Re: [Digital BW] Lyson's Quad Black and Canon i965 printer
2005-01-31 by BKPhoto@aol.com
Antonio- Have you had any issues with the Lyon ink cartridges? Bill Kennedy Associate Professor of Photocommunications St. Edward's University 512/448-8680 [Non-text portions of this message have been removed]
2005-02-01 by hmseattle2004
Antonio, I have been using the Lyson Quad with an S9000, not exactly the same printer, but 6 color and probably uses very similar drivers. I get decent prints, although I have recently moved to Espon with MIS pigment inks and like the results much better so far. A few notes: I get acceptable images from the Lyson/Canon combo (albeit some magenta metamerism) using a PS CS workflow with Epson EEM paper. I have found that the Lyson ICC profiles are ok, but dont add too much. I also have found that adding +5 to the 'Intensity' setting in the print driver gives richer print results. I've also had lousy results printing on Photo rag, William Turner and Entrada. Flat. No punch. I think it has to do with the *amount* of ink being used. Turning up the *intensity* on all color sliders helps. Can you provide more detail regarding your workflow, your exact print driver setting, paper, etc. And, of course, Bill has an excellent point bwlow in regards to double checking that the cartridges are working. Did you do a printer pattern test to make sure all cartridges are flowing? Howard --- In DigitalBlackandWhiteThePrint@yahoogroups.com, BKPhoto@a... wrote:
> Antonio- > > Have you had any issues with the Lyon ink cartridges? > > > > Bill Kennedy > Associate Professor of Photocommunications > St. Edward's University > 512/448-8680 > > > [Non-text portions of this message have been removed]
2005-02-01 by Douglas Meeuwsen
i was using lyson quads on an epson 1200, and was able to get decent prints, on matte paper only. Even then, it was trial and error. The lyson profiles were so far off that it was amazing. I went thru about 3 sets of inks, before i got them to print well. Then, the prints had a bit of greenish tint, which on some papers was real bad. As I recall, crane museo ended up being about the best. EEM I could never get to work. Blotchy, posterized etc..... museo has a warm color that neutralized the inks. Those museo prints are about as good as I get on my 1280 with UT2 inks, except the tone of the UT2 is controllable. Ilford classic pearl was good except that it was really green. All glossy papers were terrible, and i tried everything out there. ( i think). Bottom line is, experiment experiment experiment. Also, if you are using a mac, dont use the gimp driver. It might be better to get a 60 dollar epson C86, and use MIS EZ's. Then you could tap into the knowledge on Mr. Roarks website. That would probably cost the same as three sets of lyson carts! something to think about, if you can deal letter size as the Maximum size. good luck and hang in there, making one little adjustment at a time...Doug M
2005-02-01 by john dean
You are never going to eliminate the metamerism with the Lyson quads or even their small gamut set that is a little better. They are reddish under tungsten and greenish under daylight. Move on to carbon pigment and you will be pleasantly surprised at the difference. John
2005-02-02 by antonio bardonio
John, to your knowledge, what carbon pigment inks are available for my Canon i965 printer? Although digital B&W printing appears to be only Epson, tha Canon i965 should be a nice alternative, given its 2880 resolution, 2 pico-liters drops and the 6 separate cartridges. Antonio john dean <deanwork2003@...> wrote: You are never going to eliminate the metamerism with the Lyson quads or even their small gamut set that is a little better. They are reddish under tungsten and greenish under daylight. Move on to carbon pigment and you will be pleasantly surprised at the difference. John Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/ To unsubscribe from this group, send an email to: DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- ALL-NEW Yahoo! Messenger - all new features - even more fun! [Non-text portions of this message have been removed]
