Boris,
>... is this to imply that there may actualy be a problem
>with the ink, that needs to be worked around?
No, I just have not tested the UT-FSN in large format printers with the ink
order I like. I currently use UT1 in my 7500, and it almost never clogs,
even when sitting for long periods.
I thought your 9000 had a problem with a clogged Y jet. So, I was giving
you a couple of options I'd consider that would work around the missing jet.
Maybe I misunderstood your situation.
Note that I don't expect the UT-FSN to print with a perfect grayscale ramp
in any printer without a grayscale curve or other control. In the old 1160
it is close to perfect with no curves, but generally a simple grayscale
curve is needed to linearize the ramp. You can see some of my FS curves and
setups from my Information Index at http://home1.gte.net/res09aij/index.htm.
The UT-FS densities are the classic old quad densities that go back to the
PiezoBW days; they do not conform to my current practice of having B&W
inksets print well with only the Epson driver.
> Also, we have forced air heating, could a
>dramatic change in humidity cause the inks to clog more?
>(from about 43% to 31%)
I don't live in a low humidity or cold climate, so I can't say. The only
person I knew of who seemed to have constant trouble was in a cold, dry
climate and at high altitude.
>Is placing a humidifier and humidity monitor neer the 9000 a good idea?
I've heard some do this in the winter in cold climates where the indoor
humidity gets very low. Some cover the printers with the humidifiers
inside, under the cover. If it was not monitored, however, I'd worry about
the moisture doing more damage than good.
Hope this helps.
_________________________________
<paul.roark@v...>
wrote:
> I'll be loading UT-FSN into my 7500 in about a month. I'll use the CMCMY
> ink order and write curves for the 7500, 9500, 7000 and 9000. I can't say
> how it works now, not having tried it, but I'm confident it will work
fine.
> The M-density ink is light enough that in large display prints you'll
> probably not find the lack of a Y jet a deal breaker. Also, you could
load
> C & M inks in the C & LC spots, and M & Y inks the M and LM positions.
Then
> use RGB curves to distribute the inks. The PiezoTone system has gone to
an
> ink order similar to this. I prefer the other ink order, in part, because
> it gives me an excellent glossy dmax by using the 2 dark grays. This
avoids
> the problem of having to change black inks. I just leave Eboni matte K in
> the printer and can still print on glossy papers.
> I'll report on my 7500 UT-FSN progress in about a month.
> Paul
> www.PaulRoark.com
> From: Panopticon Gallery [mailto:gallery@p...]
> Sent: Tuesday, November 16, 2004 11:56 AM
> Subject: [Digital BW] MIS-UTFS in Ep9000
> Does anyone use MIS-UTFS in an Epson 9000? I'm having a number of
> issues, not the least of which is that my Y chanel will not unclog.
> I've had a repair guy in, he swaped out heads and did the maintnance
> kit thing but the clog persists even with the new heads! It seems
> fairly unlikely that the knew heads would have an identical defect as
> the old.
> Has anyone had an issue with bad batches of ink from MIS causing this
> kined of problem? I would like to eliminate the ink as a posible
> culprate.
> Any sugestions/advise (aside from getting a 9600)?
> Panopticon Gallery
> 435 Moody St
> Waltham, MA 02453
> t- 781-647-0100
> f- 781-647-4588
> www.panopt.com
> gallery@p...
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
and
> Moderators. See Group Topic, Rules and Guidelines in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
THE PRINT
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
OWNER AND
> MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS,
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
OWNER AND
> MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
INABILITY
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
CONDUCT OF ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY
OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
page.
them short.
the membership.
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
Yahoo! Groups Links
