Paul, thank you for your thoughtful and informative reply.
-Robert
<paul.roark@v...> wrote:
> Robert,
> I don't think there is any good objective comparison of the
options.
> However, here is how I approach the issue:
> First, I won't have anything to do with an inkset that is not 100%
pigments.
> Dyes may clog less, have a higher dmax, and be able to run on more
types of
> printers, but they fade much faster and most are plagued by
metamerism. The
> older pigment inksets were hybrids and the dyes burning off caused
fast and
> sever color shifts with most of them.
> When one looks only at the 100% pigment inkset, the list is rather
short.
> The UltraChromes are the starting place. They no-doubt are the
most
> reliable. With QTR or IJC, not to mention more expensive rips,
the UC
> inkset can make very good B&W prints. However the dedicated
inksets have
> light inks that are less than half the concentration of the UC LK,
which is
> used all the way up in the UC-rip prints to avoid metamerism. So,
there is
> a bit of an edge in smoothness to the dedicated B&W inskets.
> The main 100% pigment B&W inksets I'm aware of are the MIS UT inks
and
> Cone's PiezoTones. In my fade tests both are outstanding. With
both these
> outfits many love them and some have endless trouble.
> The PiezoTones are monotone inksets, as are the MIS UT-FS and UT-
FSN. The
> monotone inksets have the lightest gray inks, and are marginally
smoother,
> but most will not see this unless they look at the pirnts under a
loupe. On
> the other hand, in the MIS UT2 and UT7 variable-tone inksets the
yellow
> position can be used for the super-light UT-FSN-Y. With an
appropriate
> curve, this makes these variable-tone inksets have as smooth
highlights as
> the monotone inksets. I have tried this and have a sample curve,
but I
> don't think it's a worthwhile option for most people.
> The Piezo approach is more turn-key and prints from grayscale
files without
> the need to use curves, etc. As such, the workflow may be easier
for
> people, and I assume there are more paper profiles. The flip side
is that
> it is not an open workflow that allows you to tweak the
profiles/curves
> yourself. It's been a while since I used Piezo systems, so I
might be a bit
> out of date here.
> MIS's business model is to just sell the inks people want, and
then the
> customers are on their own. I make Photoshop curves available to
all, and
> MIS distributes them also, but if there is a paper that I have not
profiled
> with a curve, you're going to have to see which curve works best
and modify
> it yourself. With the UT2 & 7 inksets many papers also print fine
with just
> some Epson driver slider adjustments, which is the easiest
workflow.
> However, the most control is gained with the use of curves or a
rip like QTR
> or IJC. Many on this list use QTR with MIS inks and also have
curves.
> These can often be linearized for a new paper and work fine.
> I use MIS inks because its business model fits what I like to do,
the inks
> are cheap, and they are glossy paper compatible. I think the
glossy papers
> are getting very interesting, and the ability to print on both
types of
> paper without having to change ink is a big advantage, especially
with the
> 7500 and 7600. This ability is unique to a few MIS UT inksets
(among
> pigmented inkset) as far as I know.
> I post my notes on the various MIS inksets I've been involved with
at
> http://home1.gte.net/res09aij/index.htm .
> Good luck in your search.
> Paul
> www.PaulRoark.com
> > From: Robert [mailto:la_native@h...]
> > Sent: Tuesday, April 05, 2005 7:22 AM
> > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > Subject: [Digital BW] Basics on B&W Inks
> > I've been perusing this forum for over a year, and I've seen
literally
> > hundreds of posts about various B&W inkset options for Epson
printers.
> > I have a 2200 and I'm considering MIS' UT7 carbon inks.
> > Before taking the plunge, I'd like to become more knowledgeable
on the
> > subject. Is there a website or a link that discusses the various
> > options that are out there, with pros and cons of each
manufacturer?
> > Finally, has there been any kind of concensus on this board as to
> > which inksets work the best?
> > Thanks,
> > Robert Ades
> > Please visit the Group Homepage to check the Files, and other
resources as
> > they are often being updated.
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you
wish to
> > unsubscribe, please edit your Membership preferences by visiting
this same
> > page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier
messages to keep
> > them short.
> > - Good manners are required at all time. No personal attacks or
flames.
> > Hostile, aggressive or argumentative users may be removed from
> > membership without notice.
> > - Keep your posts and threads related to the group topic of
digital B&W
> > printing. Users who persistently make off-topic posts may be
removed from
> > the membership.
> > - By posting on this forum you agree to abide by the group rules
and
> > guidelines, and to abide by the actions and decisions of the
group Owner
> > and Moderators. See "Group Topic, Rules and Guidelines" in the
Files
> > section:
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
THE PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO
> > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL
OR
> > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR
LOSS OF
> > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
THE
> > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP
HAVE BEEN
> > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i)
THE USE
> > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP;
(ii)
> > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR
DATA; (iii)
> > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT
> > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL
BW, THE
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
