which is whiter?
which is whiter?
2005-03-03 by alnchiem
I would like to use the whiter of either Epson Ultrasmooth, or Premier
Art Scrapbook paper for Epson.
Is ISO brightness a measure of whiteness?, ...because ultrasmooth has
a ISO of 90 while Premier Art scrapbook is 93.
Many thanks,
Andrew
Re: which is whiter?
2005-03-03 by Clayton Jones
Hello Andrew,
Technically, I don't know.  But in my paper testing I've seen some
warm colored papers that seem brighter than some whiter ones.  So to
me they are two different things.
Clayton
RE: [Digital BW] which is whiter?
2005-03-03 by Paul D. DeRocco
> From: alnchiem [mailto:andrewlee@...]
No, it's a measure of brightness. ;-)
When you refer to whiteness, are you talking about whiteness versus
grayness, or whiteness versus some color cast? If the former, 93 is
certainly a bit better than 90. If the latter, you might be able to figure
it out if you have some software that lets you see the numeric white point
of the paper's profile: smaller a and b values indicate greater neutrality.
Re: [Digital BW] which is whiter?
2005-03-04 by alnchiem
Thanks for all the replies.
I'm referring to white versus a creamy white, and specifically
whether Premier Art's Scrapbook paper is whiter than Epson's
ultrasmooth.
Many thanks,
Andrew
figure
white point
neutrality.
> Paul                mailto:pderocco@i...
RE: [Digital BW] Re: which is whiter?
2005-03-04 by Seth
Although they imply whiteness on most commercial packaging, I believe it is
a measure of "brightness" regardless of true color.  I have held some of the
papers side-by-side that have the same ISO numbers, but appear to be
different shades of white.  Some of "whiteness" will depend on the lighting
and OBAs.
I check white in pure sunlight or an Ott light. Flourescent has that green
cavity and incandescent will warm the appearance of the paper.
Not a great test, but take it to a paint department that has different
lights for looking at their paint chips.
Seth
==-----Original Message-----
==>Is ISO brightness a measure of whiteness?
2005-03-07 by alnchiem
Thanks, Seth. I too check whiteness using sunlight. But I bought a box
of Infinity Arches paper, which turns out to be creamy, and certanly
not as white as HPR or Epson's watercolour paper. sigh.
Andrew
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Seth" <seth@m...
believe it is
some of the
lighting
> and OBAs.
green
different
> Seth
