C86 HRag 188 Paper Problem
2004-12-23 by mxgo95747
C86 was printing fine with EEM.  I then switched to HRag 188 grm2 paper and at
times it will only print (starting from the top edge of paper) part of the photo. It
appears that it starts printing before the paper is in place and then the paper is pulled
in position and it's printing on the paper.
 Print Preview settings are checked for centered.  I will stop for a while and run EEm
paper through with the eject button, it will handle the HRag paper fine.  After a few
sheets of the HRag paper the same thing happens.  I ran the alignment program and
I am also pressing the HRag paper under some heavy books to see if the slight paper
curl may be causing the problem.
By the way the EZ inks are great.  I been running the following ink position, from left
to right, Eboni, Warm, Neutral, and Neutral with no Brightness or Contrast
adjustment.  It's just very slightly warmer than Eboni "BO" printing.
Martin
RE: [Digital BW] C86 HRag 188 Paper Problem
2004-12-23 by Paul Roark
Some papers may need help with getting started.  Between the eject button
and a little push while it starts, you can probably get the paper to feed
OK.  I suspect the paper is just not feeding all the way in.  Note where
it's supposed to be with a paper like EEM, and then see if the PhotoRag is
getting to that point.  Some papers seem to have surfaces that cause more
feed problems than other papers.
These printers have also been more susceptible to problems caused by concave
curl of papers.  Because the head is "vertical" instead of "horizontal," (at
least in the earlier versions of the printer), and bottom of the paper can
be beyond the main rollers while it is still printing.  The exit rollers are
all that are holding the paper at that point, and the head can more easily
strike corners that are curled up.
Sent: Wednesday, December 22, 2004 6:04 PM
Subject: [Digital BW] C86 HRag 188 Paper Problem
at
photo. It
paper is pulled
and run EEm
After a few
program and
slight paper
position, from left
Martin
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
