Re: [Digital BW] 2880 dpi with QTR
2005-03-21 by aderca@sbcglobal.net
Hi Mat
Sorry I can't comment on QTR but if you want
a "canned" solution for B&W within Photoshop CS,
give this link a try :
http://powerretouche.com/index.htm
I've had it for about a year, I use the 8 bit version
which was more affordable. Most of the utilities
can be created via macros if you are a PS power
user, which I'm not. It saves me a lot of time and
allows using color film, so it's a bit more versatile.
The B&W film profiles are useful, at least as a starting
point, it also allows for some very basic "zone system"
approach, though nothing close to the Adams principles.
I find it well worth the money, the sharpening tool also
(IMHO) is much better than the standard PS method
(without any refinements).
Andrei
  Sent: Sunday, March 20, 2005 7:21 PM
  Subject: [Digital BW] 2880 dpi with QTR
  I tried to search the archive and came up with no hits on this
  subject.  The troubleshooting section of QTR Help advises that there
  have been problems reported with 2880 dpi printing.  Is there a work-
  around?
  Off-subject - but if anyone knows any good resources to learn a
  black and white process flow for CS I would be appreciative.  I've
  learned a lot in the last couple weeks but I struggle with how much
  I can(or should) do in 16 bit and then what to do in 8-bit.
  Having lots of fun so thanks for all your messages.
  Mat
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
2005-03-21 by Walker Blackwell
Workflow for bw in cs is as follows.
Scan in true RGB 16bit or 12bit (not 8bit).  Run all your adjustement
layers in 16bit.  Flatten after the first day, flatten your 16bit image
and save a copy as "image_16bitflat_adjusted.tif".  Then go back in
your history to unflattened 16bit and convert to 8bit.  Duplicated your
background layer (base scan) and trash the "locked" layer. Then trash
your duplicated layer. Your are left with only adjustment layers. Save
this as "image_8bitlayers.tif" NOTE: if you have gradient masks in your
adjust layers file, save it as 16bit and not 8bit.  Then go back in
history to your 16bit layers state (with the base image). Delete all
adjustment layers. Save this as "image_16bitflat_base.tif
When you come back to the image the next day, take a look at your
16bitflat_udjusted file. If you like it, start from there. If you
don't, start from the 16bitflat_base file and drag your 8bit adjustment
layers over it.
This is all assuming you are working with base-scan sizes over 500
megabytes and will be going over the 2gig load limit for an image. The
next cs will have simple 32bit support and full 16bit support and will
come out after OS Tiger comes out (Tiger has 64bit support for the
G5s). It will probably have 4 times the load limit for an image as
well.
take care Walker
On Mar 20, 2005, at 06:49 PM, <aderca@...> wrote:
> Hi Mat
>  Regards
>  Andrei
>  � ----- Original Message -----
>  � From: mathewchristopher
>  � To: DigitalBlackandWhiteThePrint@yahoogroups.com
>  � Sent: Sunday, March 20, 2005 7:21 PM
>  � Subject: [Digital BW] 2880 dpi with QTR
>  � I tried to search the archive and came up with no hits on this
>  � subject.� The troubleshooting section of QTR Help advises that there
>  � have been problems reported with 2880 dpi printing.� Is there a
> work-
>  � around?
>  � Off-subject - but if anyone knows any good resources to learn a
>  � black and white process flow for CS I would be appreciative.� I've
>  � learned a lot in the last couple weeks but I struggle with how much
>  � I can(or should) do in 16 bit and then what to do in 8-bit.
>  � Having lots of fun so thanks for all your messages.
>  � Mat
>  � Please visit the Group Homepage to check the Files, and other
>  � http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>  � If you wish to receive no emails or just a daily digest, or you
>  � Please follow these basic guidelines:
>  � - As threads develop, trim off excess portions of earlier messages
> to keep them short.
>  � - Good manners are required at all time. No personal attacks or
>  � - Keep your posts and threads related to the group topic of digital
>  � - By posting on this forum you agree to abide by the group rules
> Files section:
>  � http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>  � BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> LOSSES (EVEN IF THE� "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
>  ������� Yahoo! Groups Sponsor
>  ������������� ADVERTISEMENT
>  � Yahoo! Groups Links
>  ��� a.. To visit your group on the web, go to:
>  ��� http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/
>  ��� b.. To unsubscribe from this group, send an email to:
>  ��� DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>  ��� c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> this same page.
> keep them short.
> Owner and Moderators. See �Group Topic, Rules and Guidelines� in the
> Files section:
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE �OWNER�
> AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LOSSES (EVEN IF THE� �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT
> ADVERTISEMENT
> <22305_0205_016_b_300250_a.gif>
> <l.gif>
> 	� 	To visit your group on the web, go to:
> 	� 	 To unsubscribe from this group, send an email to:
> 	� 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
