Access violation when blending in OPM
2005-03-28 by helen_bach2003
Hi, Has anyone got any suggestions for fixing an access violation problem when blending profiles in OPM, using Win XP Pro and an Epson 2200? Whether blending by slider or by alpha channel, the message "Access violation at address 004C295D in module 'OPM.exe'. Read of address 3F6A1FBD" appears. Uninstalling Quicktime, the USN Lib and IJC/OPM, then re-installing in that order does not fix the problem. Thanks for any suggestions, Best, Helen
2005-03-28 by Louis Dina
Helen, I'd ask Bowhaus for help when getting this type of error. Contact Joe Berndt at spike@.... Some things you might try in the meantime.... 1. Make sure you have the latest windows version of the program, which is v1.0.34. 2. Refresh the printer list and profile list to be sure they are active. 3. If you just finished building or editing profiles in IJC, try shutting down IJC and restarting OPM. 4. Make sure the two profiles you are selecting are both for a 2200. Regards, Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "helen_bach2003" <helenbach@h...> wrote:
> > Hi, > > Has anyone got any suggestions for fixing an access violation problem > when blending profiles in OPM, using Win XP Pro and an Epson 2200? > > Whether blending by slider or by alpha channel, the message "Access > violation at address 004C295D in module 'OPM.exe'. Read of address > 3F6A1FBD" appears. > > Uninstalling Quicktime, the USN Lib and IJC/OPM, then re-installing > in that order does not fix the problem. > > Thanks for any suggestions, > Best, > Helen
2005-03-29 by helen_bach2003
Lou, Thanks very much for your suggestions. We've already been in touch with Joe, and he's trying to replicate the problem. I just wondered if anyone else has had the same problem because it looks like it isn't a bug in OPM. Best, Helen --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina" <lbdina@c...> wrote: > > Helen, > > I'd ask Bowhaus for help when getting this type of error. Contact Joe > Berndt at spike@b... > > Some things you might try in the meantime.... > > 1. Make sure you have the latest windows version of the program, which > is v1.0.34. > > 2. Refresh the printer list and profile list to be sure they are > active. > > 3. If you just finished building or editing profiles in IJC, try > shutting down IJC and restarting OPM. > > 4. Make sure the two profiles you are selecting are both for a 2200.
> > Regards, Lou >
2005-03-29 by selenium_toner
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "helen_bach2003" <helenbach@h...> wrote: > > Hi, > > Has anyone got any suggestions for fixing an access violation problem > when blending profiles in OPM, using Win XP Pro and an Epson 2200? Hi Helen, I have the same hardware and software, and had a similar issue of an access violation. Do you see a preview of the image in the image pane? When I imported a particular image into opm it didn't show up in the preview pane, and whenever I touched any of the controls (centering for example) I would get the access violation. Turns out QuickTime had a problem with the file name. I renamed the file to a shorter name and then all worked fine. Best, Eric.
Hi Eric, Thanks for the reply. We can see the image previewed, and, if there is an alpha mask present, we can see the mask. Everything works correctly until just after the printer springs into action. Everything works perfectly if we don't use blending. I'll try shortening all the filenames, including the profile names. We've tried everything else we can think of, except moving everything to a different computer - which is next on the list. Best, Helen > Hi Helen, > > I have the same hardware and software, and had a similar issue of an > access violation. Do you see a preview of the image in the image > pane? When I imported a particular image into opm it didn't show up > in the preview pane, and whenever I touched any of the controls > (centering for example) I would get the access violation. > > Turns out QuickTime had a problem with the file name. I renamed the
> file to a shorter name and then all worked fine. > > Best, > Eric.
