Hello, I have had exactly the same problem on a 2200 that I "think" is now sorted, certainly the image as you describe is exactly what I experienced.
I "uninstalled" and loaded via the "Windows XP" link on Roy's web-site and not from the download page. I also did not load the QTRgui, which might be the problem. The issue with 16bit or 8bit is I think an irrelevance. Try this and it may work, it did for me and now all I need to do is sort out a few profiles.
Good luck,
John
scrber <stephen.bate@...> wrote:
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lambonick"
> <BMWNick@i...>
> wrote:
> > I'm confounded.
> > QTR works just fine on my Mac, but I need to use the Windows
version
> > as well. I d'loaded the Win version, plus QTRgui, but it won't
print
> > properly. The resulting images are stretched horizontally, so that
> 1/3 of the original
> image
> > fills the space that the entire image should have. There is also
> severe banding, and very
> > flat contrast - a much too dark print. This does not occur using
> the Epson driver.
> > I'm using an 8bit PS file converted to tiff for printing, not yet
> > using the new Lab profiles, and I'm on XP.
> > I've tried:
> > 1. Updating the printer firmware
> > 2. Printing at 1440, 1440 Super, and 2880
> > 3. Rotating the originally horizontal image to a vertical
> > 4. USB and FireWire
> > None of this makes any difference.
> > Help!
> Bump.
I know you say youre using 8bit, but I have this repeatedly with any
16bit image, they come out completely grainy and stretched lengthways
by a huge amount. Just an idea but are you sure the images were
8bit....?
Steve
