RE:Digital camera 10Dvs4x5
2004-12-10 by Carl Schofield
Just to follow up on my previous post about stitching, I took some
comparison shots yesterday at a local waterfall with a 4x5 and a Canon
10D.  Here is a side by side comparison of a stitched composite image
(18 frames (landscape orientation) in a 3 column by 6 row matrix) made
with the Canon 10D and 135mm f/2 L lens and a scanned (Epson 3200 set
to produce a 16x2016 bit grayscale at 360 ppi) image from a Polaroid
type 55 4x5 negative, shot with a Tachihara 4x5 field camera and
Fujinon A 240mm f/9 lens.  Exposure for the 4x5 was 2 seconds at f/32
(EI 25) and for the 10D images 1/6 sec f/16 (EI 100).  The comparison
images are side by side screen grabs in Photoshop at 8, 25, 50 and 100%
of image size.  The 4x5 image is 83.6 MB and the stitched 10D image is
80.1 MB and both are 16 bit gray. The 25% image is approximately the
appearance when the images are printed at 16x20 inches.  The stitched
10D image compares quite favorably to the 4x5, although the stitching
is very tedious and time consuming.  You would need a 40 MP digital
camera to get single shot images comparable to the size and quality of
either the 4x5 or stitched 10D images.
http://homepage.mac.com/scho/forweb/index.htm
Re: [Digital BW] RE:Digital camera 10Dvs4x5
2004-12-10 by Roger Howard
Good comparison! Of course many factors at work (different exposure
times most importantly) but it shows what can be done with stitching.
Just fyi, if you're shooting a lot of panoramas to be stitched, there
are autostitching possibilities. I see you're on a Mac... you could use
XPoints (free) and PTMac (not so free) from Kekus.com... for this kind
of work it's very fast/effective and you shouldn't usually have to do
much/any manual stitching (unless you have image pairs where there is
virtually no detail for it to match - like expanses of water). XPoints
does the job of scanning through your images and generating a PTMac
project file with control points set for you - then just open in PTMac,
optimize, and render. Pretty smooth for non-spherical panoramas.
-R
2004-12-10 by Mark Savoia
Great work Carl. I vote for the digital. Did you stitch with Photoshop
automation?
Mark
>  10D.� Here is a side by side comparison of a stitched composite image
>  Fujinon A 240mm f/9 lens.� Exposure for the 4x5 was 2 seconds at f/32
>  (EI 25) and for the 10D images 1/6 sec f/16 (EI 100).� The comparison
> 100%
>  of image size.� The 4x5 image is 83.6 MB and the stitched 10D image is
>  appearance when the images are printed at 16x20 inches.� The stitched
>  is very tedious and time consuming.� You would need a 40 MP digital
>  If you wish to receive no emails or just a daily digest, or you wish
> this same page.
>  Please follow these basic guidelines:
>  - As threads develop, trim off excess portions of earlier messages to
> keep them short.
>  - Good manners are required at all time. No personal attacks or
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
>  - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
>  - By posting on this forum you agree to abide by the group rules and
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See �Group Topic, Rules and Guidelines� in the
> Files section:
>  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER�
> AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE� �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <lrec_companion_043004.gif>
> <l.gif>
> 	� 	To visit your group on the web, go to:
> 	� 	 To unsubscribe from this group, send an email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> 	� 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Roger,
Thanks for the tip on XPoints.  I downloaded and will give it a try
with PTMac, which I already had but did not use.
Carl
>> 100%
> -R
Mark,
No, I did all of the stitching manually using layers, masks, etc.  If I
were going to do a lot of this I would definitely try the XPoints and
the  PTMac tools that Roger mentioned in his post.  Also, file sizes
get ridculously large (>2 gb) when doing this in 16 bit RGB with
several layers active at once.  The computer I used had only 768 mb of
ram so I had to do this in 3 sections and then stitch the sections
together.
Carl
> automation?
> Mark
>> Canon
>> made
>> 100%
>> is
>> of
2004-12-10 by Steve Kale
Alan Huntley recommends REALVIZ "Stitcher":
http://www.realviz.com/products/st/
> From: Mark Savoia <mark@...>
> Date: Fri, 10 Dec 2004 13:25:59 -0500
> Subject: Re: [Digital BW] RE:Digital camera 10Dvs4x5
> automation?
> Mark
>> 100%
Long night.
Mark
On Dec 10, 2004, at 1:39 PM, Carl Schofield wrote:
> Yahoo! Groups Survey
> Please help us to improve Yahoo! Groups. Take the survey now!
>  Mark,
>  No, I did all of the stitching manually using layers, masks, etc.� If
> I
>  the� PTMac tools that Roger mentioned in his post.� Also, file sizes
>  several layers active at once.� The computer I used had only 768 mb of
>  together.
>  Carl
> Photoshop
>  > automation?
>  > Mark
>  >>� comparison shots yesterday at a local waterfall with a 4x5 and a
>  >> Canon
>  >>� 10D.� Here is a side by side comparison of a stitched composite
> image
>  >>� (18 frames (landscape orientation) in a 3 column by 6 row matrix)
>  >> made
>  >>� with the Canon 10D and 135mm f/2 L lens and a scanned (Epson 3200
> set
>  >>� to produce a 16x2016 bit grayscale at 360 ppi) image from a
> Polaroid
>  >>� type 55 4x5 negative, shot with a Tachihara 4x5 field camera and
>  >>� Fujinon A 240mm f/9 lens.� Exposure for the 4x5 was 2 seconds at
> f/32
>  >>� (EI 25) and for the 10D images 1/6 sec f/16 (EI 100).� The
> comparison
>  >>� images are side by side screen grabs in Photoshop at 8, 25, 50 and
>  >> 100%
>  >>� of image size.� The 4x5 image is 83.6 MB and the stitched 10D
> image
>  >> is
>  >>� 80.1 MB and both are 16 bit gray. The 25% image is approximately
> the
>  >>� appearance when the images are printed at 16x20 inches.� The
> stitched
>  >>� 10D image compares quite favorably to the 4x5, although the
> stitching
>  >>� is very tedious and time consuming.� You would need a 40 MP
> digital
>  >>� camera to get single shot images comparable to the size and
> quality
>  >> of
>  >>� either the 4x5 or stitched 10D images.
> this same page.
> keep them short.
> Files section:
> Service.
2004-12-10 by Alan.Huntley@cox.net
Carl,
Great comparisons! Get Realviz Stitcher 4.0 and "painful stitching" will be a thing of the past! Not inexpensive software, but, IMO, the best out there for doing this type of work.
Alan Huntley
> From: Carl Schofield <scho@...>
> Date: 2004/12/10 Fri PM 12:57:41 EST
> Subject: [Digital BW] RE:Digital camera 10Dvs4x5
2004-12-10 by Matthew Wensing
size and quality of
Not sure I agree; others have calculated 4x5 as
equally to 'roughly' 200 MP.  And Roger Clark is no
technical slouch:
<http://clarkvision.com/imagedetail/scandetail.html#digicamres2>
Matt
E-mail: wensing@...
Blog: <http://seaofglass.blogspot.com>
Photography: <http://www.wensing-photo.com>
True, no question that a high quality scan of a well exposed 4x5
negative can produce much larger images and prints, but I was not
talking about the theoretical MP equivalence of 4x5 .  I said that if
one wanted to make images with a single shot digital camera suitable
for producing images with the same quality as the images I obtained
with the 4x5 and the stitched 10D, which were both designed to be
printed at approximately 16x20 inches at 360 ppi, then you would need a
40 MP digital camera.
> size and quality of
> technical slouch:
> Matt
Re: RE:Digital camera 10Dvs4x5
2004-12-10 by Shilesh Jani
Carl,
Good work - but so surprise here.
We should remember that placing a matrix of 3 columm x 6 rows APS
sized sensors (your ~80 MPix) is not the same as placing the entire
80 MPix into a single APS (or even full frame 35  mm film) sized
sensor.  No doubt that modern DSLR sensors(>6 MPix) capture detail
close to (or by some people's opinion, even better than) modern high
res film of the SAME APS SIZE.  Your comparison is actually very good
at showing that a small format lens has a great deal more resolution
than LF lenses.  As I read somewhere else recently, "there ain't no
substitute for real estate".  Your test shows that an 80 MPix sensor
approximately 1/2 the physical size of 5x4 film will beat 5x4 film
scanned on an Epson 3200.  To beat a high end drum scan may take 200
MPix onto a 5x4 sensor.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
Canon
made
set
Polaroid
f/32
comparison
100%
is
stitched
stitching
of
On Dec 10, 2004, at 11:50 AM, Alan.Huntley@... wrote:
> Carl,
I've owned Stitcher licenses for several versions, and finally gave up
on it... while it can be convenient for easily stitched subject matter,
I often had frames that couldn't be stitched in Stitcher. After
switching to a PanoTools-based workflow (PTMac on Mac OSX - PTGUI,
PTAssembler, or Hugin on Windows) I will never look back... both for
spherical panos (QuicktimeVR, etc) and for more traditional panos. Too
many crashes and unstitchable scenes, and poor blending, not to mention
the high-cost. The PanoTools workflow seems a bit complex at first, but
it's very very capable, and not nearly as difficult as it may seem -
especially now that there are tools like XPoints to automatically find
your control points, and enblend to do first-class seam blending. It
can be an entirely automated process now, but with far better quality
than Stitcher.
Your mileage may vary, of course!
Roger
2004-12-10 by Glenn Barry
I can recommend any of the gui front ends for panorama tools. I've been
using panorama tools for over 6 years now for stitching anything from
full spherical 360 panoramas to partial panoramas with longer lenses to
get higher resolution for signboards. PTmac for Mac users, PTAssembler
and PTGui on Windows, and Hugin on Linux. Don't forget Enblend (Windows)
and XBlend (Mac and Linux I think) for procesing final remapped images
and getting rid of any colour differences in the overlap sections. There
is also a program called autopano which makes a decent effort at
automatically aligning the images and generating a project file for
loading into the GUI programs above.
There's a list PanoTools@yahoogroups.com
also there is the beginnings of a very good site attempting to collect
the wealth of knowledge available for stiching panoramas panotools.info
Good luck
Glenn
>>automation?
>>Mark
>>>100%
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2004-12-11 by A. Huntley
Roger,
My experience with Stitcher has been exactly opposite of yours...have you
used the latest version? It's the only one I have experience with. I started
out with PTAssembler and, though I believe Max did a first-rate job of
providing a reasonable GUI front-end for the more complex Panotools lying
underneath, I never found the stitching process to be very intuitive using
this tool. Additionally, seams on the final renders required quite a bit of
work to blend everything together nicely. I never had any problems setting
appropriate control points, but always seemed to have the point-of-view set
slightly wrong. And, when "things" (yaw, etc) messed up I was not able to
fix the image to my satisfaction. Probably some of my issues stemmed from
lack of knowledge on how to effectively use PTAssembler and Panotools, but I
finally just gave up.
However, after reading several positive reviews of Stitcher 4.0 and
contacting a couple of photographers on the 'net that I knew owned the
software and who's opinions I respected, I ordered it. This was a very
unusual move for me because I don't usually buy software that I haven't
taken out for a test drive, first! I had been forewarned that though a demo
version was available it was so limited that one could not really judge it
properly. To be honest, I had to contact tech support with a few questions
about how to set certain final rendering characteristics, but that was it.
To my mind, this software is pretty intuitive to use. After playing around
with several renderings of Canon 10D images creating psd layer-based output
with layer masks, and rendering the same image as a single layer tiff file,
I decided that the enormous file sizes required for the former were just not
necessary. I created the layered output because of my experience with
PTAssembler; figuring I'd have to go back and play with the seams to get
things right. However, I found that this workflow was not necessary.
Whatever algorithms Stitcher 4.0 uses for blending seams is, to my eyes,
totally invisible. Now, I only ever create single layered tiff output.
As the saying goes...different strokes for different folks. Don't get me
wrong, I think PTAssembler is a great tool; especially for the price! I've
never used the tools you mention but, for me, Stitcher has worked out great.
Alan Huntley
Sent: Friday, December 10, 2004 2:22 PM
> Carl,
than Stitcher.
Roger
2004-12-11 by Steven Karafyllakis
Carl, very interesting experiment, it certainly shows the potential
of the stitching technique. I must however point out that you have
inadvertantly biased the results in favor of digital, by your lens
choice. I own a  Fuji 240 A, and I consider it my very worst 4x5
lens. In fact, I consider it to be one (small) step above coke-
bottle grade glass. And Polaroid PN film isn't all that sharp
either, at least I've never been able to get resolution comparable
to sheet film out of it. Not to 'nitpick', but the 4x5 should have
been able to do better!
Steven Karafyllakis
Canon
made
set
Polaroid
f/32
comparison
100%
image is
stitched
stitching
digital
quality of
RE: [Digital BW] RE:Digital camera 10Dvs4x5
2004-12-11 by Richard
Sent: Friday, December 10, 2004 10:41 PM
Nice one goodly master Barry...very nice.
Richard
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Re: [Digital BW] Re: RE:Digital camera 10Dvs4x5
2004-12-11 by Carl Schofield
Steven,
I agree that the 4x5 should do better than what I obtained in this
comparison.  Although, I'm surprised by your comments on the Fujinon
240 A quality.  I purchased this lens based on the rave reviews in the
largeformat photography forum and on Kerry Thalman's web site.  Mine
seems to have about the same level of sharpness as my Rodenstock
Sironar-S 135mm f/5.6, which is the only other lens I have for the 4x5.
  The 240 gave the better focal length match to the 135 on the 10D so
that is why I used the 240 for this comparison.  A few other factors
that may be involved are wind (as affecting film flatness - there was
some movement of the envelope during the 2 second exposure), possible
focusing error, and scanner quality.  I added 3 more comparison images
using the scan from a second negative shot at the same time as the
first and this one seems to be slightly sharper, although I'd still
give the 10D composite a slight edge in sharpness.  Both the 10D
composite and the 4x5 scan produce very good 16x20 inch prints so in
terms of the end product its' a toss up.
Carl
> Steven Karafyllakis
> Canon
> image
> made
> set
> Polaroid
> f/32
> comparison
> 100%
> image is
> the
> stitched
> stitching
> digital
> quality of
2004-12-12 by Steven Karafyllakis
<scho@m...> wrote:
> Steven,
Fujinon
Mine
4x5.
Carl;
I've never been able to get particularly sharp images out of mine;
Perhaps I should have it checked? It seems adequate for 4x5, but I
use all my lenses on both 4x5 and 2x3 (common lensboards) and it
just won't hold up for 2x3. One of these days I'll probably sell it
on ebay, so I'm happy to hear it has a good reputation!
BTW-nice photo either way, though I think I prefer the longer-
exposure water-blur.
Steve
2004-12-12 by awahlster
But what you are comparing is the digital camera to the scanners
quality no the 4X5 once you scan the image it becomes a digital image
no longer a film image.
I have never understood why this is always the case. If you want to
compare digital with optical then do it that way don't cut optical off
at the knees and half way through convert it to digital.
I guess you could do a digital capture then print a digital print and
then scan it to compare to the same method used with the 4X5
Mark W.
