Monitor profiling question
2005-02-28 by Ken Carney
I have a Sony 21" Multiscan E500 monitor.  When profiling with Optical 3.7
Pro, I cannot get the brightness levels low enough, nor the contrast levels
high enough.  I have tried experimenting with the bias controls in addition
to the gain controls for RGB, with no better results.  The b&w prints (Epson
2200 with OEM inks and IP6, on PR 308) look good, but it bothers me that the
monitor is not within the range that Optical wants. So I have two questions:
A. Is this common, or is my E500 just not up to the task (it is about four
to five years old)?
B. If the answer is to retire the E500, is there an LCD monitor that is as
good as a CRT for B&W, especially in the shadow areas?  I'm less concerned
with cost (within whatever reason goes with this hobby) than accuracy and
consistency.
Thanks as always for any advice.
  --Ken Carney
    www.kencarney.com
Re: Monitor profiling question
2005-02-28 by Louis Dina
Ken,
I don't use Optical so I don't know the 'ins and outs' of that
software.  I use an Eye One and ProfileMaker.  But, I can offer a few
suggestions.
In general, the useful life for most CRTs is about 3 years, at least
for critical color work.  For B&W, it should be longer, since color
is not the main issue.  The phosphors in a CRT get 'tired' after
awhile, especially if the monitor is kept at a high brightness level,
which causes it to go dimmer faster.  You can sometimes extend the
useful life of your CRT by using a lower resolution (ie, 800x600
instead of 1024x768) or by using a lower refresh rate.  But, when a
decent software package won't allow you to hit the target levels, it
usually means the phosphors are losing their umph.  This makes it
hard to get the dynamic range you need for accurate viewing.
Good LCDs for graphics work are generally still quite pricey
(typically above $1000 - $1500).  I still use a CRT for that reason,
but have been doing some looking around and will eventually make the
switch.  Eizo's and Apple Cinema displays are expensive.  You may
want to check out the LaCie and Samsung LCD's.  They have gotten some
good reviews and recommendations.  Low end LCD's are great for video
games and general use, but nearly useless for graphics work.  Cheap
ones are a nightmare to profile, and the results are NOT good.  In
general, expect to spend AT LEAST $600 or more for a decent LCD.
If you do mostly B&W work and are able to get a good monitor to print
match without resorting to extraordinary measures, you may just want
to keep on using it.
Regards, Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ken Carney"
Optical 3.7
contrast levels
addition
prints (Epson
that the
questions:
about four
> to five years old)?
that is as
concerned
accuracy and
> consistency.
> Regards,
>   --Ken Carney
>     www.kencarney.com
RE: [Digital BW] Monitor profiling question
2005-02-28 by Paul D. DeRocco
> From: Ken Carney [mailto:kcarney1@...]
> contrast levels
> in addition
> prints (Epson
> me that the
The pre-calibration merely optimizes the monitor settings, so that the rest
of the calibration (the video lookup tables) don't have as much "work" to
do. More precisely, pre-calibration allows most of the range of the video
DACs to be used, for the largest number of steps from black to white. But if
you can't match the standards, you're still okay, as long as the monitor can
go all the way from black to whatever brightness you require for white.
You'll just have a somewhat smaller number of steps between black and white.
As kodak slowly fades...
2005-02-28 by Seth
This is a copy from another list:
>>Effective immediately, due to low sales volumes, KODAK PROFESSIONAL
>>POLYMAX Fine Art Paper, N Surface, in both Single Weights (SW) and
>>Double Weights (DW) formats has been discontinued and will be removed
>>from Page 43 of the KODAK Professional Stockhouse Equipment and
>>Supplies Price Catalog.  Please refer to the attached document for
>>details.
>>This information will appear tomorrow on the Dealer Partner Site
>>(http://www.kodak.com/go/partner).
>>If you have Partner Site questions, please call 1-800-822-9442 x33.
>>_________________________________________________
Seth
Re: As kodak slowly fades...
2005-02-28 by scott_now_coming
Kodak's into making sensor chips for other companies.
I think that's where they're going to concentrate their energy.
http://www.luminous-landscape.com/essays/kodak-iss.shtml
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Seth"
PROFESSIONAL
and
removed
for
> >>details.
x33.
> Seth
2005-02-28 by Djon
Kodak first introduced (through acquisition) practical sensor chips
about 25 years ago. The chip replaced video camera tubes, fed the data
into high speed tape (no compact solid state recording back then).
I saw this equipment in action at a trade show in Las Vegas: high
speed recording cameras designed to document mechanical movements in
machines, explosions, mechanical failures and the like. It was
intended to replace the cameras that burned millions of feet of Kodak
High Speed Recording Film in engineering applications...Kodak may have
been shooting itself in the foot.
That first Kodak-branded chip-type video camera cost only about $10K.
Deep down, Kodak knew a long time ago that film would die...but they
didn't buy in to that certainty.  Mark Twain said "Faith is believing
something you know isn't true."
The best Kodak news may be the Olympus 4/3 chip.
> Scott
