Roy,
Email on it's way with log file.
The problem is avoided by following the advice here and not printing
a file with the same dimensions as the paper sheet.
Frank
> Hi Frank,
> As several people already have said, QTR does not do borderless so
you can't
> print an 8.5x11 image on 8.5x11 paper. QTRgui should be telling
you this
> saying image does not fit. Most printers have a 1/8 inch margin
all around, but
> Pro printers have a .55 in bottom margin. It's best to NOT put
borders on
> your images in Photoshop, use the positioning in QTRgui to put the
borders
> you want.
> Despite all this, QTR should truncate the image not print a line at
the edge.
> So after doing the clean out and installing 2.2a if you still get
the problem
> could you send me the log files in \Program Files\QuadToneRIP ?
> Roy
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo"
<fh.gross@s...>
> wrote:
> > thanks Diane - i'm going to work on all the suggestions you and
David
> > posted.
> > Frank
> > btw- you did notice an earlier post from Roy saying it was a bug
he
> > thought was fixed
> > > It appears to me that you can't print borderless with QTR--but
you
> > certainly can print within the confines of the print area of the
> > paper (I'm also not sure if you can 'minimize margins' with QTR
since
> > you don't have access to the driver--or at least I haven't
figured
> > that out). If you want to print borderless (because that is
what
> > you are basically wanting to do) I would guess that you will
have
> > to 'trick' QTR--IOW, go to custom, make your paper size larger
than
> > 8.5 x 11 and then choose centered--try that. I prefer a white
border
> > around my prints and don't print borderless.(It also makes a mess
> > with your ink surplus after awhile I believe--though I could be
wrong-
> > -just an assumption since the printer has to go from edge to edge-
> > and there will be some slopover or ink I would think).
> > > Just checked help---select 'placement' and read what it
> > says: "The Placement panel lets you select Centered or
specify
> > the placement of the top left corner of the image. You can also
use
> > the mouse to drag the image icon into a new position if Centered
is
> > not checked. (Note: QuadToneRIP printing models specify minimum
> > margins depending on the printer. QTRgui will reset any margins
that
> > are less than the minimum or greater than the maximum allowed
> > margin.) Next to the placement panel is the Scale panel .
Checking To
> > Fit will size the image to fit into the printable area of the
page.
> > Alternatively, you can also specify a scale factor for the
image."
> > > Hope this is helpful.
> > > Diane
> > > ----- Original Message -----
> > > From: David Lee
> > > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > Sent: Friday, March 18, 2005 10:57 PM
> > > Subject: Re: [Digital BW] Re: QTR printing a line near edge
of
> > sheet
> > > >How does a small 5x5 inch image placed in the centre of a
white
> > > >8.5x11 inch sheet extend over the printable area of the
paper?
> > > How or why it does this I have no idea. All I know is that it
has
> > happened
> > > to me twice and each time I cropped some white off until the
> > image file was
> > > smaller than the printable area and it worked fine.
> > > >Even if QTR interprets the entire 8.5x11 file as having
printable
> > > >information it should see the 1.75 inches on the sides of
> > image
> > > >as 'white' or 'nothing to print' and not print a dark line
down
> > the
> > > >side of the sheet - surely ?
> > > You'll have to ask Roy about the "why."
> > > >Or am I not understanding your solution/workaround?
> > > >Should I be going back to PS and 'cropping'/'removing' the
white
> > > >background from the perimeter of the file?
> > > That's what I did.
> > > >What do you do if you want to print full width or length of
a
> > sheet
> > > >size?
> > > Don't know.
> > > David Lee
> > > > This has also happened to me, but only when I print an
> > that
> > > extends
> > > > over the printable areas of the paper, just as you printed
an
> > image
> > > file
> > > > with a size of 8.5 x 11 on the same size paper. I simply
cropped
> > > some of the
> > > > (white) edge from the file and printed it again. This time
no
> > line.
> > > > By the way, this is my first posting in a long time and I
just
> > want
> > > to say
> > > > what a great program QTR is. (I'm printing with an Epson
2200
> > and
> > > > Ultrachrome inks.) If I had had it three years ago it would
have
> > > saved me a
> > > > lot of trouble.
> > > > David Lee
> > > > From: "frankg_photo" <fh.gross@s...>
> > > > To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> > > > Sent: Friday, March 18, 2005 4:48 PM
> > > > Subject: [Digital BW] Re: QTR printing a line near edge of
sheet
> > > > Got 2.2 installed now - first print coming through and it's
> > still
> > > > printing the thin line 1/8 from the paper edge.
> > > > I dont get this when I do a col print via the epson driver.
> > > > > > Frank,
> > > > > > It sounds like a bug that was fixed awhile ago. You
should
> > > > > > run the latest version 2.2a
> > > > > > Roy
> > > > Please visit the Group Homepage to check the Files, and
other
> > > resources as
> > > > they are often being updated.
> > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > > > If you wish to receive no emails or just a daily digest, or
you
> > > wish to
> > > > unsubscribe, please edit your Membership preferences by
visiting
> > > this same
> > > > page.
> > > > Please follow these basic guidelines:
> > > > - As threads develop, trim off excess portions of earlier
> > messages
> > > to keep
> > > > them short.
> > > > - Good manners are required at all time. No personal
attacks or
> > > flames.
> > > > Hostile, aggressive or argumentative users may be removed
from
> > the
> > > > membership without notice.
> > > > - Keep your posts and threads related to the group topic of
> > digital
> > > B&W
> > > > printing. Users who persistently make off-topic posts may be
> > > removed from
> > > > the membership.
> > > > - By posting on this forum you agree to abide by the group
rules
> > > and
> > > > guidelines, and to abide by the actions and decisions of
> > group
> > > Owner and
> > > > Moderators. See "Group Topic, Rules and Guidelines" in the
Files
> > > section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
BW,
> > THE
> > > PRINT
> > > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT
THE "OWNER"
> > > AND
> > > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT
BE
> > > LIABLE TO YOU
> > > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
CONSEQUENTIAL OR
> > > EXEMPLARY
> > > > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> > PROFITS,
> > > > GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
> > > THE "OWNER" AND
> > > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> > ADVISED
> > > OF THE
> > > > POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE
> > > INABILITY
> > > > TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED
> > > ACCESS TO OR
> > > > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS
OR
> > > CONDUCT OF ANY
> > > > THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR
(iv)
> > ANY
> > > OTHER
> > > > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > > > Yahoo! Groups Links
> > > Please visit the Group Homepage to check the Files, and other
> > resources as
you
> > wish to
visiting
> > this same
> > > page.
> > messages to keep
> > > them short.
> > > - Good manners are required at all time. No personal attacks
or
> > flames.
from
> > the
> > digital B&W
> > removed from
> > > the membership.
rules
> > and
> > > guidelines, and to abide by the actions and decisions of the
> > group Owner and
Files
> > section:
BW,
> > THE PRINT
THE "OWNER"
> > AND
BE
> > LIABLE TO YOU
> > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL
OR
> > EXEMPLARY
> > PROFITS,
> > THE "OWNER" AND
> > ADVISED OF THE
> > > POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR
THE
> > INABILITY
UNAUTHORIZED
> > ACCESS TO OR
> > > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> > CONDUCT OF ANY
> > > THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv)
ANY
> > OTHER
> > > Yahoo! Groups Links
> > resources as they are often being updated.
you
> > wish to unsubscribe, please edit your Membership preferences by
> > visiting this same page.
> > messages to keep them short.
or
> > flames. Hostile, aggressive or argumentative users may be removed
> > from the membership without notice.
> > digital B&W printing. Users who persistently make off-topic posts
may
> > be removed from the membership.
rules
> > and guidelines, and to abide by the actions and decisions of the
> > group Owner and Moderators. See "Group Topic, Rules and
Guidelines"
> > in the Files section:
BW,
> > THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT
> > THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP
> > SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> > SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT
> > LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR
OTHER
> > INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF
DIGITAL
> > BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
> > SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO
USE
> > THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS
TO OR
CONDUCT
> > OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR
(iv)
> > ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO
GROUP.
> > > Yahoo! Groups Sponsor
> > > ADVERTISEMENT
> > > Yahoo! Groups Links
> > > a.. To visit your group on the web, go to:
> > > b.. To unsubscribe from this group, send an email to:
> > > DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> > > c.. Your use of Yahoo! Groups is subject to the Yahoo!
Terms of
> > Service.
> > > [Non-text portions of this message have been removed]
