Lou,
You have it right. The idea is to scan as linear ( raw) as you can. You
don¹t want to make any changes on scanner or Photoshop. It¹s also important
that you don¹t clip out either the paper white or step 26 ( D-Max).
Once you have your scan ready, use the ³import scanned target² function to
open the scan into a preview window. At that point you can drag a mouse
selection around the 26 steps. Once you release your selection. IJC will
display a numeric preview of the sampled values. You can use the numeric
preview to verify that you have properly selected the steps.
Also note that you want to set the aim midpoint slider to (0) this will set
the Aims to be linear.
Joe Berndt
imported into IJC, IJC will extract the pixels values from the file.
On 1/25/05 2:30 PM, "ldina" <lbdina@...> wrote:
> I only played with the scanning import just to try it out, since I
> use an Eye One for linearization. You should probably check with
> Bowhaus to be certain, but this is what I would probably do:
> 1. Scan the printed target RAW ~ no corrections, no conversion, no
> black or white point clipping, etc. I would want to see exactly what
> the scanner sees without any compensation. For linearization, all
> you really want is brightness levels anyway. I guess you could scan
> in grayscale mode if your scanner supports it.
> 2. Bring it into Photoshop RAW. Again, I wouldn't assign or convert
> or alter the data in any way. You want to retain the luminance
> levels as read. I'd just straighten it out so it is horizontal,
> clean up an blemishes or specks with the clone tool, if required,
> being sure not to change the tonal value of the patches.
> 3. Save as a TIF file.
> 4. Open IJC and import from scanner on the linearization tab. Swipe
> the mouse over the data from left to right and the data should fill
> in automatically.
> I'm not sure if this is exactly what Bowhaus would recommend, but it
> makes sense to me. You would not want to alter the tonal value in
> any way, otherwise I would expect your white point, black point and
> linearization to be inaccurate.
> Lou
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lambonick"
> <BMWNick@i...> wrote:
>> > How does one scan the linearization file? I've already printed it
>> > out, and I assume I"d want as straight a scan as possible, set
> black
>> > point as #26, white
>> > point to #1 or the white of the paper, with no auto anything that
>> > could affect the contrast
>> > curve, then save as tiff.
>> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ldina"
>> > <lbdina@c...> wrote:
>>> > > Derek,
>>> > > IJC/OPM is able to use a scanner for linearization, but it won't
> be
>>> > > as accurate as a densitometer or spectrophotometer. All you do
> is
>>> > > scan the printed test target, save it, open it into IJC, and drag
>>> > > your mouse pointer across the target. L* values are read
> directly
>>> > > into the program for linearization.
>>> > > Lou
