QTR settings with Hahnemuehle Photo Rag
2005-01-29 by fredila2
Before I waste all my Hahnemuehle Photo Rag (188), do you have a
recommended "media type" and "curves" setting that produces "cool"
prints using QTR?  I've tried a number of combinations and get some
very washed out results.
I've read a number of messages on the forum about HPR but frankly
I'm confused.
Fred
Re: QTR settings with Hahnemuehle Photo Rag
2005-01-29 by Martin Carrington
Fred,
I'm pretty new to Inkjet Printing, but have found that you HAVE to
soft proof (assuming you use Photoshop) to get a good screen to
print match. Here's my workflow:
1) Edit your image with no softproofing to the desired results
2) Turn on Proofing (get the Hahnemuhule ICC profile from their web
site and use this profile, use the White Paper and Black Point Comp
Settings)
3) Using curves, add an 'S' curve to try to recreate your desired
3) If using QTR try the Matte Paper and UC-PremiereFinaArt settings.
I have tried a blend of 50:50 between cool amd warm
This works pretty well. The image will still be softer than a glossy
paper but if you mount behind glass the differences will reduce.
Hope this helps
Martin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "fredila2"
<fred@f...> wrote:
> Hi,
some
> I'm confused.
> Thanks,
> Fred
Martin,
Thanks a whole lot.  The results are much better.  Your help is much
appreciated.
Fred
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin
Carrington" <martinc@s...> wrote:
> Fred,
web
Comp
> Settings)
> image
settings.
glossy
> Hope this helps
> Martin
> <fred@f...> wrote:
> > Hi,
produces "cool"
> some
frankly
> > I'm confused.
> > Thanks,
> > Fred
Re: [Digital BW] Re: QTR settings with Hahnemuehle Photo Rag
2005-01-29 by Steve Kale
Fred
I would strongly suggest you move to Roy's new amended workflow.  See his
recent post.  Download the "L" (Lab less a and b) workspace and use this as
your editing space.  Get the image how you like it on screen.  Set up a
proof using the QTR - Gray Matte Paper profile, Perceptual Intent, Use Black
Point Compensation and also check Simulate Ink Black.  When you print
following Roy's instructions and put the Gray Matte Paper profile in the
destination space instead of Same as Source, the soft proofed image on
screen will be very very close to output (assuming your monitor is
well-calibrated).  The big issue printing to matte paper is the reduced
dynamic range available vs display.  Roy's icc profile amendment is a very
clever way of using icc profiles to use the Perceptual colour engine to make
this compression.  Do this first before adjusting the image with an s curve
and if you do so only do so with the soft proof that I talked about active.
It goes without saying that you should be using an HPR curve for the ink set
you are using (although EEM is actually not too far off).
Steve
> From: fredila2 <fred@...>
> Date: Sat, 29 Jan 2005 16:31:20 -0000
> Subject: [Digital BW] Re: QTR settings with Hahnemuehle Photo Rag
> Martin,
> appreciated.
> Fred
>> Fred,
> web
> Comp
>> Settings)
>> image
> settings.
> glossy
>> Hope this helps
>> Martin
>> <fred@f...> wrote:
>>> Hi,
> produces "cool"
>> some
> frankly
>>> I'm confused.
>>> Thanks,
>>> Fred
2005-01-29 by Chris Hargens
I'm not clear about this would be done on a PC. Would I first edit in
the L workspace, skip the softproof, and then save the tif after
converting it to the Gray Matte Paper profile, as Roys instructions
seem to suggest? Or do I softproof using the Gray Matte Paper profile
and THEN convert?
Chris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote:
> Fred
See his
this as
up a
Use Black
print
in the
on
reduced
a very
engine to make
s curve
active.
the ink set
> Steve
The workflow is the same for Mac or PC except for the final output which I
understand must be Tiff for PC.  First of all change your workspace to QTR
Gray Lab (from Gray Gamma 2.2 or whatever).  With an existing image which is
tagged gray gamma 2.2 you need to decide right from the beginning of the new
workflow whether to "convert to" or to "assign" QTR Gray LAB.  Roy outlines
the difference in his instructions and so there is no need for me to repeat
here but if you have an image which you already liked the look of on screen
before then "convert" it to the new space (it will now be tagged QTR Gray
Lab).  Edit if need be to get an on screen image you want.  So now you have
your generic image - before paper specific factors.  Now look at the image
with either a Photo Paper soft proof or a Matte Paper soft proof as I
described.  What you are looking at now is pretty much how the final image
will be printed with respect to illuminance, not hue.  We tend to focus on
illuminance and so this is ok - we already know if we want it warm or cold
etc.  Make any paper specific changes and print in the normal fashion
(presumably saving it as a tiff if that is required).  Just don't overwrite
the "generic" image because you may want to print on Photo paper later for
example and don't want any matte paper specific changes to flow through.
> From: Chris Hargens <chargens@...>
> Date: Sat, 29 Jan 2005 17:03:12 -0000
> and THEN convert?
> Chris
RE: [Digital BW] Re: QTR settings with Hahnemuehle Photo Rag
2005-01-29 by Tim Atherton
> overwrite
and what space do you save it as? QTR grey lab? QTR Matte? Gamma 2.2?
Because you can't specify those at the printing stage - it's whatever he
file is tagged with.
tim
Tim
I am not sure what you are talking about.  When you either assign or convert
a file to QTR Gray Lab it is tagged as this and this is what you want.  The
whole point is that you want to edit in QTR Gray Lab and have your files
tagged and saved as QTR Gray Lab.  You then use the PS colour engine to
convert the file on the fly at the point of printing (a la a colour
workflow) to either the QTR Matte Paper or QTR Photo Paper profile
(depending on the paper you are printing to) using Perceptual Intent and
Black Point Compensation.  This is just as with colour work.  PS therefore
uses Perceptual intent to manage the compression of the tonal range from
image or file to the print (matte or photo) space which has previously been
linearized.  This is the object of the exercise and unless you are telling
me that your PC does not have the Perceptual intent which I am sure it does
then you should be able to do it just like colour work.
And to your earlier post, if there has not been an HPR curve made available
to PC users then I am sorry.  They are easy to construct for a Mac and
presumably at some point someone ported a bunch of profiles over.  HPR and
EEM are very similar and almost substitutable.  The issue people are
grappling with is not the minor differences between HPR and EEM but the
major issue of tonal range compression from file to matte (any matte) paper.
This is what Roy's latest addition does.  Rather than ad hoc s curve
adjustments he uses the Perceptual colour engine to do the job.
Take a look at Roy's (Mac and PC) instructions and give it a go.
Steve
> From: Tim Atherton <timatherton@...>
> Date: Sat, 29 Jan 2005 10:25:21 -0700
> Subject: RE: [Digital BW] Re: QTR settings with Hahnemuehle Photo Rag
>> overwrite
> tim
Of course you can.  The issue is not the 2200.  I use HPR curves with a
21/2200 without issue.  Maybe the issue is Mac vs PC in that you can not yet
construct your own curves with a PC.  In this case use EEM curves as they
are for all practical purposes close enough.  See my other post.
Steve
> Date: Sat, 29 Jan 2005 10:20:53 -0700
>> the ink set
>> Steve
> which you can't do on a 2200...
> tim a
> Tim
> or convert
> want.  The
if you are using QTR PC you don't use Photoshop for printing - you can't
convert anything on the fly at the point of printing - which was my point.
You can't edit the file in the QTR LAB Grey then assign a profile at the
point of printing. Everything has to be done when the file is saved - hence
my question (and Chris's I believe)
Actually there are significant differences in the way HPR and EEM print
tim
> can not yet
Again - that was my point -t here are as yet no HPR curves for the PC
version
OK got you.  Then edit as discussed.  Soft proof as discussed.  Prior to
saving as a tiff for printing, convert to profile QTR Photo or Matte
depending on media using Perceptual and Black point compensation, save as
tiff - now you have a QTR Matte (or Photo) tagged file.
If you are stuck on the Windoze platform and have no other choice EEM curves
are very close to HPR.  Most of us use EEM for proofing.  The linearisation
will be off but not too badly - dMax and dMin are not massively different.
The bigger issue (and the one I think most users struggle with) is how to
manage the big tonal compression and it is Roy's addition that gets this
done well.  Presumably someone, Roy?, ported the existing profiles that were
in circulation for beginner Mac users over to the Windoze platform.  Given
HPR profiles exist for Mac users perhaps if you asked nicely that person
will port them over for PC users.
Cheers
Steve
> Date: Sat, 29 Jan 2005 11:01:24 -0700
>> Tim
>> or convert
>> want.  The
> tim
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See „Group Topic, Rules and Guidelines‰ in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰ AND
> „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
Your original post made no reference to PC vs Mac but rather mentioned the
2200 printer.
> Date: Sat, 29 Jan 2005 11:03:07 -0700
>> can not yet
> version
2005-01-31 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@b...> wrote:
In a very short while, it's the Mac users who are going to feel "stuck" ;) ;)
Steve Billard is adding GUI curve generation to QTRgui. I'm building a neat curve generator that can do curves for QTR, as well as N-channel ICM profiles (N being as high as 16) for another printing application (tease, tease) as well as converting from QTR curves to N-channel ICM and back.
Right now, it's likely Steve Billard's will be debuting sooner. I don't know if he's planning on doing anything for the Mac. All my stuff is in wxWindows, and could (theoretically) compile for a Mac, but I'm only releasing Windows and Linux at this time.
By "porting", do you mean fixing the ridiculous Mac carriage returns on a text editor?
2005-01-31 by john dean
Well - as graphics professionals we will never be "stuck". Microsoft belongs in the offices
of accountants and typists. Windows is a disgrace for graphics, and should be eliminated
from the face of the earth, forever and ever, amen. Do you see them producing high-end
cinema  animation like Lord of the Rings on Windows 2000 or NT, hell no. That would be
retarded. They do that on a G5. We're not going anywhere.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean" <deanwork2003@y...> wrote:
Actually, that's why Apple created "Lisa", the first predecessor to the Mac, and gave it a GUI and a mouse. It was designed to be the ultimate spreadsheet machine for high power accountants and financiers. The DTP was just for pretty financial reports. The fact that the machine failed miserably in its target market, and went on to find widespread acceptance in the graphics arts community, surprised the heck out of Apple.
Actually, they seldom allow Macs near anything as important as major movie visuals.
WETA, who won the Academy Award for Best Visual Effects for LOTR, created the animation on a network of SGI Octane workstations, and rendered them on....
3200 PCs, in rack after rack of blades.
> That would be
> retarded.
Mirror, mirror, on the wall...
You're quite right. You're not going...
anywhere...
ever.
Seriously, I've found the majority of Mac users are decent people. It's amazing how one bad apple (or one opinionated Apple user) can spoil a whole bunch of good.
Ciao!
Joe
2005-01-31 by Tom Husband
> I can  see you never used a G5 with a 8 gigs of ram for photo
applications or you won't
> even think like that. And LOTRings animation was created with a room
full of G5's because
> I saw the film showing them do it. Not that I care about Hollywood.
> Steve Jobs never saw the Mac as an office machine. That is why he
hated IBM drones
> looking for employment in his engineering departments. And, it is
still true that Windows
> is a cheap and sad imitation of of the Mac interface. And all the PC
laptops suck as well.
What does this have to do with QTR settings and photo rag?
It's a no win argument.  Can we drop it?
Tom
2005-01-31 by Bob Frost
John,
Those are probably the sort of comments that the dinosaurs made to one
another many years ago! Variety is the spice of life, and without it there
would be no evolution.
Bob Frost
in the offices
be eliminated
producing high-end
That would be
