Sorry Steve, I guess I haven't been clear enough: I'm running the
glop in a 1280 with the Epson driver, but printing the UC inks in a
7600 with QTR. I need to flush the LK in the 7600-without wasting
the equivalent amount in all the other colors. Changing the K ink is
not as expensive since you can do so with out flushing all the other
lines, but the rest of the inks are a different story.
I'm taking this approach rather than blending it in for a couple
reasons, not the least of which is -if it works, in the end I will
need to be able to use it with the 7600, but retain color printing
capability. I simply can't commit that machine to some exotic
combination of greyscale inks. In all likelyhood, if it does work
well enough, the glop will wind up in the 7500, either in the K
channel, or blended in through one of the other channels as Carl
Scoffield is doing with his 2200. I'm just not ready to commit to
that without knowing I have a viable functioning system and a better
option than the matte ink on watercolor papers. So far, as you can
tell from my previous posts, the execution has been problematic and
inconsistent-but the results! the prints I have that are flawless
absolutely kick ass, pardon my Greek (I can say that, being Greek
myself). Well worth a bit more effort to work out the bugs.
Thanks for the info, I'll work it out as soon as the Epson cart gets
to me & post again on the results with Epson LK instead of MIS.
Steve Karafyllakis
http://www.stevekphoto.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote:
> In a 1280 the ink should flush out with a couple of purge pattern
prints.
> If you really want to mess with a QTR curve to just flush LK then
simply
> create a new curve with LIMIT_LK=100 and all other inks set at 0
and adjust
> the partitioning to one ink etc - pretty straight forward. You
should try
> using an RC QTR curve instead of EEM. With levels as high as 120%
you will
> start to incur the tint of the glop - according to Carl it is not
perfectly
> clear. Why don't you edit a curve and add the glop (15-20% flat
coverage)
> as the ink is laid down.
> > From: Steven Karafyllakis <steve@s...>
> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> > Date: Tue, 21 Dec 2004 02:21:24 -0000
> > Subject: [Digital BW] More on Glop overcoating
> > A further report and observations on overcoating with MIS gloss
> > optimizer. Some bad news, I'm afraid, at least for those of us
using
> > the MIS UC inks.
> > After switching my K from the 'Universal' to MIS PK and gloss-
> > coating with the 1280, I started getting some very good dmax, far
> > better than I've gotten with matte K on Photorag. The problems
> > however, started a few hours after making the prints, when the
gloss
> > coat really started to dry. The dark gray areas gradually lost
their
> > gloss, and in some cases actually bronzed up again, and looked
very
> > flat. Not the results I'd gotten with the full color prints.
> > The glossy papers hardly suffered at all, but the semi-matte
showed
> > the effect heavily, especially with low-key but not black areas.
The
> > problem seemd to involve only the dark grays, IOW the LK printed
> > areas. I then did a full-page gray-scale, and coated 5 sections
with
> > 5 different levels of glop, using the Epson driver sliders to
> > control the lay-down.
> > After dry-down, 2 things became obvious: 1) While the 100% K band
> > retained the gloss, the bands from 95% to about 75% matted and
> > bronzed again. 2) The heaviest glop coat retained the gloss most
> > consistently. 20% may work if you're mixing it into the ink, but
> > this way, you need more like 120% for a solid coat.
> > A later test of the Epson Premium semi-gloss was more
successful: a
> > day later the surface felt dry, no visible dry-down effects, and
a
> > killer tonal range. So far with this ink combination, the Epson
> > premium semi-gloss is the winner.
> > Other papers tested:
> > Epson PGPP
> > Epson Prem. semi-matte
> > Oriental Graphica luster
> > Proof-Line semimatte DP and Glossy DP
> > Kirkland Glossy (the Swiss-made)
> > I'm hoping that this problem has to do with the MIS LK ink, so
I've
> > ordered a cart of the Epson to test; If the Epson ink is better,
A
> > much lighter coat might do the job.
> > This of course means switching and flushing the LK line, so I'd
like
> > to put out a request to those list members running QTR on PC who
> > have an idea how to do this, for a curve that will run the LK
> > channel only, at full tilt. Or a description of what it needs to
> > look like at any rate, or a link to that info if it is already
> > available.
> > Some further observations-
> > Drying the prints before gloss-coating does not seem to be
> > neccessary. The prints I've had least trouble with, I dried
quickly
> > with a few seconds of hair drier blast, and fed right through the
> > gloss coat stage.
> > If you use a desktop printer for the gloss, the pizza-wheels MUST
> > go. Even at the slowest feed setting the glop coat is too soft to
> > take the abuse. This causes problems with last half-inch of
paper if
> > you're overcoating all the way out. Easy enough to allow for it
with
> > a border.
> > Nozzle checks need to be done on an instant-dry glossy or semi-
gloss
> > paper, so you can see the reflection on the pattern, and so the
> > other ink colors don't get on your rollers and then on your next
> > print. I had been using the back of RC paper-the zero absorption
> > makes the gloss coat easy to see, but cost me a couple of
otherwise
> > good prints.
> > I've had the glop cart in the 1280 for a couple days now, no
> > clogging problems yet, only the occasional cleaning cycle
needed, so
> > far so good. It hasn't been as trouble-free as running dyes, but
> > easier than pigments.
> > The glop is easy to refill in the annoying 1280 carts. I've
found I
> > don't have to pull out the remaining ink/foam-I'm getting 10-
15ml in
> > the bottom with no BS. Wonderfull, considering these carts are
small
> > and coating an entire piece of paper eats the stuff up in a
hurry.
> > Good thing it's cheap in bulk.
> > QTR is working very well for this. So far I've used only the EEM
> > profiles for all the RC papers I've tested, and I have no problem
> > fine-tuning any given pair without-split-toning, crossover or
> > visible metamerism. I do have to use the 1440 super and
> > unidirectional printing to get as smooth and micro-banding free a
> > print as I like, but I would use that setting regardless.
> > What the heck, I think I'll go ahead and pay for it...
> > Print protection being an issue, I tried waxing a couple of the
> > prints that dried properly-it works well, the wax goes on
smoothly
> > and easily, and buffs up nicely. No more skid-marks or
fingerprints,
> > thank you. Very different from trying to wax a straight UC
print. I
> > don't know how much protection wax adds, but it's got to be good
for
> > something more than just smudge resistance.
> > That's it so far;
> > I'd be interested in hearing from others trying this out,
> > particularly anyone using straight Epson UC inks; any problems?
> > Steve Karafyllakis
> > Please visit the Group Homepage to check the Files, and other
resources as
> > they are often being updated.
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you
wish to
> > unsubscribe, please edit your Membership preferences by visiting
this same
> > page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier
messages to keep
> > them short.
> > - Good manners are required at all time. No personal attacks or
flames.
> > Hostile, aggressive or argumentative users may be removed from
the membership
> > without notice.
> > - Keep your posts and threads related to the group topic of
digital B&W
> > printing. Users who persistently make off-topic posts may be
removed from the
> > membership.
> > - By posting on this forum you agree to abide by the group rules
and
> > guidelines, and to abide by the actions and decisions of the
group Owner and
> > Moderators. See ?Group Topic, Rules and Guidelines? in the Files
section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
THE PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ?OWNER?
AND
> > ?MODERATORS? OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
> > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY
> > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL,
> > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE ?OWNER? AND ?
MODERATORS? OF
> > DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
POSSIBILITY OF SUCH
> > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
THE DIGITAL BW,
> > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION
OF YOUR
> > TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
PARTY ON THE
> > DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER
RELATING TO THE
> > DIGITAL BW, THE PRINT YAHOO GROUP.
> > Yahoo! Groups Links
