyen@...] Sent: Friday, November 12, 2004 11:34 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] matboard - buffered vs unbuffered with UT2 All, I'm trying to figure out whether printing with the UT2 inks needs buffered or unbuffered mat board. All the references to unbuffered mat board is regarding color prints. Some articles reference dye-based inkjet prints. I have no clue on pigment based ones. any suggestions? allan -- Technical Projects Specialist Academic Computing Stanford University v - (650) 996-0546 f - (650) 725-4685 Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
